- 4.6 to 5.4 engine swap
- 93 f150 5.0 O2 code first time user
- Engine coolant
- need some opions on a motor install price!
- 92 to95 5.0 engine swap
- Help! Motor stalls when I hit accelerator???
- I'm contemplating a wicked idea.
- Injector Cleaners/Fuel Additives
- upgrading to 302??
- 1994 F-150 6 engine
- Head gasket??
- 2002 4.6L V8: no noticeable problems but 12MPG hwy?
- premium fuel
- 8 ribs
- COP problems
- troyer e fan install
- How to clean your MAF
- timing
- cam
- 5.8 Liter "OVERHEATING"
- 93 5.0 F150 Recommended plugs
- more power out of a 2003 5.4?
- Wierd Idle/Engine Quits...plz help!
- Taking a 5k mile trip
- 3-way blue and white vacuum valve go?
- Engine Missing
- Engine swap
- 4.6L V8 No power??
- cylinder head torque specs?
- won't start
- no heat
- Truck like shaking Please help
- Testing ignition coils
- New truck owner--few questions
- Higher amp alternator ?
- Misfire - COP's Deal -
- Bars head gasket repair?????
- Why can't I do this
- Battery
- water dripping off shield by tranny pan
- NEED HELP!! on check engine light PLEASE!!
- who makes e fans for 03 Exp, 4.6l?
- I need your opinion!!!
- Rough running 4.6 litre?
- 02 Belt Tensioner
- do i have a normal truck
- Replaced EGR valve and sensor...
- Did Seafoam cause this?
- 171 and 174, then 172 and 175
- 4.6 or 5.4
- traded in the 97 150
- high mileage
- Another mystery rattle
- P0171 & P0174 Codes
- Antifreeze for '03
- Sounds like it's outa time
- 5.4L Great clouds of smoke
- 87 pick up won't start
- Wrong Plugs!
- Battery light on...
- 99 aftemarket tach hook up...
- 4.6 running poorly, please help
- Urgent- 97 F250ld
- 03 F150 Supercrew 5.4 engine is psycho!!
- Brakes and oil useage
- 5.4 Piston Slap?
- Knocking
- some thing when't bad
- blown engine
- dyno sheet on a stock 4.6l
- Bright Red Headers!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Engine clicking?
- engine problem
- P0308 Cylinder 8 Misfire Detected
- Accel Ignition Coils??
- Fuel Filter Trouble
- A question for someone mechanically minded.
- 5.4 Coil Packs Again
- Valve pinging 97 4.6
- Start-up RPM's
- engine acting up!
- Anybody cleaned their injectors like this?
- Rant, and hoping for oil change tips
- What size exhaust manifold studs??
- ABS light on
- STUMPED!! How can I figure this out?
- Blinking Check Engine Light on 98 5.4L
- K&N Oil Filter...are the threads week on there?
- need help!!Just replaced my EGR...
- Code 402 excessive EGR flow?
- O2 Sensor Maybe????????
- Anyone use Patriot Performance?
- Good Set up
- Help with by-pass water pump line
- Knock sensor
- Timing Advance Mystery....
- How to deal with blowby?
- Skeaking/Squealing then a Check Engine Light
- 97 F150 won't turn over, hazards tick...
- Cranking Problem????????
- Great Crank just wont Fire.
- Engine Swap
- Cr*p Idle, IAC and Seafoam?
- smells like coolant in vents
- My Cam Phaser pains
- I abso-frickin'-loutely hate Bosch plugs
- Upper Intake Manifold Plenum? Please Help!
- 2005 4.6 V.s. 1999 4.6
- Engine Light
- Horsepower of a stock F-150
- runs rough until warmed up?
- 99 F-150 4.6L - Blue smoke on startup
- Can someone tell me which one's the part #
- Help with Service Engine Light (Codes inside)
- 1999 F-150 running issues
- Sparkplugs
- engine "ticking"
- What is the Mile-Ton torque requirements for 2006 5.4 Engine
- Read Only If You Know Your ****!
- I changed the oil and 4 days later....theres a leak around the oil pan area? WTF?
- hello
- Throttle response
- Engine Shakes At 800-900 Rpm
- fuel pressure gauge
- 2006 F-150 5.4L 4X4 Stumble/Stalling
- Engine dies..need help.
