View Full Version : Engine
  1. cams
  2. Fuel Pump Question?
  3. engine swap
  4. tranny and motor problems
  5. White residue on exhaust tip???
  6. 4.6 timing chain tensior questions?
  7. trouble code p1aee and p1000
  8. Intermittent Noise during acceleration
  9. Fuel pump circuit high?
  10. Power Steering Pump
  11. She just seems tired, where should I start?
  12. 1998 4.6 wanting to stall when comming to stop
  13. Misfire on cylinder 5 code: which one is cylinder 5?
  14. Which sensor is it? Off of the EGR valve.
  15. 2002 f150 fuel filter...
  16. Disturbing sound, what is it?
  17. 99 f250 v10 motor swap
  18. Need Help; Low RPM Stumble
  19. Another stinking Fuel Filter + air in the fuel line thread....
  20. Burning oil
  21. Oil Temp Gauge
  22. Won't Start When Hot,please Help!
  23. out of the blue
  24. P0401
  25. Ignition Problem, and the fixes. Learned alot.
  26. More Horses
  27. 1989 F150 300 6 Bucking and Jerking help!!!
  28. knocking of 2004 f150 fx4 super crew!
  29. Gasy smell
  30. Plugs and wires
  31. F-150 Woes
  32. Good ideas for where to get MSD Wires somewhat cheap
  33. Will your 5.4L Expedition spin the rear wheels?
  34. 7.3 Diesel Block
  35. cracked engine block
  36. Perma Cool Electric Fans
  37. Oil leak PLEASE HELP
  38. Mileage Question
  39. cheap upgrades or tricks for 97 4.6w
  40. rough idle
  41. 4.6 swap for a 5.4
  42. Belt change after 15000 miles?
  43. Lower Chamber delete idea...
  44. Hesitation at high RPM
  45. hesitation is it trans or eng
  46. Question that cant be answered!!! Piston rings!
  47. Loud Fan
  48. 2006 4.6L Idle RPM
  49. Stuck in the slow lane
  50. $4000
  51. Remote Oil Filter [again]
  52. Plug wires
  53. Overheating??? Any Sugestions!!!
  54. svt eaton on a non-sc 5.4
  55. 4.6 horse power
  56. Codes question
  57. What engine is better?
  58. Engine Swap
  59. 1999 f150 4.2 liter wont start
  60. Help! EGR Problems
  61. 1997 5.4 Coil replacement
  62. 5.4L engines
  63. Who's in the 200,000 Mile Club?
  64. is there a set of "BOLT IN HEADERS" and would they make a significant diffrence?
  65. timing chair
  66. IAC Cleaning/Maff sensor other fun stuff
  67. Aluminum Block Probs
  68. Synth Oil Change Interval???
  69. Sercive Engine light on
  70. ? about maff
  71. Windsor Swap Details
  72. 5.4 Spark Plugs Coils replacement
  73. 4.6 Rebuild
  74. toping out a 5.4 in a f 150
  75. 99 f 150 1/4 time
  76. 5.4 Driving RPM
  77. video clip...
  78. ok i bought my new 4.6 what do you think?
  79. overheating
  80. Spark Plugs?
  81. some failure on my 5.4, need some help!!
  82. My BAD Timesert job! Pics.
  83. custom grind cams
  84. 4.9 L oil leak
  85. 4.6 brocken exhaust manifold studs ?
  86. wont't start
  87. help
  88. 2 questions.....
  89. 2 questions.....
  90. 5.4L VS 6.8L Fuel Economy
  91. Where is the RPM Yellow/Red Line ??
  92. getting my first f150, 1993 5.0
  93. rrrrreeeaaalllyyy
  94. vents moving to defrost
  95. Nastyness!!!!
  96. Grrrrrr!
  97. How hot does the EGR tube get?
  98. New Windsor
  99. New Windsor
  100. EEC-IV or EEC-V PCM?
  101. E-fan warning and advice....
  102. No A/c On Cold Start
  103. Power Steering
  104. Engine cooling and oil filter relocation questions
  105. 4.6 L vs 5.4 L - Gas Mileage and Power
  106. '03 A/C problems
  107. Trouble removing A/C Compressor
  108. Injector cleaining worth it?
  109. POP goes the weasel
  110. 1981 ford f-150 belt diagram
  111. Engine shudder, vibration help.
  112. Flushing Radiator Question??
  113. underdrive pullies
  114. 94 5.8L Question??
  115. Don't Clean That Throttle Body!!!!
  116. Need EGR help!
  117. Return of the pinging!
  118. Engine Shutters in the morning.
  119. cam phasers
  120. New plug wires make a difference?
  121. Marbles in the engine???
  122. 351 needs more power!
