View Full Version : Engine
  1. Milk on the Dipstick
  2. Milk on the Dipstick
  3. Milk on the Dipstick
  4. Mis-fire code.
  5. my DTC's
  6. to cam or to E fan
  7. Squeeking/whining noise. What is it?
  8. firing order on 95 5.8 liter
  9. Underdrive Pullies
  10. Red Line?
  11. funny cold shivers
  12. sounds like i am driving over the markers
  13. low rpm hesitation
  14. Oil on spark plug
  15. 13,500 miles on 04
  16. Over 100,000. What should I do for tuneup?
  17. Mobil One venders
  18. Flitz It Ball
  19. truck wont start, O/D off light is on
  20. High Idle Problems
  21. 5.4 Quarter Mile times
  22. Very high idle
  23. Slight Knock On An 01' Triton 4.6
  24. What's the dif?
  25. Most miles on 5.4L
  26. Hydraulic whining sound comming from under hood when starting up/idle
  27. Injector cleaner
  28. 2003 Expedtion 5.4L engine blown!!!!
  29. Intake gaskets on 95 f-150
  30. Why 5W-20?
  31. are these 5.4 all dogs?
  32. Another Knock
  33. Larger Tires versus MPG
  34. another egr gone bad?????????
  35. Cost of brake job.
  36. o2's
  37. Superchips question
  38. Engine stalls every blue moon
  39. spark plugs
  40. Gas Cap Warning Light
  41. Replacing Ignition System Need Part Recommendations
  42. P0171 & P0174 Codes
  43. Help!
  44. timing question
  45. 302
  46. ODB-II Complete Info from Motorcraft Site
  47. Time for Plugs - Motorcraft, denso or NGK???
  48. Anti-freeze odor from tailpipe
  49. Raced 5.7 HEMI
  50. 91 I6 runs rough
  51. Bosch spark plugs
  52. End of winter gas?
  53. oil pressure- wild fluctuation
  54. Oil sending switch
  55. Engine for a F-150 V6 4.2L 1998
  56. Missing sound pad under hood..
  57. Any1 got turbonator details?
  58. 1997 460 tow motor cam change parts?
  59. Help with acceleration.
  60. Bogs down when hot.
  61. MAF Question
  62. K&N air filter and MAS question
  63. Leaves in Air Filter Housing
  64. 1998 F-150 engine shake/rough running
  65. Navi 5.4L dohc swap in 98 with 4.6
  66. flowmaster, magnaflow...your opinion?
  67. Should of been a simple miss, help me!!
  68. vacuum leak or electrical problem?
  69. 2005 smokin on start up???
  70. My 4.6 misses at around 45-65mph??
  71. Popping thru carb after rebuilding 351W
  72. Anyone know anything about an 85 460
  73. loud knock in the front right side
  74. Speed density questions...
  75. Oh Boy, Check this one out...
  76. 94 ford 302ho work in a 85 ford 302 fuel injected
  77. 86 5.0 to 88 5.0 swap
  78. Plug blowout warning signs...
  79. 1988 pickup 360,00 miles ...brain problems...HELP !!!
  80. Flying Spark Plugs
  81. Ticking from the engine 05 5.4L...Pully maybe?
  82. whats the redline?
  83. can you guys make a better ignition kit than...
  84. Intake elbow porting
  85. Smoking on start-up
  86. Power Question?
  87. 2003 HD f150 motor and trany in a 1998 f150 4X4
  88. Truck won't start after sitting overnight
  89. Truck won't after sitting overnight
  90. Need Advice on Plugs
  91. Problem after rebuild on a 302. Please help!
  92. 4.9 300 Exhaust Questions
  93. 4.9 300 Exhaust Questions
  94. 1995 ticking/missing on accell
  95. MAF/IAC Cleaning results
  96. PCV wires
  97. 2000 5.4 with knock at low RPM
  98. Injector economics
  99. Please break the bad news gently......
  100. blew the plug out, or sonmething close too that
  101. Fuel Octane Ratings
  102. need help
  103. 100k tune up 01 F150
  104. New 4.6 2004 and newer
  105. Fuel Rail Sensor
  106. engine swap
  107. Another Blown Plug
  108. Cleaning the DPFE Sensor?
  109. Oil light
  110. Adding a chip! is it worth it!
  111. Cold start
  112. Alienated rocker arm
  113. When to replace Ignition System and Oxygen Sensor?
  114. engine question
  115. Need Advice!! Cai
  116. Oil Filter Location
  117. 04-06 recommended spark plug change?
  118. Coil Problem
  119. AF1 Install
  120. Engine compartment Chatter
  121. No I'm not bitching...But you early 04 might be interested..
  122. 02 F150 problems after "sea foam" treatment
  123. injectors
  124. injectors
  125. AC and the Serpentine belt
  126. Stuck Spark Plug
  127. S&B Intake
  128. 5.4L with 5W-30W oil
  129. 94' 4.9L Air pump.
