- Service engine soon light? DCT Codes??
- 2003 supercrew problem
- performance chip for 06 F150
- 4.2 lower end
- Ethos FR.....What's your take?
- Need More Hp...
- diagnostic code???
- Checking coil pack?
- 99 f150 4x4 with a lightning blower
- 302 roller lifters
- dual fans
- Need Intake Manifold Pics
- help with fuel line
- PO175 System too rich (Bank 2)???
- Questions
- help with fuel filter removal please
- 2004 5.4 with wierd noise
- '01 Expedition starts when it wants to
- Misfire questions
- jbrews Misfire - resolved!!!
- Best Spark Plugs
- Eec Question
- Wanna Be Cool: Water Pump Swap
- bad vibration in 1993 Motor Mounts????
- power increase with cam upgrade
- Started Changing motor today!
- Check Engine Light
- !Makeing my new truck better!
- F-150 4.2 V6 Cylinder Order
- need help
- anyone had this problem?
- bought the truck the 1997 150 ext cab
- Thanks!
- Gas line quick disconnect????
- 2004 F-150: E85 (Ethonol)
- Completly boggeled on this one, HELP!!
- Cadillac Converter Problem
- ford lightning 01
- New f-150 5.4 Bluesmoke on cold start up
- K&N air filter
- Aftermarket Mass Airflow Sensor
- Multiple Misfire!! - Tell me this isn't it!!
- changed battery
- f-150 lightning codes po171,po174
- Leak in Fuel Line
- Engine light
- No Fire--help
- Kinked gas line
- Electric fans compatability and wiring
- 4.6 pinging finally fixed
- 97 150 ext cab worth
- IAC Location
- Is this "hesitation"?
- engine misfiring, getting worse...
- Plugs
- 1990 F150 I-6 question
- Need help, Engine hesitation
- high pressure fuel pump.....
- 2003 4x4 Expedition...
- '01 SCab Power Steering Leak.. anyone else?
- What size socket for O2 sensors
- Real Test Tomorrow
- How many bolts on 5.4L starter
- Engine "ticking" noise
- Engine replacement
- buying a truck need help guys!!!!
- It's BAAAAACK!
- Change fuel filter
- Full Proof Coil(Cops) Test
- 02 f-150 5.4L Rough Idle?
- oil filler cap?
- Rough Idle
- Help with Check engine light
- Oxygen Sensor Problems
- Top Speed Limiter 06 F-150
- Motor interchange
- Oil Filter Relocation Kits???Anyone using one??
- What kind of Power?
- Gas Mileage
- 04 5.4L wont accelerate
- Starting my Starter
- Installing Remanufactured engine
- Shame!! Anyone know this kid
- So, does the Tornado really work?
- Gear Drive
- more 99 5.4 missing bucking and such
- F150 Banshee concept truck
- 2000 E350 stalls/hesistation
- Difference between timesert and bigsert repair kits
- Anybody have a timesert kit
- hypothetical question.
- Emergency blown plug repair with JB WELD
- Can anyone in Phoenix loan a timecert kit
- K&N air intake system 57-2541...
- Engine mfg. date
- Replacing battery cable terminals
- Just got my first F150 5.4 Triton SuperCrew, questions..
- E85 fuel in f-150 engines?
- Propane Conversion
- cams and intake mods for 2004+ 5.4 3v
- New 5.4 owner
- Question for Neal, JMC, any experienced modular motor people..
- Troyer E fans problem - fan slow or no worky at all
- Looking for opinions on air intake systems...
- Titan Talk
- piston 4 missfire
- Blown Plug, options?
- Replacing AC Compress Clutch - Question
- Hi Everyone I M All New 'l' Owner
- 87 302 air intake
- 91 302 rebuild
- E 85
- Need Help with 97 4.6 noise around belt area
- Tachometer
- rough/weak 5.4
- Problems-please read! F150 running terribly!
- Time for a new motor...
- 97 4.6 Romeo question
- Diesel Swap?
