- Can anyone recommend a good fuel system cleaner?
- '97 F-150 - Rough hot idle - slight miss
- 04 lightning knocks when cold
- Blocked Gas Tank?
- debris around fuel injectors after removal
- Trading in :(
- Coil/plug problems
- Code readers
- fuel injectors ????
- Loss of Power on Acceleration
- New Fuel Press. Reg. and it still won't start
- 00 f150 runs great until warm then has an extreme miss and no power help!!!!!!!
- O2 sensor questions
- Can I buy the fuel injector o-ring only?
- 2005 5.4
- Aftercooler.. intercoolers
- Oil Filter Recommendations
- The saga: #8 misfire...not COP!
- 1998 F150 - Problem Codes - P1538, P1537?
- Need Advice about EEC
- i need some help!
- would this work??
- someone PLEASE!! any ideas before I burn it down!!!
- Antifreze leaking ???
- Unusual Question On 5.4 Spark Plug Issue
- aluminum heater hose fitting leaking
- Filter wrench that works
- Just Bragging
- WOW!! wtf
- UPDATE: JB Welded spark plug
- 92 5.0 V8 running rough low power on hills, code surprise
- Air filters
- 89 4.9 V6 - a bunch of black smoke!!!
- 4.6 idle problem???!!!???
- Question on the new 5.4L Triton's
- Want More Power from 4.6 V8
- Desperate For Help
- Changing connecting rods.
- P0181 - Fuel Temp Sensor, Circuit A
- Rough running
- Super Straight six motors
- Coil problem or DPFE? Any help appreciated.
- Not sure which Time-Sert kit to get
- 2002 Ford F150 - Rough idling - PO302
- Truck Stalls While Ideling!!!!!!
- 1990 F-150 Engines Dies At Highway Speed
- EGR heat riser tube
- 1989 F150 4.9 inline 6 - will not start or run
- 1998 f150 Idling erratically
- truck won't start
- a/c compressor question
- cant stop heating
- 89 Ford F-150 XLT Lariat Alternator issue
- Coolant temp sensor
- This is gonna sound dumb. :P
- Wierd turn off then on.
- Slow to start
- starter solenoid replaceable??
- timing help please
- check engine light does not light up when started
- Low oil... what the deuce?
- tachometer problem
- F150 Intake
- Converting Fuel Injected to Carbureted
- Loud Rattling Noise Under Truck
- 4.6 to 5.4 Big Difference
- compression 93 |6 4.9L
- Need more horsepower from my 300 I6
- Lower Temp Thermostat...
- help?? where is my low side cap to recharge my a/c???
- Misfire on Cylinder 8 help! Recommendations
- !994 F-150 oil pan problem
- Help me revive my 88 f150
- PCV valve question
- Speedometer problem
- One for Norm
- run lean or rich
- Cylinder 8 Misfire
- Vacuum or Fuel Problem????
- Temporary groan at 2k RPM at startup
- 1997, v6-4.2 cyl 2 missing
- I broke my radiator drain plug....
- Not a gasser or F150 man...need advice and help.
- more powerhttp://www.f150online.com/forums/images/smilies/thumbsup.gif
- 95 f150 5.8 sensor location
- engine swap quote
- Pressure relief on passenger side of radiator?
- 4.6 Fuel Pump?
- More questions on plug issue
- 1997 F150 with Check Engine Light On, EGR?
- IMRC and MAF
- Fuel switch maybe?
- Body removal for engine change
- Replacing Gas Tank on Dual Tank F-150
- Just got my F-150..thought I had tranny probs
- help with a/c
- No oil getting to head?
- What brand of belt is best?
- A/c Help!!!!
- I need help please....
- Can a bad injector cause a misfire code?
- Fuel tank float
- Lessons Learned for the Electric Fan Kit from Troyer
- 1998 4.6 what weight oil?
- 4.6 triton
- plug replacement
- Engine Swap?
- mass airflow sensor swap
- Misfire 4.6l #3 and#4
- My f150 problem
- 2003 F150 Questions
- Ford oxygen sensors - NTK not Bosch
- Buzzing sound
- how to clean up cyl 4 coolant
- air intake out of a 96 explorer
- Mixed oil...do over?
- 1990 F150 with dual-tank problems
- occasional carbon blow out at startup
- Spark Plug Part Number
- 4.2 still running strong
- SuperCrew Hybrid with Towing Capability
- Fuel Smell: 4 Service Appointments to fix it
- Cam Position Sensor/Syncronizer
- Possible head gasket leak?
