- the new 4.6 is in!!!!!!!!!
- 1989 ford f-150 timing and spark plug gap
- Starting Problem? 1999 5.4L
- knocking sound... im lost
- 97 4.2 power steering out. Doesnt seem to be pump
- Stripped a plug hole today.
- help diagnois my problem on 1986 302 f-150
- 08 F-150 ?
- How to remove oil pressure sender on '97 4.6?
- 2001 hesitation
- 60k stuff
- '02 FX4 "ticks" at startup
- running 97 on my 4.2l v6?
- 2000 F150 4X4 wont crank with key
- Check engine light slight vibration and back fired a few times
- Spark plug replacement
- 97 expy 5.4 Misfire?
- Plug wire length
- cooling
- Cylinder head part # Anyone?
- starter clicking
- Why did my 5.4 engine Hydrolock at 29,000 miles?
- Front tank noise from fuel switch.
- Air Intake
- please help, code reader and maf
- Diagnostic Errors
- 2002 F150 Won't Stay Running
- Insufficient EGR Flow???
- 2000 F-150 Stalls and has irregular idle
- 5.4L sounds like a Train
- 97 f150 starter
- A clicking or rattle sound at low RPMs 05' 5.4 V8
- Gutless!
- MSD spark plug wires
- 03 engine knock
- "Plugged Heat Core?"
- Temperature gauge goes to HIGH TEMP
- Hey Quintin or anyone that wants to kick in.
- F150 newbie.
- Need to buy new fuel pump.
- 2003 Ford F150 Oil Recommendations Please
- 32 Valve 4.6 Swap
- '01 4.6l Lower Manifold Intake Gasket
- 1989 F150 fuel pump relay
- Oil
- gauge pods
- Dual Tanks - Front Fills VERY SLOW
- Motor swap
- Plug and wire location on distrubutors
- code p0401 insufficient flow
- Engine "ticking"
- 04 starting to ping
- sounds like a diesel....
- The "JUICE BOX".
- EGR Tract?
- Code Scanner
- PCV valve location???
- efan install
- ported heads
- Intake Plenum Question
- Finally Some Power!
- efans and stock alternator
- Error Code PO443 - Purge Control Valve
- Frustrated
- Trailing Arms Bent ?
- Girlfriend's G35 is squeeling like no other...
- APP103 or TR55
- Small Hose Leak
- my 4.6 is ticking...please help!
- 5.0L Oil Pressure
- Newbi to forum 5.4 question 01 f150 supercrew
- Navigator Engines
- Check Engine Light & Purge Control Valve??
- What kind of 351 is in a '96 F-150?
- i have a extra 4.6 where would be best to get rid of it and whats it worth?
- Accel Super coils for 02 4.6
- most powerful 5.4L 2V
- Head Gasket replacement, do i have to:
- P0307, P1401 What are they
- Odd idle speeds
- K&n
- Tune Up on a 1997 4.6L?
- Idle problems
- Maf
- Troyer Underdrive Pulleys
- Ford 5.4 f150 just shuts itself down while driving.
- A new ignition problem
- 1988 F150 problem.
- 4.6 Hp?
- Head Gaskets and more... Help?
- 5w20 or 5w30
- help?? engine dies when warm
- Fitch Fuel Catalyst?
- Harmonic Balancer Bolt
- Ignition(Coil pack)
- 5.4l
- starter problems
- L Pistons
- nasty engine vibrations at speed?
- Hard to start
- Code 23 and Code 63
- codereader for rough idle?
- granatelli ignition coils
- need help locating 5.4
- P0453 OBDII Error Code - Where is this sensor?
- Fuel Pump???????HELP!!!
- Check engine light-Codes PO455and PO457?
- '03-'04 Cobra Powertrain Swap
- Simple Green
- e-fan recommendations?
- Misfire. HELP! Pulling my hair out.
- Self Test Plugs
- best motors
- Fule line
- Dpfe Sensor
- Problem with 1998 Ford F-150 w/ 4.6L V8!!
