View Full Version : Engine
  1. hard idle and poooooor mpg!
  2. 300 question
  3. ERG valve code
  4. Plug wires again
  5. '04-up Gas Mileage.....
  6. Triton 4.6 Questions???
  7. Exhaust leak from manifold.
  8. 4.6 roaring
  9. stalls when cold??
  10. No Place for the CHT
  11. 4.6L f150
  12. What's up with the 5.4L spark plugs
  13. ok i need help on this
  14. Misfiring #7 cyl.
  15. Timing Chain Question
  16. frg valve code
  17. rpm's at 70 mph?
  18. What Should I Do ? ? ?
  19. No vacuum!
  20. Help! Fuel, shuddering and other bad stuff.
  21. 2003 radiator removal question.
  22. air filter housing.
  23. Lean???
  24. Motor cleaning and degreasing.
  25. where can i find a complete lightning engine
  26. people who swaped 4.6 to 5.4 with 4.6 computer
  27. What can trip a Code P0113?
  28. Truck shuddering while driving
  29. I need help! 92 300 I6 Ignition system.
  30. New Truck, but old engine?
  31. Fuel Filter Replacement Photos
  32. romeo vs windsor heads
  33. Sensor on oil pan
  34. 92 f150 leak from near starter
  35. fixing idle
  36. Whistling Engine
  37. Clicking noise
  38. Fuel Fliter
  39. cranking longer to start???
  40. 1999 F150 4.6L Romeo Head Gasket Questions
  41. 2002 5.4 vs 99 dodge 5.9
  42. '03 f-150 radiator removal question
  43. Code P0054????
  44. Oil change Intervals
  45. Oil leaking
  46. Code p0230
  47. Any software that can Be used Via LPT
  48. Walbro fuel pump question
  49. tach install
  50. More power from 4.6L
  51. Towing question
  52. 4.9 oil pan
  53. is 10 miles a gallon normal
  54. Performance '07 F150 5.4L FFV
  55. Base fuel pressure for 98 4.6L F150
  56. another rough idle...
  57. slight rough idle
  58. 1993 V8-5.0 vs 6 cyl 4.9
  59. e-fan blues - no FAL kit for 03 Expedition
  60. coolant flush on 99 5.4L
  61. Hello
  62. aftermarket thermostat?
  63. Oil Additives - Do they Help?
  64. Good price on used 5.4 engine
  65. help
  66. How man miles are on your f150s?
  67. Throttle Body Spacer?
  68. 05' F-150 STX to a 2008 F350 FX4!!!
  69. Poor throttle response 06 FX4 5.4
  70. people with 5.4's video please
  71. totally dead
  72. Safety Torx for MAF
  73. Lost power towing RV
  74. Im having a whistling noise from my engine....
  75. Recommended service with 107k miles on a 1999 F150 4x4
  76. Fast Idle on startup
  77. Code P0404
  78. PO401 Help!!!!
  79. I Need Help!
  80. 2004 4.6
  81. P2104,p2106,p2111,p2112 & P2135
  82. Cant hold rpm's
  83. which cam
  84. cam phasers
  85. 02 replacement?????
  86. Ruff idoling
  87. what e-fans for a 2003 Expedition?
  88. Clearing Codes without Scan tool
  89. Help Decoding Code
  90. Recommended plugs for 1999 5.4?
  91. should i keep my 98 f150 4x4
  92. Coil Replacement
  93. Mechanical Odometer Stopped working??
  94. What difference is there between a 97 4.6 from a thunderbird and a 97 4.6 from f150?
  95. newbie needs help
  96. Auto-Rx?
  97. Checking codes
  98. seriale number
  99. cam?