  123. a/c problems
  124. battery light
  125. Please Help
  126. pi or not to pi
  127. Rough running 302...
  128. To Torque Or Not To Torque ?
  129. Iner fender rust
  130. Been Awhile
  131. No Power to Air Conditioner Clutch
  132. +5 Mpg F150 4.6l
  133. Long road trip. Gas mileage tips?
  134. Shudder in OD
  135. Does this make sense (lack of power steering)
  136. Oh Yes, One Day!
  137. Mustang
  138. 95 5.0 rebuild delemas
  139. excellent article on fuel, aerodynamics etc.
  140. 92 f150 cooling question
  141. Can someone explain this to me?
  142. Cam Questions
  143. Starter problems - 2000 F150 4x4 4.6
  144. how about a 99 4.6 will it be a direct replacment for a 2002 4.6
  145. Loss of Power/Acceleration Uphill
  146. 1997 f-150 overheating
  147. F250 Clicking w/low oil pressure
  148. 300ci easy power gains
  149. VCTcontroller rough running
  150. 2004 5.4 with strange "whoooo" noise
  151. fuel problem i think
  152. how much for a remanufatured 4.6?
  153. need help to pick up a right one
  154. Intermitent engine skip
  155. Synthetic oil question
  156. Need 4.6 to 5.4 interchangability for my 1994 F150 swap!
  157. wos running a supercharger on thier 04+ f150?
  158. I-6 300ci randomly goes nuts
  159. clueless about low bass sound when stopped
  160. Do I need new Wires?
  161. 2002 4.6L Tuneup
  162. Ignition coils/spark plugs
  163. 2004 5.4L 3Valve swap into a 98 4x4 f150 4.6L?????????
  164. Fuel Tank Trouble ?
  165. Shakes/Runs rough on cold start
  166. indy coil code question
  167. Running Hot
  168. 1999 F150 horrible MPG problem
  169. Bosch Platinum Question
  170. 5.4 Liter Schematic
  171. Tune-up
  172. Stoopid English man needs help!
  173. 98 f150 281 cu in
  174. dead obd port
  175. Throttle body fitment issues
  176. Newbie here guys needing some help
  177. Injector issues
  178. New turbo whistle = vaccum leak?
  179. intake
  180. Self Engine Wash
  181. Performance question..........
  182. Need a new intake/Whick K&N submodel-need to make decision ASAP
  183. ac question/problem
  184. Egr
  185. Thinking about trading in my F150
  186. Bosch Spark Plug: Platinum+4
  187. zeeroboy
  188. '93 5.8L Driveability Problems
  189. Edge Revolution ?
  190. 95 F150 Fuel Filter
  191. Intake Air Temperature
  192. 02 5.4 Idle issue
  193. Whats the best way?
  194. injector cleaner causing rough idle?
  195. 2006 Ford F150 5.4L AEM Intake System R&D
  196. Help with Code P1406
  197. Reccomendations
  198. Aluminum Block?
  199. need timing help on my 98 4.6L........chain questions!!!!
  200. '97 4.6 to '97 Triton 5.4 swap??
  201. Newbie needs help with startup
  202. 5.4L swap into a 98 f150 with a 4.6 questions
  203. how much for a long or short block from ford for my 98 f150?
  204. 2000 F150 ign. coil 30A fuse blown
  205. Really need some help here guys
  206. check engine light
  207. Thermostat Help
  208. Thoughts on Engine Cleaning
  209. Denso Iridium Lifespan?
  210. Why is my 4.6 pinging and eating spark plugs??
  211. knocking and smoke. help
  212. z max users
  213. Misfire on 4.6L without COP
  214. 80-86 Performance Radiators?
  215. Replaced the 5.4
  216. 5.4 IAC Location?
  217. Codes P0411 and P0420
  218. 1989?? F-150 Engine ID??
  219. California Gasoline - what to add to it?
  220. F150 idle hesitation out of nowhere
  221. 2001 Ford F150 Idles and Kills
  222. Flex Fuel Engines?
  223. Getting code 1309
  224. Part on Back of Manifold Buzzing
  225. running hot!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  226. more code problems
  227. What to do 5.4 or 4.6?
  228. Overdrive
  229. 302 timing set
  230. Cleaned MAF, IAC & Throttle Body with Mixed Results
  231. F150 Interstate Accident
  232. Cool Oil Change Accessory....
  233. 89 f150 5.0 dies and wont restart
  234. 95 f150 idle problems
  235. 88 f250 wont start
  236. Should F150 move in DRIVE w/o gas pedal pushed?
  237. Runs better in high heat?
  238. Deep Oil Pan?
  239. Alternator Question
  240. Sparg plug blowout common on 5.4?
  241. body lift fuel economy?
  242. Help please! Fuel bank 1 too lean???
  243. Need Help!
  244. Maf Sensor Fix
  245. 351w diagnostic help please
  246. lean system
  247. 02 sensor replacement
  248. 87 F-150 no fuel?
  249. Unknown Trouble Codes!!!!
  250. P0401 Code..
