View Full Version : Engine
  1. '04 engine ticking?
  2. Proper idle RPM 4.6
  3. I wanna race
  4. Tech Tips a good referance
  5. Cleaning under the hood
  6. Ditching the remote oil lines?
  7. Really wierd problem. Help please!
  8. All about 98triton54l's 406K+ mile truck!
  9. Losing Antifreeze
  10. still got heater troubles, still coold too!!
  11. Block Heater
  12. heater troubles, damn is it cold!
  13. Tune-Up Info for a 2004 5.4
  14. Blown V6 Engine
  15. Starting Issues
  16. 98 4.6 rough idle
  17. 5.4L spark plugs
  18. rattling dash.......driving me crazy
  19. Weird noise from truck
  20. Shaking truck
  21. What oil do you run? Higher mileage trucks?
  22. Erractic Oil Pressure Reading
  23. 5.4 problems, please help
  24. rear main seal
  25. who will be the first to swap this in?
  26. Noise From Engine Compartment
  27. Friend just lost #4 cyl. 97 4.6L
  28. Valve Cover Gasket
  29. Stuck gas pedal
  30. 4.6 oil capacity
  31. Lightning S/C on Reg 5.4?whats i need?
  32. Some info - F150 Diesel confirmed!!
  33. 300 Straight Six questions...
  34. Weight Class 2 for a f-150 ??
  35. Compare stage1 cams to stock...
  36. Noisy Power Steering
  37. 2000 Ford F150 5.4l. Codes#p0171,p0174
  38. Hard to start when warm 5.4L.
  39. Warranty Quest.?
  40. 1998 ford over temp
  41. horrible idle
  42. 4.6 mustang vs. 4.6 f150
  43. strange noise on startup
  44. ethanol conversion
  45. Condensator?
  46. Need new ignition coil packs for F-150 F250 97-99?
  47. Oxygen Sensor Heater Ground Help!!!!!!
  48. Towing Mileage
  49. 5.4L crappy start up and idle
  50. how to adjust belt tension with idler pulley
  51. Cold Weather High Pitch Noise
  52. white sludge
  53. EGR valve need help
  54. 05 5.4 Fx4
  55. V8 swap from V6
  56. 03 4.6 No starter cranking,.but has good battery
  57. 5.4 Triton vs. Chevy Vortec and Dodge Hemi
  58. 5.4 and main question
  59. cam shaft what to choose
  60. Cylinder 1 misfire...Lean
  61. Ha! mines bigger
  62. NOS and other under the hood mods.
  63. 302 dead cylinder
  64. Engine Starts fine, but then just Dies
  65. Possible headgasket leak?
  66. P1451 canister vent solenoid
  67. Slight Whistle at idle..Anyone?
  68. Worse MPG after break in?
  69. Cometic MLS Head Gasket
  70. Fuel filter pressure before/after
  71. Source of wet plugs?
  72. Fuel Line removal question....
  73. 2001 5.4 shuddering
  74. 99 5.4l cylinder location
  75. Are throttle body spacers worth it...?
  76. help speed control sensor
  77. timing adjuster
  78. Losing power more every day
  79. 4.6L Runs rough until warmed up
  80. Check Engine light
  81. Mobil 1 Test
  82. electric fans cooling
  83. Which COPs to use?
  84. Location of fuel filter relief valve
  85. shouldn't I be getting better mpgs?
  86. LONG: Multiple issues from the engine compartment area
  87. Long trip, need tips
  88. hard start
  89. Loose air intake?
  90. cranking issue
  91. Throttle body spring..?
  92. Oil Leak??
  93. Another Idle problem.
  94. Time for a new Thermostat. Stock or step down?
  95. Time for a new 4.6?
  96. '95 f150-351 Sensors
  97. 1994 5.8L oil pressure
  98. replacing IAC and fuel pump
  99. Engine swap
  100. Can't find the cause of the truck's stumble..
  101. Oil temp guage screwy
  102. truck is bein a bitch
  103. Will a older 351 Drop down into my 1997 F150 4x4?
  104. Where is the shrader valve on a 2002 Supercrew?
  105. Most difficult oil change of my life
  106. Ignition Coils Ford F-150 97-99
  107. Grinding sound during start up??
  108. the 5.4 it's alive after swap
  109. big time problems!!!
  110. Electric fan worth the $$?
  111. Horsepower?
  112. F-150 Diesel !!!
  113. NOT the normal clicking/ticking
  114. Cel P0125 ??
  115. 1997 F150 4.6.Need Some Ideas to get more Hp On My Rebuild
  116. Oil changes and warranty
  117. Rough Idle
  118. 4.6 suggestions
  119. 05 5.4L issues...
  120. 04 Belt tensioner- adjusting to loosen
  121. Clean Ports
  122. Engine Drop in quote
  123. Releasing Fuel Pressure?
  124. Oil question...
  125. 90 with I6 300 idle high
  126. Interesting Site...
  127. 2,000 to repair HELP!!!!!!!!!!
