View Full Version : Engine
  1. Putting motor back together !
  2. air/fuel ratio help
  3. Need Injectors?
  4. Looking at HP/MPG from a different angle?
  5. Location of PCV and valve cover filter, 4.9L
  6. 1997 4.6 R7R time?
  7. ford dodge nissan
  8. Engine surge??
  9. Mass Air Flow Sensor
  10. Underdrive Pulleys
  11. 1998 f150 4.6 swap
  12. high pressure in gas tank
  13. Seafoam - how to use?
  14. check engine light
  15. 1989 302
  16. Is my battery dying or is it the alternator?
  17. 4.6 HP upgrades/mods
  18. 4 wheel drive engaging NOT
  19. New member with misfires
  20. Complete drivetrain swap? What would you do?
  21. Tune up
  22. ticking after replacing plugs
  23. What can I do to prevent the plugs from shooting out?
  24. 1993 F-150 coolant loss...
  25. f-150 Shop Manual
  26. 4.6 stuttering, about to give up
  27. Misfire #4 cylinder
  28. big oil leak?
  29. can i clean my k&n air filter
  30. Whistling at 1300-1400 RPM
  31. I-6 in my 1995 f150
  32. Engine noise after oil change
  33. Popped spark plugs on high miler...
  34. 4.6L check engine light flashing and steady
  35. What does the Intake Manifold Tuning Valve Do ..... Do I need it?
  36. New 5.4L break-in period
  37. Problem with 04 Screw 4.6 ??????????
  38. Question about mods
  39. I think I'm getting screwed in gas....
  40. wet injector runnin lean?
  41. Cam Phaser Q's
  42. Question about Engine Flushing
  43. How much to rebuild
  44. Performance Programmer
  45. How many miles do you have on a 5.4L.
  46. Engine Swap
  47. 4.6 to a 5.4 lightning swap questions
  48. Engine Bay Cover missing
  49. 4.2L to 5.0L?
  50. Weird humming noise?
  51. problems after rebuild
  52. VCT sensor oil leak
  53. 98 Expedition OBD port.
  54. Engine wines at freeway speeds..
  55. help me fix it
  56. Engine tapping after low oil pressure.
  57. Coolant Change
  58. Fuel Filter WTF?!
  59. Looking for something, but dont know what it is.
  60. Fuel pressure regulator - Injector pulse problem
  61. How many miles do you have on you 4.6?
  62. BBK 75mm Throttle Body
  63. P0171 & P0174 Codes/Engine runs smoothly
  64. 5.4 supercharger for a 4.6
  65. 4.6 to 5.4 swap
  66. Engine won't start after shutoff!
  67. Engines and mpg
  68. Engine Tick????
  69. Gas mileage issues
  70. Gas mileage issues
  71. 04 FX4 erratic throttle
  72. 03 supercrew 4.6 won't start
  73. If you were me...
  74. white film on oil cap
  75. 1998 4.6L Misfire #4 cylinder Help
  76. 5.4 Lightning Firing pattern?
  77. can you help me?
  78. Spark plug lock washer Ford installed?
  79. f 150 -250
  80. new 6.4L ?????
  81. 04 5.4 Rough Idle / Stalling
  82. weird mising....
  83. P0308
  84. Need Help with 1997 5.4 engine
  85. $150 shipped cop's good or no?
  86. Another misfire question
  87. Engine Power Loss (?)
  88. storage questions
  89. storing a motor
  90. 0420 Code Question
  91. Whistling F-150 SuperCrew
  92. 4.6 to 5.4 swap problems
  93. Is Motorcraft Synthetic Blend 5-20 good for first oil change?
  94. Help
  95. Engine is showing its Ford traits
  96. 1997 5.4 Will Not Start
  97. trying to figure motor hp / torque estimate
  98. cold start noises??
  99. Engine revving High
  100. 4.2 V6 Missfire??????
  101. F150 5.4 Running 'off'
  102. O2 Blues...
  103. What Size Belt???
  104. 91 f-150 rough idle
  105. 97 F150 5.4
  106. HEaders, Exhaust, Intake, etc, etc, etc
  107. 4.6 RPM Range
  108. 5.4 to 4.6 conversion
  109. Engine Whirring on front passenger side. Injector?
  110. What changes need to be made...
  111. 1994 F-150 4.9l
  112. lean on bank2 question
  113. RPM's
  114. Modular
  115. Question about chips
  116. Missfire question
  117. Whats this harness for???
  118. Is 4.6L Superior to 5.4L
  119. PVC Replacement
  120. Chronic cooling system problems
  121. 5.4 vs 5.3
  122. Pi Heads?
  123. Replacing injectors and head gasket on 3V 5.4 04-06???
  124. my intermittent misfire
  125. Non-smoker accepting trades..
  126. First ford
  127. Hissing noise
  128. 5.0 fuel has me troubled and stumped
  129. Anyone need COP'S?
  130. 1999 5.4L Won't start - no injector pulse
  131. Where to find...
  132. Built 5.0
  133. 96 F150 fuel problem
  134. oil weight
  135. Drivebelt whistle
  136. Low Coolant - No Heat?
  137. FlyWheel Rubbing
  138. new engine
  139. Starts up then dies... 4.0 Exploder
  140. 4.6l engine removal
  141. noisy cold start -up
  142. failsafe mode helppp
  143. 2002 won't start
  144. Bigger engines last longer?
  145. Electrical short
  146. E S P price
  147. 4:10 gears or Line-X Whole Truck With My Tax Return?
