View Full Version : Engine
  1. I smell oil!!
  2. 2004 5.4 Litre coolant leak
  3. Engine has power loss under 2k rpm
  4. Engine stalling
  5. 99 5.lL Triton
  6. Good ole Tune up suggestions
  7. MAF code
  8. Need Help with my F150 300
  9. 2004 Navigator Possable EGR or Fuel Issues
  10. [B] So now what [B]
  11. are the 04+ 5.4l engines still problematic with spark plugs
  12. 2003 f-150 5.4 4x4
  13. 5.4 questions
  14. Engine running rough
  15. 3000 mile Tow&Drive
  16. Oil and Grease
  17. Stroking a 4.6 has anyone done it and is it worth it?
  18. 300 inline 6 Towing question
  19. Check Engine P0119 Coolant Temp. Sensor
  20. Ebay Coil packs- which ones are worth it?
  21. 6 codes, WAAY rich, help please!
  22. Autolite plugs after 50+k miles - read
  23. Wrapping your LT's = More everything ?
  24. Spark Plug Boot Stuck On - Need Advice
  25. Nitrous set-up on a stock Daily Driver
  26. Sulfamic Acid
  27. Low Idle or stalling after 10 minutes
  28. cams
  29. Project Faster150!!!
  30. help: what 2 sensors are on the air intake
  31. Oil level at lower hash marks after only 5000 miles?
  32. Why is routine maintenance so difficult??
  33. oil pressure question
  34. What to do??
  35. Need to know
  36. oil in the radiator
  37. motor swap
  38. what is a FULL tune up?
  39. Looking to beef up 5.4
  40. Air Box Mods?
  41. 1997, 5.4 hesitation
  42. lightning swap
  43. Where is the low pressure access?
  44. Hard starting?
  45. My First MOD!
  46. Masonry drill bit
  47. 2007 4.6 idles rough
  48. Odd Sound Under Acceleration
  49. Quick EGR block off plate question
  50. Which engines will work?
  51. Spark plug change
  52. EGR Check Engine
  53. 6.8 liter Questions
  54. 5.4 2v using oil???
  55. Fuel Grade
  56. truck want accelerate under load
  57. 01' 5.4 w/ new plugs & cops, now has misfire on #3
  58. Cam Sensor Or O2 Sensor
  59. 0135 trouble code
  60. Need help quick...
  61. 1985 f250 351W fuel injected?
  62. high idle
  63. dont buy napa water pumps
  64. Engine
  65. Engine eating oil dipstick?!?! How many qts?
  66. Long Road Trip and Questions???
  67. New C.O.P.'s
  68. Oil filter
  69. Dtc p1000?
  70. Trouble starts on '02 HD
  71. Regular or synthetic
  72. Mountain Suckage Need Help
  73. Should I tackle a rack and pinion replacement?
  74. tps replacement on 1995 f 150
  75. Misfire under load....
  76. Thinking of Buying 99 f150 w/5.4 triton, is it worth it, what problems to expect???
  77. Better gas mileage
  78. replace gas tank....22mpg?
  79. Supercharging 2008 F150 4x4
  80. Going In-Depth With Ford's Twin-Turbocharged V6 EcoBoost Engine
  81. Question about towing hooks at front
  82. I want to build my 3v 5.4
  83. Conserning noise
  84. looking for help
  85. Another idle question....
  86. Battery/Engine Light Issue F150
  87. Another Sythetic Oil Question: Why Should I Switch?
  88. Help out a newbie
  89. Bumpy Electrical Issue?
  90. Spark Plugs
  91. Need underdrive pulley help
  92. need help please
  93. spark plug wire info
  94. looking to do a 2v to 4v enginge swap in an '02 f-150. has this ever been done?
  95. Another tick thread
  96. Solved my 5.4L pinging issue! ! ! No thanks to FRAM...
  97. Engine Codes are like reading lawyer documents
  98. Oil pan gasket on 4x4
  99. Whistling noise from fender
  100. PCV Elbow Replacement
  101. MOVED: 1998 Ford F150 Ranger XLT Check Engine
  102. 3 valve heads on 2 valve block
  103. 300 ci swap???
  104. Salt water logged truck
  105. need help jbrew
  106. Power Steering Pressure Line
  107. Proper Proceedure, Di-elec.,grease in COP connectors
  108. Failing oil pump
  109. $422 for the 15K mile service?
  110. Possible Radiator Failure
  111. got thinking today.
  112. gas mileage
  113. 5.8 swap
  114. Not running right!!!...
  115. Fay Flood Ford?
  116. Injector help
  117. Help
  118. A/C Help ???
  119. Something weird is going on
  120. 4 Part Question, this one's a doozy...
  121. Irregular Idling
  122. best plugs for the 4.6?
  123. have a question (dont flame me!)
