- o2 sensors
- COP's off of Ebay?
- I think there may be a problem....
- Cleaning The Idle Air Bypass
- Replacing a 1997 4.6L with a 2004 4.6L
- More Power?
- 04-06 Plug Warning
- efan or edge programmer?
- Troyer underdrive pulleys installation questions
- fuel pump basket
- Idle
- Need Help With Understanding HP
- Electric fan
- 1989 f 150 troubles...still
- 2005+ Pcv
- check engine light on
- idle problem after battery change...
- Curious
- Started 4.6 to 5.4 swap
- 05 towing 7000lb travel trailer
- Qiuick question
- Oil Problem?
- Computer Problem??????
- She Loves Me Again!
- RPM's drop down when stopping...
- engine oils (kinda lengthy)
- 04 5.4 Excessive ticking at startup for 2 seconds after sitting for 36 hours
- Possible head gasket problems????
- help please? fixed hydrolock still white smoke
- PLEASE help !!! Code P1121
- Lost Soul!!!!!!!!!!!!!!
- tuneup on 2000 f150 4.6 with 200,000 miles . . .
- I looked at the Chevy and Toyota truck engines
- tuneup on 2000 f150 with 4.6 . . .
- cop replacement?
- Is this an IAC problem?
- oil sending unit
- how to test coils
- devo2810
- Idiots at the Ford dealer
- Neal, Headgasket Question
- Burning antifreeze!!!!!!!
- 0-60 times?
- changing plugs on 2000 5.4 efi
- 98 4.6 swap to 5.4
- 07' 4.6?
- Engine Questions & Problems for 5.4L.
- 1997 4.6 V8 F150 belt issues
- power steering
- Higher Amp Fuse Replacement
- Standard maintenance for 100,000 miles
- time to idle my F150?
- Bought a F-150, now what?
- How much are new spark plugs?
- 04 5.4`s do they have lifter tick ????
- open loop/closed loop?
- used seafoam
- Weird "bang" on highway today
- Engine Skipping after parking truck on hill
- Electricans...Charging System Questions???
- New To Site, have a question
- tranny problems
- different 4.6 engines, what is the difference?
- Please forgive me if this has been discussed before... 3v 5.4L rev limitation
- Cheapest remanufactured engine deal
- 2007 F-150 - 4.6L vs. 5.4L Gas Mileage
- internal horsepower rating
- super chargers?
- COP bad?
- Injector Cleaner
- Problem with idle after cam/head change in 1994 f150
- can someone find me the "spark plug changing"
- starter noise?
- it idle to hi
- resetting computer?
- 5.4l - to rebuild or replace, that is the Question!
- Stalls in Park
- Increasing Idle speed
- 2005 Motor Noise
- Problems with 5.4!!
- Wix Filters
- Code P0125 (Closed Loop Fuel...) Advice?
- ran codes on my "03 supercrew
- Engine knock, Please help
- '06 5.4 Motor Fixed with Oil change - WEIRD
- pi head swap
- fluctuating oil pressure (urgent)
- E-Fan - Single or dual??
- Improving fuel milage?
- Fuel filter clip? 2004 and up
- 4.9L 6 cylinder question
- F150 motor problems PLEASE HELP
- New Speed Chip!!! Ha!!!
- 5.4 Head removal question
- Keeps popping PCM maxi fuse???
- The next Tornado/TB Spacer/Fuel Line Magnet type thing
- Engine Swap, Crate or Other Manufacturer
- 1998 F150 auto scanner it said it was the coil pack
- Excessive gas consumption.
- OBD-II reader, Cheap ones OK?
- Starter removal on 1997 4.6
- 30,000 Mile Service
- Fuel Filter change 2004 and up, NEEDF CLIP
- Spring Clamp Fuel Lines
- K&n
- Please help quick
- Chain Tensioners sound like bad idler?
- Found the miss in my 5.4L
- Fuel Pressure Relief...
- Newbie Few ? about engine swap
- How Many Horse Does A New 5.4l Stock Put Out?
- Power Distribution box location
- Blue coolant radiator hoses?
- 92 F-150 5.0 rough idle
- shaking at 30
- Air filter change "heads up"
- 4.6 rough idle
- 1998 F150 4.6 suspect seized engine
- xcal 2 and manual transmission
- what engine vin= W?
- Gaskets
- Changing oil and warranties
- 3-valve Heads On 2-valve Block???
- How do I adjust my TPS ?