  148. No oil pressure when cold
  149. Coil on plug install??
  150. Misfire at cylinder #2 code
  151. Seafoam
  152. 4.6 Lifters Rattle
  153. Strange Start Up - Gauages all the way over and back
  154. SLP CAI anyone using?
  155. 6.8L V10 sepcs?
  156. Humming/Harmonic noise comes in @40mph and out @45mph?
  157. Advice please.........slight shudder
  158. Just a little help!!For my HD150
  159. Need help with repairs and obd codes
  160. oil light comes on and pressure drops
  161. E- Fans
  162. Why Buy?
  163. Misfire when it rains??
  164. 1990 4.9L no start after run out of gas
  165. how do I change my 03 Exp o2 sensor?
  166. Its actualy cylinder 7
  167. 2001 F150 5.4 antifreeze around #6 cylinder
  168. Melted My Vacuum lines
  169. What should I be aware of?
  170. Is It Possible?
  171. 5.4 misfire
  172. E-fan controller?
  173. Engine surging intermittently after cleaning.
  174. 6.8 liter in f150?
  175. Where is cylinder #2 on my 4.6L, please???
  176. Glove com
  177. Antifreeze getting around coil number 6
  178. Engine Knocking
  179. Oil pan gasket leak
  180. F150 4.6L starter has me stumpt?
  181. Air Intake
  182. looking to get around 350-400hp
  183. New intake manifold!!
  184. 5.4L service engine light on
  185. 5/20 vs 5/30 oil consumption
  186. Where is A/C accumulator on 2000 F150 4.6L?
  187. 1999 F-150 overdrive light
  188. 5.4 Liter......Regular or Flex Fuel
  189. 4.6 tune up
  190. Fuel Pump Noise
  191. Low compression on two cylinders
  192. Oil Pressure gauge going crazy!
  193. After Headers Problems
  194. 2004 F-150 5.4 Kicking when accelerating!
  195. EGR positioning sensor HELP GOING CRAZY HERE
  196. 4.6 engine replacement
  197. 4.6 problem
  198. water sound in dash
  199. 5.0 Running Too Rich
  200. new process to reduce friction in engine parts
  201. bad gas or cop??
  202. Automatic Start
  203. Help Replacing My Belt Tensioner Pulley F-150
  204. Dealer Oil Changes
  205. engine lunge/surging at constant speeds?
  206. Ford’s short threaded spark plugs – Beware!
  207. 96 4.9L I6 rich and misfire in No.5
  208. Turning on 4x4
  209. 1989 F150 5.0L suddenly running rough
  210. new user!
  211. Smoke underhood when shut off?
  212. Where do these Vacuum lines go?
  213. plugs/wires question on '97 4.6
  214. 98 F150 4.6 misfiring badly
  215. 97 5.4l Crackling noise at startup
  216. Weird Idle Problem?! VIDEO
  217. Engine Specifications
  218. Spark Plugs????
  219. 2005, 5.4(3-Valve)Catastrophic ENGINE FAILURE
  220. 5.4 2 core radiator??
  221. 1998 f-150 5.4
  222. 2001 F150SCREW #2 misfire
  223. Replacing Ford F-150 Engine Advice.
  224. 4.6 to 5.4 swap
  225. dead
  226. 5.4
  227. OBDII Scanner/Monitor
  228. Bad Cats, leaky?
  229. Speedometer change PATS
  230. Looking for Diagrams
  231. Things I should know about 4.6L Tritons?
  232. Oil
  233. Strange Engine Behavior on Start Up in -19 Degree Celcius Temp
  234. More Idle Problems
  235. Recurring spark plug corrosion/misfire
  236. 5.4 Engine Problems
  237. RXP Gas Kicker
  238. 2005 engine tune up
  239. Idle surge
  240. Starting problem - Clean MAF?
  241. Tune up on the 4.6?
  242. Cylinder 3 misfire only in the morning
  243. Temperature gauge question
  244. 8000 cfm efan
  245. Oil ?
  246. Poor coolant flow at idle
  247. 93 Fuel pump
  248. Chewbacca
  249. insufficient EGR flow, please help
  250. f150 hesitating