  124. Replacing COP and plug on #4
  125. cam from 5.4-4.6
  126. How long have you gone between oil changes?
  127. Idling rough withA/C
  128. door unlock code
  129. Oil Catch Can/By-pass oil filter
  130. only 6qt right for my 05 5.4?
  131. 5.4L in 4.6vin truck?
  132. Imrc??
  133. anyone here use mobil1 oil? about to do 1st change
  134. what oil and spark plugs for my 05 5.4?
  135. Please help
  136. need help
  137. trouble finding part (crank vent system)
  138. HELP Sensor problem
  139. Need help---ticking
  140. Supercharge a 02' F250 5.4L ? ?
  141. what shot of spray can i run stock
  142. convert truck to run off water?
  143. Intake Differences
  144. Heads!
  145. dodge sucks
  146. 1998 5.4 V8 COP's
  147. Bad Gas Milage
  148. Another New IACV
  149. 4.6 engine not firing two injectors
  150. '04 camshaft right side
  151. Iddle
  152. Need advice
  153. Ethanol (E85) & service engine soon light??
  154. 2007 5.4 Hesitation
  155. hey jmc
  156. 1986 5.0L EGR Questions
  157. edge programmer eef2400 ver e32021
  158. Cam shaft postion sensor replacement
  159. Engine, Tranny, Diff.....5w-20/30 or 10w-30
  160. I NEED A PROS ADVICE!! 2002 5.4 2v 16v SOHC in a 99 4.6 2v 16v SOHC
  161. NEED Help major engine shutter-Don't know
  162. where to find
  163. No starting once in awhile
  164. 75 shot
  165. knock knock knock
  166. How to remove baked on oil build up?
  167. Truck gives me a message "reduced engine power" the other night.
  168. Odd misfire issue
  169. How do I jump the fuel pump relay on 03 f150?
  170. TPS, Truck going into "limp home mode"
  171. $2400.00 bill.........need advise!!!
  172. F 150 timing
  173. TPS or Iac/Vacuum
  174. 98 F-150 Won't Start
  175. 1986 5.0L- F-150/Bronco EFI & Mustang EFI
  176. 04 5.4l started erratic and stalling at idle
  177. p0506 idle air control system
  178. throwing code P0353 Ignition Coil C Primary/Secondary Circuit
  179. Sorry for hijacking Engine threads......
  180. Gen 3 injectors in an 02 5.4?
  181. Blown Head gasket..Worth fixing?
  182. New Member 05 Screw
  183. 01 f-150 5.4 powerdyne
  184. 4.9 l help! :(
  185. Help with 99 5.4 Expy
  186. Flex fuel and non flex fuel.... 5.4's
  187. Z-Max yes or no
  188. removing alternator
  189. Help me diagnose this....
  190. What engines will fit?
  191. 05 4.6 fit in a 1999????
  192. Cams
  193. EGR breather filters
  194. EGR Valve
  195. New Owner of an old Cream-Puff
  196. better than chevy?
  197. 96 F150 Help
  198. P0402?
  199. 351 motor swap
  200. old viscosity for elder engines?
  201. 4.10 gears.
  202. Engine Tapping
  203. 3.4 whipple charger??
  204. what changes were made to 2008 4.6?
  205. oil change and sparkplugs
  206. A/C on all the time?!
  207. under drive pulleys
  208. Need some sage advice. Rough idle on 2007 Supercrew.
  209. sizzling sound
  210. changing plugs
  211. Manifolds done. STILL TICKS
  212. 4.6 DOHC ,OOHHH IT's A TIRE BURNER!!
  213. cleaned my throttle body
  214. Choppy Idle/Surges
  215. Bosch Iridium Fusion / Spark Plug
  216. Name that sensor...
  217. changing the plugs
  218. Help with vacuum leak???
  219. 2004 5.4 3v, WTF!!!!!
  220. Driver side Manifold
  221. antifreeze in spark plugs??
  222. FV and FFV
  223. 4.6L engine clatter almost sounds like diesel
  224. 2004 F-150 5.4 24V Knocking like a diesel
  225. Fixed 4.6L Blown Out Plug Myself / Saved big $$$
  226. Very rough idle, PO161 code
  227. Dealer Service - Rough running engine @ 1100 rpm
  228. Royal Purple Oil
  229. New sparkplugs???
  230. best bang for the buck ;-)
  231. Help!
  232. transcooler mount
  233. location of 6th cylinder help asap
  234. Question about the EGR.
  235. 1995 f 150
  236. Electrical issues, battery, alternator or something else?
  237. anyone tried the bosch platinum plugs?
  238. wont stay running
  239. Cant decide- Intakes
  240. Champion Plugs
  241. Rough Idle
  242. 04 5.4 into my 2001 ford f150
  243. Changed spark plugs
  244. New 302 installed - something isn't quite right
  245. DTC on 1998 F150 4.6L
  246. High miles
  247. Tuner questions
  248. PDB fuse 18 blows
  249. injector stuck
  250. Can't figure out the problem...