- Is there a performance head upgrade for a 3v 5.4?
- My new AEM Brute Force for my 4.6
- Blown motor 05 Screw 22k 5.4L...Advice???
- P1451?? Little help Please
- Battery
- Need help, non-Ford (sorry)
- Heater core hoses
- '99 running rough
- 4.6L Odd issue...jumped time
- Oil in the air cleaner
- 1.7 ratio rocker arms safe with a 2021 cam
- What do i need to beat a Harley
- c.o.p's
- 04 Heritage won't start
- Alternator Does Not Charge
- M.Y. 2000 5.4L specs.
- 99 with 5.4 won't run
- I have 1989 COMPLETE 5.0 laying around, how hard to put in 2000 f150???
- Bad Coil Pack? 1999 5.4L
- Gas Mileage
- 97 F-150 w/ start-up white exhaust
- idle troubles...
- How to check for vacuum leaks?
- Oil Capacity 2005 vs 2006 5.4
- Fuel Gauge Going Out???
- CEL Light on...CHEAP place to scan for the codes??
- crane powermax 2021 camshaft ??
- 351 W Vs 5.4
- another 98 4.6 #4 missfire... searched a lot
- K&N air filter/ reprogaming needed?
- Stalling
- Heater Core Replacement
- looking for high speed bearings
- valve/lifter noise
- Engine missfire at high load and high speed
- Merry Christmas and Happy Hoildays
- 5.4 idler pulley = common problem?
- White Foam on oil filler cap.
- Bad Alternator??????????
- flex plate
- 06 with 10k-mi Wont start DOA
- Spark Plug Wire Connection on Coil Packs?
- belt squeek with hard shift.
- '88 4.6 valve cover gasket
- 89 f150
- 1st time I had to be towed home - HELP!!
- Size needed to change fuel filter.
- Engine ticking/plunging sort of noise
- v6 parts
- 5W30 w/ 5W20 Amsoil??
- Service engine soon light?
- weird smell????
- 4.6 to 5.4 swap 97-98 people... to PI 5.4
- Bleeding Power Steering
- Replacing coil packs?
- question on adjusting idle on 5.4
- '01 F-150 won't start
- Quick Gatorback Belt Question
- bad vibration
- Do I have the right spark plugs?
- engine restore additive?
- NEW OEM Ford COP's
- Maf
- cleaned tb, now have fast idle
- Engine working too hard?
- 59K on my 2005 5.4L, Change Plugs?
- EGR Question for jbrew, bluegrass, or others
- Stalling issues
- tapping pedal when starting cold??
- So who does have a time cert video ???
- Help Immediatly! Please
- question on high mileage 98 f150 4x4
- HELP!! Trucks missing...no power... check engine light
- The Truck Project
- Save your $$$
- Cooling Capacity????
- engine miss when wet out
- Need help - F150 started guzzling gas
- [PRETTY URGENT] Is this what's called a blown spark plug?
- cruise control doesnt work
- Larger Throttle body/ TBS/ custom tuning
- Ford Genuine COPS 2
- Simple 4.6 swap?
- help please
- PCV Valve
- MAF sensor
- Harmonic balancer not lining up w/ other pullies
- Severe Backfire Problem
- Where are the sparkplugs?
- Front main seal replacement
- Stalling Question
- Gauges or OBD-II Monitoring
- 4.6 alternator probs...Please help.
- Spinning using brake
- When did you get you first....
- Aftermarket Coil Packs!
- 02 won't start
- 95' 5.8 buckin like mule , egr ? PLEASE HELP!
- 5.8l Ecu
- DOHC heads on my new engine.
- Power steering Prob
- service tech needed for part #'s
- Help.
- engine swap
- vacuum leak & buzzing noise.....
- o2 sensors
- 99 F150 4.6 Heater Control Valve
- Question about valves...
- Would a bad valve cover gasket make engine run lean?
- Original Air Intake/Air Filter Queston
- Feul Trim System Lean Banks 1&2
- 2001 f150 supercrew plugs
- theft light flashing won't start
- pullin the motor
- Prolbems (HELP)
- 5w30 oil in a 5.4
- truck shaking
- Motorcraft 5W-20
- Fuel filter replacement.
- 1993 F150 w/4.9 cutting out - suggestions needed
- Dual tank fuel siphoning problem…
- Idle Rpm's all over the place??
- Lifters
- I know about so many brands of oil but what is BEST?
- 2003 5.4 starting issues HELP!