  128. Burning Plastic!!!!!!!!!!!!!
  129. Plastic smell from Heater
  130. Worse mileage after TB Cleaning?
  131. C.O.P. question
  132. More Power for a 04 4.6?
  133. what carb to go with? any suggestions?
  134. 2002 4.2L V6 Service Engine Soon Light
  135. Serpentine Belt?
  136. sensors on a gas tank
  137. NOt Sure where exaclty to put this...
  138. IAC question
  139. remote oil filter
  140. First self oilchange Triton 5.4
  141. 1st engine upgrades, what to do?
  142. Valve Spring Tools?
  143. engine swap question???
  144. 5.4 3V Swap
  145. Engine Warning Light!!
  146. Triton problems!
  147. gas miliage
  148. Fuel line question
  149. Increase Power for 5.4
  150. Annoyance........please help............
  151. I found the BEST Gas Saving Device Yet!!
  152. How hard is this on the engine?
  153. Engine Swap
  154. Humming noise
  155. what is this wire plug into??? swap people 4.6 to 5.4
  156. where is the oil pressure switch on 95 4.9 L
  157. long tube headers
  158. How long can a 5.4L last, as in mileage?
  159. Prestone belt dressing
  160. 5.4 L upgrades
  161. 2002 f-150 super crew 4.6, engine?
  162. Price of a new starter
  163. vacuum leak at pcv hose
  164. HELP!!! 4.6L Change Out
  165. 4.6L Change Out
  166. 4.2L spark plugs
  167. Please Help!!!!!!!
  168. Help!! Need a pic of fuel vapor canister and charcoal canister
  169. Engine does not start. No sound at all
  170. 99 4.6 spark plugs?
  171. 1999 4.6 weird start issue
  172. ford mech. cant help can u
  173. Tricking out my 04
  174. Cleaned TB
  175. Hey Quintin
  176. New 5.4 engine had to be installed
  177. What's a plug working it's way out sound like?
  178. Misfiring COP
  179. Ford Customer Service/Head Gaskets
  180. what eslse to do
  181. Turbo Inline 6... ?
  182. what is it
  183. Can 5.4L COP's BE USED ON 4.6L?
  184. computer malfunction? 03 Spercrew
  185. F150 Pressure Guage Dropping Around Corners??
  186. LOUD noise when starting up?
  187. 85 f150 - Running Hot - Stumped!
  188. Pennzoil Platinum and Quaker State Q Torque
  189. [Sorry, you guys gotta see this!] It'll make you smile
  190. Whats my towing capacity?
  191. IAC Cleaned, Still Loud Noise
  192. 91 PCV Valve Location - HELP
  193. What temp do your e-fans come on
  194. 4.2 Engine Upgrades
  195. Frustrating starting problem in cold weather...
  196. F150 5.4 vs. F350 5.4
  197. Whistle problem log
  198. First time Ford owner... need advice.
  199. f150 recall for cruise controll
  200. Engine questions
  201. service contracts?
  202. cold starting noises
  203. 5.4 Piston Slap? May be time for a change
  204. Fuel injection vs. Carburated
  205. Some codes
  206. cruise control
  207. Will Expedition 5.4 fit in F-150
  208. Stock Thermostat
  209. Core plug installation
  210. Electric Fan Once Again
  211. Service Engine Soon light...
  212. 2002 4.6l auto f-150 smoking after cranking??
  213. Bad Gas?
  214. '85 F-150 won't fire!
  215. intermittent crank no start, theft light flashing
  216. p0320 question?
  217. stroker kit and boltons
  218. seafoam?
  219. Vibration/rattle noise
  220. 1998 5.4 engine missfire #1
  221. Engine Swap????
  222. Super Unleaded
  223. Block Heater?
  224. runs like NEW!
  225. Gunpowder Smell from Engine
  226. Po320
  227. 2001 f150 4.2l check engine too lean 1 2
  228. best gas, highest btu
  229. Just replaced my plugs, some notes
  230. super charging
  231. Hydrolock
  232. Ford sues International over engine dispute
  233. 98 F150
  234. 0-30w Amsoil
  235. Another 2003 5.4 Spark Plug Question
  236. Long Crank time? Fuel pressure/IAC??
  237. Starts for an instant
  238. Ford Racing 5.4 3V Ported Heads
  239. supercharged 4.5 ?
  240. engine flush
  241. Pro Blend More Mileage plus????
  242. How much current does a block heater use?
  243. Humming Noise?
  244. 5.4 engine ?'s
  245. DPFE sensor
  246. Po1451
  247. Mustang Intake
  248. 5.4 3v top end lubrication issue
  249. Need help with my PI Head swap!
  250. Check engine when I accelerate
