View Full Version : Engine
  1. O2 sensor threads got me thinking
  2. your input on this car..??
  3. cold air intake
  4. Oxygen Sensor
  5. Why is it a slug?
  6. What I learned about misfires & triton motor
  7. Brown foam in oil!?!?
  8. 88, wait 30 min before starting
  9. 2000 f150 with rpm problem
  10. O2 sensors
  11. HELP!! / 2005 F-150 CREW - Problems starting at 1200 miles
  12. Plug Problems?
  13. Should I rechange plugs
  14. Blown Plug...Finally I'm a Victim!!!
  15. 3 codes replaced cop now what
  16. 2004 - Present Spark Plug INSANITY
  17. Gotta see this
  18. Will re-flashing at dealer help engine??
  19. 98 F-150 Intermittent High Temp Indicator
  20. replace 97 5.4 with 03 5.4
  21. help please
  22. High Hydrocarbons
  23. Intake options for 5.4L owners. News. everyone in here please.
  24. Forgive me--- pics are in order...
  25. From Cobra to F150.... questions about HP
  26. strange clicking noise when I start truck
  27. Synthetic oil for 72,000 miles
  28. Air Conditioner Compressor
  29. *five hundred thousand mile club*
  30. five hundred thousand mile club
  31. P/S ticking noise?
  32. Pushrod Cover
  33. Oil on Spark plug!
  34. Fuel Pressure Regulator
  35. Active Fuel Management
  36. battery draining
  37. 4.6L Burned Plugs wrong cams wont run Help!
  38. How to test COPs (coil on plugs), '01 F150 w/155K miles misfire??
  39. 98 F-150 Temp Guage goes out of sight, light comes on
  40. Gas mileage goes from 15.5 to 18 because of premium gas?
  41. 1983 temperature gauge sensor, where is it?
  42. Pinging sound
  43. 1994 Fuel Filter Change Question
  44. raw fuel odor on re-start :help:
  45. boost retardation
  46. Skippin When Warm
  47. 4:10 gears, please help
  48. Check Engine Light 89' F-150 5.0
  49. 01 F150
  50. 04' SCREW 5.4 Intermittent Hissing Sound
  51. Need Help!!!asap
  52. my 97 f150 wont run right please help
  53. 1 barrel to 2 barrel carb question
  54. Sounds like spark-plug ''knock''
  55. Which Truck to buy
  56. HELP! Sounds like the lifters ticking?
  57. only starts with fuel in throttle body
  58. Great MPG...Bad Omen???
  59. 2004 5.4L 3V "tapping" noise ONLY when cold...please help!
  60. 05 5.4 Hesitation
  61. Gotta love the wife
  62. turbonator
  63. Underdrive Pulleys???
  64. Can someone decipher this?
  65. Diagram
  66. Differences between 02 4.6 and a 05 4.6?
  67. 4.9l Oil Leak
  68. Fuel pump question? orvs4me please help
  69. Has anyone reprogammed a 5.4 ?
  70. pretty bad engine vibration
  71. Trufilter Oil Filtration System
  72. Rough Idle & Occasional Hard Starting
  73. don't judge just help
  74. Rear main oil seal leak
  75. 1998 f150 PLEASE HELP
  76. Fan Clutch Replacement
  77. 4.9 trouble
  78. pillar mount pod
  79. How many gallons ..... ?
  80. Fixed my heat problem in my Taurus
  81. 1998 f-150 5.4l
  82. 4.6L Help
  83. Iac
  84. Speed Control
  85. La Gasolina!
  86. Spark Knock - 05/4.6L
  87. Wierd No-Start Issue
  88. service engine soon
  89. Could it be my fuel pump? or what?
  90. loud engine knock
  91. timing specs
  92. Surging Idle- IAC/MAF?
  93. Installing new manifold studs in 5.4 heads
  94. Need Quick Help - Oil Consumption
  95. Water Pump 42,000
  96. 5.4L Throttle Delay Issue...
  97. 2005 KR SC Whistle from Alternator - Anyone had an issue?
  98. 05 5.4L weird howl noise
  99. DPFE troubles
  100. 2006 bad mpg
  101. 351 C...
  102. combination question
  103. oil filter
  104. Oil Flush "Liquids"
  105. 1997 F-150 4.6 XLT questions
  106. 1997 4.6L F150 Heater Core Replacement
  107. 98 F-150 Running Hot Above 35 mph
  108. pic
  109. Help identify this leak... *Pic*
  110. wistle sound around 2000 rpm?
  111. stalling and hesitation
  112. can i do this
  113. fan rotation
  114. 5.4 L Misfire/hesitation/jerking/cuts off
  115. Oil mix problem
  116. 5.4 L acting up
  117. More 5.4 Misfire Carnage
  118. Oil Filters
  119. F150 Engine swap
  120. Oil Question
  121. Synthetic v Regular Oil
  122. Gas mileage
  123. Help ! 1997 Ford F150 4x4 4.6 V8 LOok!
  124. Maybe going Volant
  125. Best Spark Plugs for '97 5.4L
  126. '91 F150 5.0 Rollercam FI Problem
  127. 5.4 3v useing oil?
