- 5.4 triton v8 firing order
- What is Rod Knock (not really F150 related)
- System Running Lean...
- To be or not to be....Synthetic?
- 07 F150 5.4 is loud.
- break-in required?
- Cam's for the 4.6....?
- Fuel Sensor
- '03 SCrew 5.4L running with low oil
- E85 Fuel
- Seeping head gasket 4.6L???
- 98 4.6W rear freeze/core plugs leaking?
- coolant leak ???????????
- Spark Plug change
- do I change the Spark Plug Boots?? Help.
- Anti freeze leak
- Question about K & N airfilter
- cylinder numbers
- ordered new cops and plugs for what??
- What's the Word on Iridium Plugs & Aftermarket Coil Packs 2V 5.4?
- Tune up time
- Wrong EGR tube?
- Gears don't line up ?
- Timing Chain Tensioner
- 16 Month old "new" truck
- 4.9 Stright 6 Mpg.
- Cylinder Head Temperature Sensor?
- 1998 f-150 5.4 blown spark plug
- Lightning ECU?
- no 7 missfiring
- 98 F-150 Backfiring
- Hissing on Shutoff
- what r u getting for gas mileage
- Feedback on F150 Ext Cab w/5.5 Bed
- 5.4L idle problem when cold. Help!
- Deisel Transplant
- cleaning TB??
- 4.2L Engine Knock
- engine size
- How can i change the timing on my 86
- '02 F150 P0308, P0316, P0174
- number 2 cylynder miss fire
- Must I pull the engine to remove the oil pan?
- Governor
- Codes without reader
- how do underdrive pullies work?
- Seafoam? Fact or fiction?
- 400-351....
- hp rating 5.4 and 4.6
- Bad engine mount?
- 93 F150 302. Now 331 with 351 fire order
- Codes? Help
- governor
- oil pump or pick up tube?
- HELP: Squealing / Whining 2004 F150
- '86 with starting issues
- Vacum Leaks
- Please HELP, Lean codes, no fuel mileage, vibration
- 1992 w/ water in oil
- Fuel Economy on 97 F150 Scab w/ 4.6
- Loud Engine Whine
- 5.4 bank 2?
- Waking up 5.4 on '04 Expedition?
- Cranks but won't start!?!
- help me please
- Alternator Problems??
- fuel mileage
- 87 f-150 300 6 cyl missing and dies at idle?
- blow off valve under my hood!
- Engine Bay Picture for '85 F150
- Oil pressure problems
- Spark Plug check
- Idle Air Control Valve
- Sea foam or Injector service?
- Dealer Service
- codes for check engine light?
- water leak
- Help cop question
- 4.6 how much oil does it hold
- After Market Cruise Control
- Help! 98 F-150 NASCAR edition Battery Dead, hood latch stuck.
- Idle vibration
- 2005 PCV location
- 5.4 no off idle power??
- 4.9L Straight 6 Questions
- Low RPM=weak power
- hey guys
- cylynder head problems
- Please tell me it was a freeze plug!!!
- 95 4.9 Accessory Drive Belt
- coolant question
- Supertuners? Help me out
- I knocked the wire loose from oil sending unit on...
- Is this an IAC problem?
- Expedition Engine Advice
- 4WD with 4.6L, need feedback
- changing o2 sensors
- Rough idle
- Need 6-pin MAF pinout
- interessted in opinions on this e-fan article
- Removing the silencer
- Spark Plugs From E3
- 2000 F150 Spittin' and Sputterin'
- 99 4x4 4.6L plug and mileage questions...
- O2 sensor
- 2001 F-150 Wont Start
- 4.2 spark knock question
- cam phaser repair cost
- 5.4 a dog?
- part number for oxygen sensor
- Accel COP's
- thermostat problem?
- maf
- Help In the middle of changing fans
- cylinder 7 misfire in1997 5.4
- Check Engine Light
- oil leaks 5.4
- Occaissional "clanking" when warming up
- loud whining sound-pollution pump or belt?
- 5.4 3 Valve Motor.
- Help diagnose O2 problem
- Head Gasket question
- 4.6 L Continuing to missfire
- Spark Plug for 98 4.6???
