- AF1 install probs. on 03 Exp 4.6L - need pics
- Oil level too high?
- blue smoke after idling then acceleration
- Iacv
- O2 Sensor Fun
- Rough idle and missing
- engine build
- engine swap
- Throttle body
- '05 Lariat 5.4 Engine Knock - Warranty Item?
- Gas in Central Florida
- Wierd coolant leak
- 1995 F150 Fuel Pump Issues
- 92 F150 Looping Idle
- Amsoil
- F150 and Displacement on Demand?
- Water leaking into engine compartment?
- GM to introduce Light Duty Diesel
- how high will it go?
- New hoses.... when?
- add-on Magnet oil filters
- 5.4L V8 (1999) tapping sound
- Oxygen Sensor & Rich Code
- 5.4 swap advice
- For synthetic oil, Fram or K&N oil filter?
- Alternator endurance
- 4.6 supercharger
- distributor and rotor keep burning out
- locate oil pressure sensor 97 4.6l
- Engine flushing
- Not trying to beat a dead horse, but....
- Finally Using the FFV/E85 (2006 SCREW)
- Rattling under Acceleration (Piston Slap)
- first oil change WHEN??????
- spark knock
- Tc P0402
- Spark knock?
- Engine suddenly seized
- 4.6L Heads?
- Spark Plugs
- Motor Swap from 4.9L 6 to 5.8L or a 7.5L in 91 F150
- Antifreeze
- Help! Engine Wont Stay Running
- Prestone doesn’t meet 2001 Ford spec
- Diesel in an F150??
- Alternator Problem, please help!
- Tornado experiences...anybody?
- oil pressure gauge
- coil on plug question
- New Cats
- Misfire Cure
- Starting Issues
- Engine Cranks Real Slow And Wont Start When Hot
- 98 4.6l
- what the heck could this be???
- 2002 4.2L plugs
- Synthetic Motor Oil
- bosch platinum
- Injector Cleaner
- Backfire?
- Lingering problems, maintenance questions
- sparkplug heck
- cleaning a EGR
- Fuel small after hard acceleration
- Throttle Response
- 4.6 Heads / exhaust mainifold probs
- Roush, Steeda, and Saleen
- Schrader valve
- Specific Plug Recommendations?
- Flooding???? Horrible mpg
- 4.6 vs 5.4
- More cranks before starting...
- 300 6cyl Fuel injection problems????
- Spark Plug Spit Outs
- Pin hole in head
- should I change plugs now...while I'm in there?
- Dealer Sold with Orange Coolant - Manual says Green Coolant Only - Will This Hurt It?
- $10,000.00 Upgrade
- Sea foam
- '93 4.9L I-6 with a knock
- Down on Power
- ODBII software
- what size injectors are in my 85 F-150? they have yellow tops.
- ABS Light on, can't put in gear
- upgrades
- f150 v8 conversion
- K7N filter
- 93 f150 fuel filter
- 4.6L crown vic motor vs a 4.6L f150 motor????
- A/C Problem
- need help
- Truck dies after a few miles
- anyone tried this throttle body replacement?
- EGR Valve
- Coolant temperature gauge
- Code problem missfire P0171/P0330 Need Help
- need your help fast!!!!!!
- intake swap
- Gas milage!?!?! HELP!!!
- Swapping a SOHC 4.6L for a DOHC 4.6L
- V6 misses trouble code...
- Intermittent stalling on 2000 F-150 4WD w/5.4
- Straight six fuel rail
- Oil Questions
- Fram Boost Air Intake
- 1990 F150 5.0 TPS errors HELP!
- O2 Sensors
- 2008 6.2l
- 4.2 missing
- general info question - what is the torque converter?
- Hate my clutch fan.
- Motor is sluggish again....HELP!!!
- coil packs
- No Start / Hard Start
- kenne bell supercharger belt routing
- 98 4.6 L missing/sputtering @ high rpm
- 2000 F150 4x4 4.6 buzz/whine on acceleration
- Remote oil filter leak...help?
- Missing - DTC 556
- broken exhaust studs on my 97 expy
- Truck sputters and dies sometimes
- 2006 F150 with 5.4L, this thing is WEAK
- Sudden stall on 5.4
- major timing issue need advice its a 4.6
- Missing and missing
- does this work????