  128. help...
  129. 4.9 front oil seal
  130. How to Pull 4.6L engine out
  131. 5.4L puffs blue smoke on start-up
  132. Loud Fan
  133. engine cuts off!
  134. Missing Cylinder #8
  135. hypertech
  136. 98 F-150, 4.6L, 221,000+ miles should I change the H20 Pump?
  137. 98 F150 4.6L Radiator Removal
  138. Exhaust Manifold Help
  139. Plastic V8 manifold cracked? Get $$$
  140. 3 valve Ford V-10 heads onto the older motors?
  141. V6 or V8
  142. BAP Sensor
  143. 4.2 V6 potential problems
  144. 1998 F150 w/4.2L V6 - Interference or Not?
  145. Loud noise under hood..
  146. Missfire, flashing CIL in my 03 4.6L
  147. #3 cylinder misfire
  148. Engine ticking after plug change
  149. How often to change brake, steering fluids?
  150. 300 I6 missing on one cylinder
  151. Volant CAI yes or no
  152. Fuel Injectors
  153. Anyone know anything about these fans??
  154. Kill My Truck?
  155. Really need some help on my heat problem...
  156. '05 5.4L Engine Problems...
  157. k&n or e-bay knock off?
  158. Overdrive Problem
  159. rocker arms
  160. blue smoke at start up...
  161. Coolant change - where are the drain plugs?
  162. 4.6L & 5.4L block shared?
  163. Any ideas?
  164. Bad Fords.....
  165. 390 Ford Crank
  166. fuel Filter problem
  167. 300 six..low end torque!
  168. testing 1992 ford without code reader
  169. motorcraft Spark Plugs
  170. air filter
  171. High Pitch Sound at High RPM
  172. Denso Iridium Gap Suggestions?
  173. all she does is whine whine whine!!
  174. 300 I6 barrly runs but starts good
  175. throttle body replacement, how hard?
  176. 4.6 (6) vs 4.6 (w)
  177. Serpentine Belt Help
  178. HELP! Thought it was bad gas
  179. Somebody please help me, truck illiterate.
  180. Need Some Info
  181. No heat-ac blend door actuator?
  182. knocking ?
  183. Proper way to break in engine (5.4)
  184. IAC Whistling Noise: Problem Solved
  185. pinion gear slipping off new flywheel help!!
  186. Need help! How to change heater core?
  187. Horsepower!?
  188. New IAC...Truck still idles rough
  189. antifreeze smell
  190. higher octane vs octane booster
  191. Lifter Noise?
  192. P0402
  193. Vacuum Hoses
  194. Electric Fan Reviews
  195. got a question
  196. morning guys - 94 f150 4.6 wont start - turns over but..
  197. Strange noise? Help.
  198. Engine Braking
  199. Noisy compressor...bearing
  200. diff between 1993 and 1995 F150
  201. 2006 F150 S/C 5.4 3:73 gas mileage question
  202. Trouble codes PO305 & PO306
  203. Any used TimeSert Kits out there?
  204. Plug blow out advice $$$$$$$$$$$
  205. NHTSA investigation on spark plug problem closed
  206. Fuel System
  207. Amsoil - Give me the spin
  208. 98 F150 4.6 Check Engine - Cylinder Mis-Fire
  209. Changing out my COIL - 1999 V6 4.2 liter
  210. 1998 F150 4x4 oil filter relocation
  211. PI Heads
  212. On Line Stock Parts?
  213. How can I bump up the gas mpg??
  214. What is this "bulb" in line with my PCV valve?
  215. Help with coolant leak diagnosis...
  216. 1999 F150 problem!
  217. Anyone besides me use Royal Purple?
  218. Misfire in cylinder one - code P0316 & P0301
  219. Mobile 1 Ext Perf.!!
  220. Radiator Problems
  221. 2002 Supercrew using oil-why?
  222. 2000 F-150 Trouble Code p0430
  223. Ticking sound 1999 V6 4.2L 4x4
  224. 1999 F-150 4.2L Head Torque Specs
  225. Tune Ups
  226. Which is better? K&N in my stock intake or replace w/ entire new K&N intake system?
  227. 4.6L Using Oil!!
  228. misfire code cylinder 7
  229. Engine Failsafe mode???
  230. SuperCharged Mantinence
  231. NPI P&P Heads
  232. droning
  233. High egt
  234. Help Me!! Need Code P1154 explanation!!!!
  235. Fuel Pump
  236. Turbonator
  237. Please spin your Fan
  238. Pulleys & Belts & Fans, oh my!
  239. tensioner pulley question
  240. Which engine?
  241. Do American's build crappy cars...?
  242. New plugs and wires, now rough idle ?
  243. engine build up
  244. Starter Continues to Run Even With Switch Off???
  245. codes
  246. im back...weird noise :(
  247. 4.6 Miss for 2 years
  248. Is it bad to get the RPMs to 5000?
  249. HELP!!!! knock sensor and fuel trim...
  250. Awww dang it, coolent leak...