- Who all here has pulled their motor and Tranny @ the same time?
- truck started shaking again.
- hey neal
- 97 F-250ld
- Towing cylinder shutdown at 70 mph...
- 5.4 Tapping noise
- Question about Pulling out a 5.4L ?
- Do I need a tune up?
- 1990 F-150 motor swap
- What is piston slap and what dre symptoms
- Best Way to Retire the Old Ford?
- Dual Fuel Pumps
- Airpressure for my tires
- Which Oil
- Help very bad gas mileage
- Fuel Line Size?
- 97 Expedition 5.4 Starts then dies
- 1995 EEC problem -- Diagnosis help request
- 50/50
- Accel Ignition Wires
- Camshafts
- temporary speed governor disable
- oil collection in air box
- near death malfunction
- Lucas Oil
- Mass air flow sensor free mod
- 4.6 power increase
- Oil pressure extreme drop...
- Sudden Oil Consumption
- I have a water pump question
- Base timing for 98 4.6L F-150?
- P0304 Help
- Coolant contamination?
- A success story
- 1993 F150 - won't start
- Thought I had Piston Slap
- Am i measuring this correctly?
- lil bit of smoke when it starts up
- Plug Boot Stuck
- Throttle body spacer question?
- emissions
- 97 f-250LD A/C Problem
- Question about 30K Maintenance
- Thanks To All - Information Invaluable
- COP Troubles
- ford f-150
- Need Accelerator Cable
- Headers on a 351
- 98 F150 V6 Rough Starting
- 5.4 spark plug trouble
- Best Motor Oil?
- DPFE sensor life
- 2000 Expedition 5.4 Temperature Sending Unit
- Code help
- want to put a carburated motor in my 98 f150 and need sugestions
- 2001 5.4 timing chain noise at startup please help
- EGR fault code 401! help!!!
- F-150 mpg problem
- Front cover blues
- 20mpg!
- 06 Fuel rails, what material are they?
- N2o
- Question for you engine guys???
- 04' FX4 had more power than my 06" 4X2 Lariat???
- 98 F150, 5.4 high pitched whistle
- FS: Swapped F-150 Extended Cab Flareside Bed 4x4
- Swap 4.6L engine
- 92 f-150 Synthetic oil or not ???
- Bought a 195 f150.need info
- Horsepower and Axle Questions
- Flow Master
- HELP!!!!!!! fast idle
- High mileage 4.6L
- 1998 4.6 #4 Misfire And Evap Emis Leak Codes
- running rough
- 4.6 pi cams? 4.6 quick hp?
- Surveying for Average Price of 90000 Mile Tune
- 03 heads?
- intake
- 04 4.6L or 07 5.4L
- 99 f-150 5.4 COP swap question
- Acetone in gasoline
- MPG tweeks shift firmness and drag coefficients
- Power Steering Pump Questions...
- How many o2 sensors on 97 f150 xlt v8 4.6L
- Emmissions and Gas Milage
- 96 to 94 5.0 engine swap
- A couple of engine problems
- Gear Shift Indicator out of Alignment
- Cooler Thermostat
- Stupid blown plugs
- Plugs & coilovers changed, now a battery light?
- high milage oil
- Oil smoke
- Air Filters???
- MSD Ign Coil Packs vs OEM Ign Coil Packs
- valve clearance on a 4.6L...Need Help!!!
- rough 1st ten minutes
- a thought about changing plugs
- Exhaust Porting Question
- repair manuals
- troyer e-fans
- engine stalling
- Changed plugs
- EGR problem
- quick question
- Question On Oil Pressure Switch On A 06 5.4L?
- 99 5.4 hickups @ low rmp upper gears
- 2000 4.6 L won't start
- 1990 4.9 tapping at idle
- 02 4.6L misfire
- Help needed: oil pressure gauge pegs out
- New 302 crate - E7 heads?
- Volant CAI PCV hose
- Vibration while stopped in Drive
- starter clicking?
- No more lonely Heads
- forum for Ford Ranger pickups?
- Famous last words. . . .
- 4.6 mustang heads on a 2005 F-150 4.6
- blowby oil in intake, all the sudden?
- Fuel tanks
- Only runs while starter runs
- Oil capacity on 2004 Ford F-150