- oil ?
- Complete tune up
- Problems with truck startingstaying running
- Q about posting pics in posts
- parts?
- air fuel gauge install
- Engine is knocking after detailing engine
- Firing Order
- Help with p0453 code
- IAC bolt ??
- Oil filter line leak
- check engine light wont go off
- Cold Drive Away Miss
- Cop's Deal -
- emissions prob?
- ODB for '95 F150
- truck is smokin...please help guys
- keyless door entry
- how many quarts of oil 99 4.6
- Which is better, K&N or Airaid?
- Intermittent misfires
- f150 engine stall and revs flactuate
- My F150 sounds like a diesel
- o2 sensor wire help
- e-fan help
- MEGA Fuses
- Excessive Oil Loss...Please Help!!!
- 1989 f150
- High RPM hesitation
- Throttle Response / Acceleration Hesitation Delay = 2006 F-150 Lariat 5.4L 4x4
- 4.2l V6 in a '98 F-150
- Absolutely ridiculous gas mileage! HELP!
- Mass air flow sensor cleaning help
- Fan questions...
- Indicated Engine Temp Never Normal
- Oil pressure drops,then noise
- Trucks runs, but no fuel pressure
- O2 sensor question.
- '99 F150 Won't idle
- '02 F150 shudder/misfire
- Blown 1985 new 87 powerplant! Over heating....
- 2004 5.4 Spark Plug issues
- Any printed shop manuals for 03 yet?
- Fuel Filter Location 2000 screw 4.6
- Fuel issue...
- 98 4.6 slight shudder/stumble
- Engine Swap
- Need More Power!
- 1997 4.6 Misfiring Cyl. #1
- a/c and heater
- Factory EFans?
- engine stumbles
- got new cams ordered, what about heads?
- gas mileage
- Why, in the name of Jesus...
- High pitch whine at 66 mph???
- Moroso 35500 cermaic block sealer
- Tapping when under load
- Has anyone ever experienced this with MPG indicator?
- Cold Air Intakes from Ebay?
- Inectors
- What engine do you have and for what reson did you chose it?
- Frozen Fuel Rail???
- Engine swap with explorer
- Excessive Dripping
- High Pitch Squeal at approx.1600 rpms - alternator
- Oil Pressure-How much is too much?
- Throwing P0171 and P0174
- Spark Plug Tips
- Changing only pre-cat O2 sensors
- engine rebulders
- Weird choking situation while cruising
- 4x4 ate that much gas?
- TQ Converter
- engine type
- Removal Oil Filter 5.4 2006
- 98 f150 trouble code p1299
- v-10??
- Truck accelerates without me pushing the gas!!!
- Oil filter removal 5.3-V8-2006 F150
- Check Engine light
- Burned up my '99 F-150
- Q for the pc geeks - cd based repair manual
- knocking/tapping '99 4.2L -COLD WEATHER!!!
- strange noise 03 4.6l
- how often do you all change your oil
- Tune and new exhaust, is like new truck
- Throttle body Spacers
- Faulty Oil Pressure Sensor
- '02 F-150: Engine squeak
- 1997 4.6 engine removal
- 2005 F150 High Oil Consumption
- Is the hurricane coming?
- Cold start whine
- New EGR valve?
- 5.4 Intake Interchange
- 5.4 engine build questions
- Engine problem
- 98 F150 4x4 4.6L- What engine do I have?
- Rough idle issue,someone help please!
- Who needs cold air intake?
- Heating problem?
- Hesitation from idle. Timing problem?
- starting problem
- using a little oil!
- Porting A Stock Plenum
- Engine Vin Number-original Or Rebuilt?
- Cold Weather=No Start
- Fuel Filter???Missin,But no Engine light???
- Blew the motor
- Finally 18.5 MPG
- 4.6l
- F-150 4.6L and the Sport trac 4.6L
- Interesting idle pattern
- '93 300 I6 hesitation
- Fuel Pump Help
- Which oil type? Dino or Syn?
- 2002 5.4 making some noises ya'll
- bad miss
- engine stutter?
- Running codesDi
- Help My Truck Is Shaking
- f150 "low" on something ?