  130. Ethanol blended fuels??
  131. Synthetic or reg oil
  132. Valve Spring Issues
  133. Just clicking
  134. oil preasure
  135. whistling noise....
  136. Blue smoke at startup with 25K
  137. Who out there has the highest mileage?
  138. '94 loosing power
  139. whining noise from engine??
  140. Need EVM help.
  141. AirAid TBS and K&N FIPK intake
  142. 00' wont start...battery is ok?
  143. New Battery and Crummy Fuel Mileage
  144. Help with CE codes please!
  145. please help
  146. 1995 F150 Air Intake
  147. another shudder / miss in the 4.6 4R70W
  148. detonation problems
  149. High Idle when stopped and moving
  150. best mustang web sites
  151. Intake Manifold Control Circuit
  152. P0171 + P0174 error codes
  153. 2000 F150 4.2 Problems...
  154. Engine code on..Please Help
  155. 2003 F-150 won't start, please help!!!!!!!!!
  156. Plugs on 5.4
  157. Running Hot
  158. hard start
  159. "Turbo" whistle from FIPK
  160. why do ppl use 4x4 oil pans?
  161. Switching to Synthetic????
  162. Alternator
  163. battery replacing questions... help...
  164. 5 qt Oil Change On 5.4
  165. Buying spark plug wire
  166. engine swap (just need to make sure i get the right help)
  167. CE light Emission control leak?
  168. rough idling 5.4 2003
  169. Surging or loping idle
  170. xcal2 & air intakes
  171. K&N FIPK vs 77 - why the difference?
  172. Installed Volant CAI down 2 mpg
  173. 2006 SCREW Hesitates occasionally. Any Ideas?
  174. Spacers
  175. '89 5.0L won't start
  176. K&N FIPK Install Bad Idle
  177. engine/drivetrain info. wanted
  178. engine light is on....help please
  179. SEAFOAM, how i love thee!!!
  180. Need Help With Code
  181. 260 HP 4.6b (factory)
  182. Opinion on Plug Brands
  183. Hard starts on occasions....5.4L
  184. smell oil at start up
  185. Strange whistle on 2000 5.4L?
  186. NEW 2005 W/ Fuel problem?
  187. You used JB Weld For What?!!?!!
  188. 97 f150 misfire
  189. 2002 F150 wants to stall, but doesn't?
  190. warmup time
  191. '01 F150 Still runs cr@ppy, new spark plugs, coil(s) and fuel injectors :(
  192. quintin i need help!
  193. Horsepower????
  194. V10 spit a plug, got lucky
  195. Misfire cure
  196. Blowby in Filter Box
  197. Must Read: Engine Oil Filter Study
  198. hp count
  199. how much fluid will i need....
  200. Kenne Bell too much power?
  201. OK TROYER...I bought a dual electric fan from you.
  202. Will this engine bolt up?????
  203. 5.8 Mods ?????
  204. battery?
  205. walmart synthetic oil?
  206. Cracked Head
  207. EGR tube fitting removal
  208. Go from synthetic oil to what ever the dealer uses??
  209. Performance shop in my town...
  210. 5.4 3v horsepower?
  211. Rear Main Seal Plate Question 5.4
  212. What's the best oil filter to use?
  213. Oil Leak...Part II
  214. Priming rebuilt engine with coolant?
  215. Help in selecting an air induction system
  216. Left bank Lean
  217. Coil Breakdown
  218. Svt Supercharger on Stock 5.4
  219. P0303 Need advice?
  220. Antifreeze leak... no it was a gusher
  221. Could i put a mid 70's 302 engine into a 91 ford??
  222. Intake Manifold Porting
  223. Small oil leak
  224. Amsoil viscosity trouble
  225. MAF sensor
  226. 96 f150 fuel pump help please!
  227. TWO time loser.... 01 blows plug again!heeeeellllp!!!
  228. '01 5.4 Injector Pintle covers available? NAPA autparts sc#%^ed me!!
  229. Truck Maintenance ideas...
  230. Trying to find an exhaust part.. Need Help
  231. Temp sender question
  232. motor swap
  233. Engine hesitation
  234. 4.2L 97 F-150 timing trouble
  235. Is it a 2 valve or 3?
  236. Moisture in #6 plugwell
  237. Plug ID
  238. HELP!!!! WHATdo i do DEAD MOTOR
  239. What will improve performance on F150 4.6 coil packs?
  240. Magtnaflow Discolored from Heat
  241. 5.4 timing problem
  242. misfire problem
  243. Four Wheel Drive Engaging
  244. after market pulleys for f150 4.6
  245. tensioner pully
  246. replacing power steering pump
  247. Performance Problem
  248. Is it possible to replace 4.6 with 5.4 os other hi performance
  249. Lightning acc. serpentine belt problem
  250. un-plug battery for a night, 12 hours later, its dead??
