View Full Version : Engine
  1. Mass o2 Sensor
  2. E-fans
  3. Gas cap warning light
  4. Cams
  5. BBK underdrive pully?
  6. Rear seal advice
  7. O2 sensor
  8. Amsoil
  9. Duplicate Removed
  10. Need some insight on Ticking noise
  11. Head swap
  12. Understanding Oil Viscosity
  13. timing
  14. abs light
  15. Egr valve
  16. cylinder 7 misfire
  17. cylinder order
  18. Knock sensor question
  19. Need diagram to replace heater core
  20. Antifreeze leak.. Help!! (99 4.6)
  21. electrial
  22. Fuel Problems...I think
  23. SeaFoam in crankcase??
  24. Lucas Oil Stabilizer?
  25. Truck won't Start (Need Help)
  26. Po401 for 5.4L
  27. '99' mercury mystique
  28. O2 sensor question
  29. Why does my 03 screw sound like a disel
  30. Installed new engine this weekend
  31. 5.4 oil consumption?
  32. Hurricane is back
  33. Dead!!
  34. Ford Duraspark wiring help
  35. Signs of running rich??
  36. Gas Mileage
  37. HELP Code P1299 ( and overflowing coolant tank )
  38. crate motor question
  39. 5.4 Head Removal/Time-Cert Install
  40. 330 blocks
  41. I messed up (using pure antifreeze) and a little help needed!
  42. Help with ticking noise in engine bay
  43. 2003 f150 4.2 v6
  44. More problems with 5.4 SCrew
  45. MAF Cleaner
  46. Pinging Problem
  47. 1986 F350 460
  48. Check engine light
  49. 05 5.4 U/D pully/75mm BBK Tb ?s
  50. Do I need a radiator flush.
  51. New ignition installed (for those with duel coil packs)
  52. whats wrong
  53. Help With My 1995 F-150(5.0/302
  54. HOWTO: Change engine Coolant / AntiFreeze
  55. Changing out a starter
  56. Losing water
  57. Best way 2 go?
  58. Thermostat Questions
  59. fuel pump cutoff relay
  60. what rpm should be on a straight six standard
  61. fan clearance...?
  62. Coolant leak on 351 Winsor
  63. bad coil (again)
  64. Hard starting when cold 1992 F150 302
  65. 87 f250
  66. Built 4.6
  67. code p1000
  68. Brake Rotor Part# Ford Messed Up HELP!
  69. High mileage post for 4.6 and 5.4
  70. Battery charging problem
  71. Throttle respone in 2004 5.4 screw
  72. Replacement K&N filters???
  73. 180.000 miles
  74. Cyl 4 Misfire Detected (4.6 F150)
  75. 351 Won't start
  76. Oil Pan Question
  77. 455 olds...
  78. Throwing a plug causes damage?
  79. Underhood Engine Compartment Decal
  80. **service engine soon light on**
  81. 2005 150screw Still smelling Fuel & Recalibrated PCM
  82. New Diesel Engines for Ford Trucks
  83. Help!!!!!!
  84. Choice of Cam for 302
  85. Please help with 1997 4.2 v6 issue
  86. F250 turbo on 4.6
  87. indy to atl and back
  88. f150 4x4 will not run under load
  89. Big Problems with Oil Pressure
  90. question
  91. Do I Need to worry?
  92. P0401, P0402, and P1405 codes.
  93. Question about sea foam?
  94. Need power
  95. torque managment
  96. Passenger side upstream 02 sensor, how the bloody #*@#$??
  97. Ford Not Honouring Warranty F250
  98. Bushel of crickets in motor???
  99. Question about TPS
  100. Engine problems
  101. turbo ?
  102. how much coolant?
  103. "Missing" coolant
  104. Iginition COIL OVER PLUG '97 5.4L v8
  105. flareside and styleside
  106. Gas Mileage Dropped
  107. Supercharger ?
  108. Vibration while at cruising speed.
  109. need more power 5.4 screw
  110. DPFE sensor
  111. Race Truck...NITROUS
  112. 1997 F150 4.6 Engine Question (pinging under load)
  113. Question about piston rings
  114. Opinions needed
  115. MSD for '04
  116. 1997 f 150 4.6 engine question
  117. Oil Pressure Reading Zero
  118. [b]oil Pressure Reading Zero[/b]
  119. Bigsert vs timesert
  120. Engine won't idle...HELP
  121. Fuel pump relay?
  122. 1995 5.7 liter 351 water pump
  123. How do you adjust the idle in a 5.4L 04?
  124. great. more DTC's.
  125. i need help
  126. Cylinder Head
  127. fuel filter tricks?
  128. Cleaning throttle body, and lower manifold?
  129. what 4.6 liter engine is better? and which do you have??