- 1995 4.9 drivability problems
- 89 F-150 Will Not Start
- Need help checking the PCM
- Weird "Buck" when idleing
- '89 F150 Help! POP then no start or electricity
- E85 in 2005 F150
- High idle with AC on
- egr code
- Cylinder 3 misfire 4.6L engine
- Performance Heads or PI Heads
- P1405 engine code
- Ignition ?
- aftermarket coils vs. chip and/or?
- 2002 F150 is jumpy at idle, new-b needs info! and help!
- Where is the engine id tag (mid 70s 390)
- 01 4.6L engine seized. will 05 fit???
- PCV Valve
- Engine Swaps
- New Owner 94 5.0 4x4 Needing advice on parts and how to's
- 2006 5.4L Intake System
- 2002 Mountaineer (Explorer) 4.6 NO START won't even try
- Throttle Issue
- Cps
- First Time Towing With 97 4.6
- Cold oil Change?
- serious ilde help?
- Studdering" Problem at constant speed, Need ideas on fix Please
- miss firing problems
- 4.9l Inline 6 spark plug problem
- 1998 5.4 F-150 Spark Plug Locations
- Edge Evo over the XCT2?
- Need advise on an engine that overheated-should I get rid of it?
- pinging on the 3v 5.4
- Misfire in 5.0
- 4.6 triton
- 4.9 L engine
- egr puzzle
- need help, 91 ford f-150 ext cab engine dies in gear
- 01 5.4 slow off the line.
- 00 f150 colum swap out, PATS problem, fuel pump problem
- Engine will not start unless accelerator is pushed down!
- Do I need a new engine???
- Diesel F150???
- Burning Smell and Loud Noise
- Have I damaged my engine????
- 5.4 w/ misfire
- Remanufactured engines
- 2000 f150 4.6 runnig bad help!!!
- Stalling in 3rd and 4th!!
- No heat from the heater
- Injector coils on Ebay
- :confused: 1997 Ford F-150 4.6L (Blown head gasket)
- got the ac to work
- change ac clutch ac still wont work
- What are the HP and ft/lbs numbers for a '97 4.6L
- Dealership Oil Change Question
- Location of PCV valve in 92 5.0 V8 model
- Stuck lifter or noisy tappet?
- 97 4.6 acting up
- Intermittent death when warm
- 1988 idle problem
- need compression on a 1988 lariat xlt
- Its Alive!!!
- Does anyone have any experience with nitrous oxide on an F150 (4.6L)
- Won't start. Insrt pnl no power. Anti theft?
- Removing oil pan in '92 F-150 5.0 V8
- dead 4.6
- Tune up?
- k&n oil filter
- More "excessive EGR flow" problems
- Leaky Oil Filter-Why???
- changing idle speed
- Quick: I need help tonight.
- put the 97 150 on road today
- Gasoline in engine oil?
- 04' SuperCrew 5.4 Blowing Oil
- Upgrading injectors, which to get and what to do?
- "tornado"
- Fuel Problem?
- '94 6cyl 5spd MPG
- Throttle position sensor.
- 2001 SuperCrew 4.6 Smoking on Start Up
- Additional info on my A/C problem
- I want more torque
- Fluid Leak under truck
- 1999 5.4 sounds like a diesel
- Throttle body problem?
- Asking if it is worth it????
- Thank you to all....
- A/C problems:'(
- 5.4 3V EFI vs. 5.4 3V EFI FFV engine
- Oil Filter stuck, so I left the old one on it?
- Oil problems...Help?
- Fuel Additives
- 4.6 to 5.4?
- Check engine light
- Stumped by vibration
- Access port for fuel pressure guage and NOS HELP!!!
- Dyno
- Spark Plug Question
- E-fan??????
- Geezzz, Now mine won't start..
- Engine Chirp - Spark Plugs??
- 5.4 Flex Fuel Motor
- Won't Start...help!!!!!
- ???Condensator???
- Misfire/backfire on heavy acceleration
- help with fuel problem please
- Hypertech Power Programmer III & The Jet
- Pulling Codes
- Cold air, Spacer, and exhaust
- Need advise on bigger engines for 1998 F-150
- Amazing
- fully functional ram air hood and the rouschcharger
- E85
- Po232 Code
- Ford Lightning SVT 5.4 litre motor /Engine
- Engine Suddenly Shuts OFF!!!!
- Synthetic oil
- Need Help
- Humming Noise
- Building a 4.6 ????
- PO133 and P1131 - Double checking after searching
- ignition woes solved!!!
- ac wont work