- What does it mean when the headlights flash, but no "check engine" light.
- F150 300 1987 clutch problems
- Replace Idle Air Control Motor?
- Occasional Blue Smoke on Startup?
- Code P0442....The PCM has detected......
- engine misses
- 06 F-150 Oil Pressure Sensor?
- lightning swap in a 97 v6
- 4.6L Spark Plug Change Question
- cams
- Fuel Pump Question?
- engine swap
- tranny and motor problems
- White residue on exhaust tip???
- 4.6 timing chain tensior questions?
- trouble code p1aee and p1000
- Intermittent Noise during acceleration
- Fuel pump circuit high?
- Power Steering Pump
- She just seems tired, where should I start?
- 1998 4.6 wanting to stall when comming to stop
- Misfire on cylinder 5 code: which one is cylinder 5?
- Which sensor is it? Off of the EGR valve.
- 2002 f150 fuel filter...
- Disturbing sound, what is it?
- 99 f250 v10 motor swap
- Need Help; Low RPM Stumble
- Another stinking Fuel Filter + air in the fuel line thread....
- Burning oil
- Oil Temp Gauge
- Won't Start When Hot,please Help!
- out of the blue
- P0401
- Ignition Problem, and the fixes. Learned alot.
- More Horses
- 1989 F150 300 6 Bucking and Jerking help!!!
- knocking of 2004 f150 fx4 super crew!
- Gasy smell
- Plugs and wires
- F-150 Woes
- Good ideas for where to get MSD Wires somewhat cheap
- Will your 5.4L Expedition spin the rear wheels?
- 7.3 Diesel Block
- cracked engine block
- Perma Cool Electric Fans
- Oil leak PLEASE HELP
- Mileage Question
- cheap upgrades or tricks for 97 4.6w
- rough idle
- 4.6 swap for a 5.4
- Belt change after 15000 miles?
- Lower Chamber delete idea...
- Hesitation at high RPM
- hesitation is it trans or eng
- Question that cant be answered!!! Piston rings!
- Loud Fan
- 2006 4.6L Idle RPM
- Stuck in the slow lane
- $4000
- Remote Oil Filter [again]
- Plug wires
- Overheating??? Any Sugestions!!!
- svt eaton on a non-sc 5.4
- 4.6 horse power
- Codes question
- What engine is better?
- Engine Swap
- 1999 f150 4.2 liter wont start
- Help! EGR Problems
- 1997 5.4 Coil replacement
- 5.4L engines
- Who's in the 200,000 Mile Club?
- is there a set of "BOLT IN HEADERS" and would they make a significant diffrence?
- timing chair
- IAC Cleaning/Maff sensor other fun stuff
- Aluminum Block Probs
- Synth Oil Change Interval???
- Sercive Engine light on
- ? about maff
- Windsor Swap Details
- 5.4 Spark Plugs Coils replacement
- 4.6 Rebuild
- toping out a 5.4 in a f 150
- 99 f 150 1/4 time
- 5.4 Driving RPM
- video clip...
- ok i bought my new 4.6 what do you think?
- overheating
- Spark Plugs?
- some failure on my 5.4, need some help!!
- My BAD Timesert job! Pics.
- custom grind cams
- 4.9 L oil leak
- 4.6 brocken exhaust manifold studs ?
- wont't start
- help
- 2 questions.....
- 2 questions.....
- 5.4L VS 6.8L Fuel Economy
- Where is the RPM Yellow/Red Line ??
- getting my first f150, 1993 5.0
- rrrrreeeaaalllyyy
- vents moving to defrost
- Nastyness!!!!
- Grrrrrr!
- How hot does the EGR tube get?
- New Windsor
- New Windsor
- EEC-IV or EEC-V PCM?
- E-fan warning and advice....
- No A/c On Cold Start
- Power Steering
- Engine cooling and oil filter relocation questions
- 4.6 L vs 5.4 L - Gas Mileage and Power
- '03 A/C problems
- Trouble removing A/C Compressor
- Injector cleaining worth it?
- POP goes the weasel
- 1981 ford f-150 belt diagram
- Engine shudder, vibration help.
- Flushing Radiator Question??
- underdrive pullies
- 94 5.8L Question??