  130. specs ??
  131. Just got an F150, have some questions/concerns
  132. Engine chugging, dealer can't figure it out!
  133. To anti-seize or not...?
  134. Plug Wires
  135. new guy needs more power
  136. More mods
  137. stuck sparkplug wires
  138. where are the plugs on my 4.6 v8??? help..
  139. bad oil leak behind oil filter adaptor help??????
  140. Do not buy Autolite oil filters!
  141. 2000 5.4L fan clutch going bad????
  142. Oil gauge is acting up???
  143. Cylinder Misfire
  144. Spark plugs and torque wrench
  145. Off topic, just need some quick color help. Thanks!
  146. A few questions regarding performance
  147. 1998 Ford F150 4.6 - Heater Hose Change
  148. Check engine light problem
  149. Piston slap and brand of oil: relationship?
  150. Who in here hasn't blown a spark plug?
  151. Clicking Sound coming from dash? HELP!
  152. Anyone running the Granatelli COPs and Connectors?
  153. Any News on F150 Diesel?
  154. sqeal in pulleys/belt
  155. Service Engine Soon Light
  156. Humming Noise?
  157. Underdrive pulley?
  158. 4.9's revaphobia
  159. Removing Inectors
  160. 97 F150 4.6 Race Truck????
  161. Programmers... a way to make money?
  162. New Coil Pack worked for 1 run around the block.
  163. BS Call?
  164. 5.4L 3V idle
  165. Running Lean
  166. Hosed down the Engine Now I got a Service Code
  167. need help with codes
  168. Stupid EGR tube..
  169. loss of cylinder compression 4.2 6 cylinder
  170. 302 fuel injection to 351 carb swap
  171. Fuel Pump Question 98 Expedition
  172. New Radiator Installed/Antifreeze Question
  173. Valve Tapping/Lash Adjusters
  174. Supercharger
  175. f150 carbeurator idle speed
  176. question on connecting rods on a 302
  177. damp
  178. Is this ticking normal?
  179. Serpentine Belt
  180. Problem
  181. Smoke at Start-up 1997 4.6L
  182. engine removal lift points
  183. White smoke comeing out of exhast pipe
  184. Torbonator...???
  185. California Emissions
  186. 1996 f150
  187. Oil Leak Additives
  188. Removed Catalytic Converters
  189. Stuck throttle cable in 97 F150
  190. Help me!!!!!!!!
  191. Fuel Injector Clips not completely on
  192. Headers
  193. Hello, I'm new and need help!!
  194. Mystery Hose...Please Help!
  195. High Idle, Low Coolant Temp and Poor Fuel Economy..Related?
  196. Rumor of 6.4 twi....
  197. Wtfbbq?
  198. gas mileage
  199. Catalytic converters
  200. my 1987 f-150 wont start
  201. 4-5 mpg loss in last 60 days!
  202. 5.4L to 5.8L Conversion
  203. For the Newbies asking about misc...
  204. 5.4 Cold Noise Diagnosis, Don't Think its PS
  205. 02' Won't Start When Hot
  206. Where to buy Time sert kit
  207. 4.6 to 5.4 swap HELP
  208. How Much Horsepower...1/8 mile
  209. I need advice please.
  210. Removing the heads to fix plug blowout
  211. CEL Codes, what's wrong
  212. universal joint
  213. camshafts?
  214. Turbo supercharger ???
  215. MAC Throttle Body (#3775)
  216. Confused
  217. werid sound...from 2000 F150
  218. 05 FX4 hard to start *sometimes*
  219. spout plug??
  220. Never Getting Ford Truck again!
  221. Oil pressure - up and down
  222. Ebay Stuff???
  223. Blown Head gasket?
  224. Longevity/Reliability of 4.6 vs 5.4?
  225. plugs and wires opinions
  226. need advice on valve seals
  227. is this the end of my truck?
  228. Can This Be Done Lightning S/c Installed On My 02 5.4
  229. Which engine for a work vehicle... 4.6 or 5.4?
  230. Engine Ticking/Missing???
  231. Weird noise in the morning
  232. Another blown plug
  233. Gear Swap
  234. 1994 5.0 5-speed shake
  235. Spark Plugs
  236. People = Too picky about oil
  237. Underdrive Pullies
  238. 2002 F-150 FX4---Tune Up Advice
  239. EGR question
  240. How should I be breaking it in?
  241. 5.4l Problems..help
  242. Found my oil leak...
  243. 80,000KM maintenance Question
  244. 95 f150 5.8 timing
  245. K&N air intake/Throttle body spacer...
  246. Thermostat
  247. Spark Plug Replacement Dealer Time
  248. Milk on the Dipstick
  249. Milk on the Dipstick
  250. Milk on the Dipstick