- Can't remove gas filter
- Bank 2 Sensor 2?
- 4.6L Head gasket question...troubles ahead?
- Flowmaster vs Borla ????
- 2005 F-150 4X4 Smoking Issue
- cylinder head gaskets
- Will a V 10 fit my F150?
- "check engine" light.
- Question on Cruise Control usage
- what sensor is this
- K&N Air Filters. Any good?
- Possible oil leak
- Scan Tool, which one?
- Antifreeze leak
- Slight hesitation and whistling sound
- popping through carb
- 4.6 knock
- 5.4 running very rough, need some help please!!!
- Underdrive Pulleys
- 5.4 going in.
- Buzzing sound....
- Electrical Problem Or Fuse ? 2001 F-150
- Bad Mis / NO power
- What next?
- Converting to 35.7 gallon gas tank
- 4.10 gears purchase ?
- When your O2 Sensors are bad.......
- Is it the Alternator or battery?
- 99 Expedition won't start - No power to cam sensor
- V8 Swap
- Lincoln 5.4 DOHC conversion
- oil pressure problems
- 1990 lincoln 302 to 1994 f150 motor swap
- Throttle Body Leak
- Considering to buy '99 f-150 stepside 4.6
- What is it?
- Replaced Blown Fuses helped w/misfire?
- Engine oil
- 5.4l stroker kits?
- Low fuel hesitation
- wrench light
- Exhaust leak help?!
- Boken Ex Manifold Studs Help!
- Price
- How to Clean Lower Intake Plenum
- Check Engine light???
- Check engine light flashing then off?
- 1990 4.9L help
- Does anyone know...
- anybody?
- AC always on...
- found exhaust leak
- Redline water wetter color change
- Best way to get more from the 4.6
- air filter....
- 91 F-150 stalls when hot
- Another stupid question......
- 5.4 Valve clatter! HELP!
- ticking 2000
- Airaid issue
- Stumped!! Bad Misfire Issues
- Single E fan
- 5.4 Cam Options
- Oil Pressure
- '95 w/ 5.8l
- lighting engine
- K&N and Superchips
- 5.4L gas hog
- No Fire!
- rough idle
- In line 6 trouble
- Time to Start the 200,000 mile club
- Never Again...!
- Code P1451-4.6 motor- what next?
- Engine sputters but wont run?
- cylinder heads
- Changing synthetic oil
- sputtering at 50-55mph
- Quick Throttle Body Question
- E-fan question.
- intake manifold
- Special OBD Codes?
- 5.0 Oil Usage
- new heads
- Best blower for 02 F150 2valve 5.4?
- Motor running poor and sounds bad
- WTF!!! Sludge at 37k
- Strange Idle...
- gears
- Can't siphon gas out of truck
- 1988 F-150 Will Not Start
- Synthetic Oil Increase Milage????
- Idler pulley replacement and serpentine belt
- 5.0 Won't Start
- How hard to repair alternator
- Help 85 300 DOHC wanting more power
- where to buy Antifreeze strips to test coolant?
- Failed NYS Inspection
- Acceleration
- Where oh where has my coolent gone?
- Running Poorly
- engine help needed!!
- What Sending Unit????
- New 06 wont start on first try???
- Towing Question
- whitefoam on oil cap
- water damage trans not shifting
- plug replacement price ?
- vote please reply
- dumb ? so shut up
- vomiting spark plugs
- 1990 F150 fuel delivery problem
- 99 5.4 wont start sometimes
- 2004 Coil pak Help
- throttle body tube broke HELP
- Nice Rear End
- Constant misfire!!!!
- 01' SuperCrew Q's
- Does a 2002 4.6L have lifters?
- Walmart Performance upgrades!
- K&N replacement air intake?
- Aftermarket Heads?
- intake and exhaust?? K&N/Volant? Magna/Borla?
- high idle when clutch not engaged
- Changing heads
- Changing heads
- 98 f150 4.6 will not start
- Code Po401