- 5.0 swap into 06 4.2l f150
- A little worried
- engine knocking
- f150 vs. ss
- Mustang parts
- My 07
- OBDII emissions testing
- 90 f150
- check engine
- Superchips
- DTC - code PO175
- 5.0 f-150 upgrades
- 4.6 Plug Wires
- 2 cats gone
- 98 Expedition Help.
- What is this hose?
- Annoying Resonance @ 2k RPM
- Engine Running 50/50
- EGR Valve Replacement Help
- 4.6 to 5.4 engine swap
- 93 f150 5.0 O2 code first time user
- Engine coolant
- need some opions on a motor install price!
- 92 to95 5.0 engine swap
- Help! Motor stalls when I hit accelerator???
- I'm contemplating a wicked idea.
- Injector Cleaners/Fuel Additives
- upgrading to 302??
- 1994 F-150 6 engine
- Head gasket??
- 2002 4.6L V8: no noticeable problems but 12MPG hwy?
- premium fuel
- 8 ribs
- COP problems
- troyer e fan install
- How to clean your MAF
- timing
- cam
- 5.8 Liter "OVERHEATING"
- 93 5.0 F150 Recommended plugs
- more power out of a 2003 5.4?
- Wierd Idle/Engine Quits...plz help!
- Taking a 5k mile trip
- 3-way blue and white vacuum valve go?
- Engine Missing
- Engine swap
- 4.6L V8 No power??
- cylinder head torque specs?
- won't start
- no heat
- Truck like shaking Please help
- Testing ignition coils
- New truck owner--few questions
- Higher amp alternator ?
- Misfire - COP's Deal -
- Bars head gasket repair?????
- Why can't I do this
- Battery
- water dripping off shield by tranny pan
- NEED HELP!! on check engine light PLEASE!!
- who makes e fans for 03 Exp, 4.6l?
- I need your opinion!!!
- Rough running 4.6 litre?
- 02 Belt Tensioner
- do i have a normal truck
- Replaced EGR valve and sensor...
- Did Seafoam cause this?
- 171 and 174, then 172 and 175
- 4.6 or 5.4
- traded in the 97 150
- high mileage
- Another mystery rattle
- P0171 & P0174 Codes
- Antifreeze for '03
- Sounds like it's outa time
- 5.4L Great clouds of smoke
- 87 pick up won't start
- Wrong Plugs!
- Battery light on...
- 99 aftemarket tach hook up...
- 4.6 running poorly, please help
- Urgent- 97 F250ld
- 03 F150 Supercrew 5.4 engine is psycho!!
- Brakes and oil useage
- 5.4 Piston Slap?
- Knocking
- some thing when't bad
- blown engine
- dyno sheet on a stock 4.6l
- Bright Red Headers!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Engine clicking?
- engine problem
- P0308 Cylinder 8 Misfire Detected
- Accel Ignition Coils??
- Fuel Filter Trouble
- A question for someone mechanically minded.
- 5.4 Coil Packs Again
- Valve pinging 97 4.6
- Start-up RPM's
- engine acting up!
- Anybody cleaned their injectors like this?
- Rant, and hoping for oil change tips
- What size exhaust manifold studs??
- ABS light on
- STUMPED!! How can I figure this out?
- Blinking Check Engine Light on 98 5.4L
- K&N Oil Filter...are the threads week on there?
- need help!!Just replaced my EGR...
- Code 402 excessive EGR flow?
- O2 Sensor Maybe????????
- Anyone use Patriot Performance?
- Good Set up
- Help with by-pass water pump line
- Knock sensor
- Timing Advance Mystery....
- How to deal with blowby?
- Skeaking/Squealing then a Check Engine Light
- 97 F150 won't turn over, hazards tick...
- Cranking Problem????????
- Great Crank just wont Fire.
- Engine Swap
- Cr*p Idle, IAC and Seafoam?
- smells like coolant in vents
- My Cam Phaser pains
- I abso-frickin'-loutely hate Bosch plugs
- Upper Intake Manifold Plenum? Please Help!
- 2005 4.6 V.s. 1999 4.6
- Engine Light
- Horsepower of a stock F-150
- runs rough until warmed up?
- 99 F-150 4.6L - Blue smoke on startup
- Can someone tell me which one's the part #
- Help with Service Engine Light (Codes inside)