  100. Cylinder Layout - 2000 F150 5.4L
  101. 4.6 1997 f150 engine I'm stumpped
  102. What next
  103. After market head for the 3v??
  104. Knocking when cold!!!
  105. Head Gasket
  106. Where is my PCM?
  107. Crate motors
  108. Is There A chip or tuner for 1994 Lightning
  109. 93 idles rough when warm
  110. Throttle response w/'07 3V
  111. Need help with 5.0L
  112. 7700gvw
  113. f150 stalling at low rpm and stepping on gas
  114. wierd whistle comin from engine
  115. tune up time 97 4.6
  116. Radiator hose adapter for temp sender
  117. Long starup
  118. New 2007 F-150 rough idle
  119. 95 5.0L-looking for SPOUT
  120. Quick-n-simple engine rebuild ...
  121. 93 vs 99 F150
  122. help on what this code means
  123. code p0455
  124. Engine Knocking
  125. Squeak from engine
  126. Fuel Mileage Experiment
  127. EGR Flow Excessive...Tried everything!
  128. A ticking noise in my 97 f150 w/4.6???
  129. Check Engine Light Came On
  130. 97 4.6 Ticking while stopped in Drive or Reverse. Goes away in Park & Neutral
  131. 97 F150 evac error
  132. 4.6 Timing
  133. Remanafactured engines
  134. 1995 5.0 L Engine Firing Problem
  135. How to change cop's
  136. E85
  137. #2 Misfire after cleaning Engine Compartment
  138. Superchip 1100
  139. COP's
  140. '97 4.6 gas mileage PROBLEM
  141. Needs better Highway manners
  142. Help oil ?
  143. 2006 F150 Studdering ???
  144. overheating
  145. 98, won't start.
  146. HELP-studdering f-150
  147. HELP-studdering f-150
  148. My 4.6 seems to be going down hill
  149. Bottle Baby/2004 5.4 F-150 & other mod help
  150. 97 4.6L F150 running rough
  151. 5.4l hesitation/stumble?
  152. spark plugs
  153. Engine Fumes in the cab ...
  154. broke a plastic air hose insulated in foam
  155. 4.2L to a V8?
  156. Speedometer Dances
  157. Truck has no balls
  158. Observation is your best friend...
  159. Need Help
  160. truck is getting worse and worse
  161. Truck Missing Dealer may be wrong?
  162. engine losing power
  163. i belive my valves are knocking
  164. My ford is very sick...
  165. wierd wierd problem we cant solve
  166. Thinking Of Switching K&n To A Aem Brute Force
  167. slow idle return after rev
  168. New 4.4L diesel in 08
  169. Air Charged Temperature Sensor - What does it do??
  170. NOS yes or no
  171. Best bang for buck mods on 4.6???
  172. Why E-fans?
  173. Way under powered!
  174. O2 Sensors
  175. Iats???
  176. Speed
  177. Coolant Temp Sensor????
  178. Check this out!
  179. farting noise
  180. 3.8/4.2
  181. 2003 5.4...Air Silencer?????
  182. How high is to high?
  183. A little help if you can?
  184. lots of water from both tailpipes
  185. Air Bag light flashes and then stays on
  186. Gas Mileage
  187. What Motor Do I Have?
  188. Truck won't start
  189. Tips on changing plugs
  190. Need Help with Oil Pan
  191. Anyone have any ideas? Rain...Misfire....
  192. 97 F150 4.6 Died!! :(
  193. Changing plugs, lots of oil on one of them...
  194. Where is my ignition control module? 92 f150 300
  195. Best Online Parts Store
  196. Engineering flaw with 00 F150
  197. Best Way to learn everything about cars/trucks
  198. super chip idle
  199. Oil Filter question
  200. it fishished
  201. Fuel Mileage
  202. My 04 F150 stalls...
  203. Demand for Ford F-150 over the other 4 makers
  204. Guys with Cam Phaser knock/tick
  205. 2000 F150 rattling sound coming from engine compartment
  206. Wierd Noise After Shifting into second
  207. Chirping sound from 02 F150, need advice.
  208. Yet another 4.6 swap question
  209. modular crank and cam lock tools
  210. Polyurethane engine mounts
  211. F-150 5.4l
  212. Modifications for better mileage
  213. Cold air induction
  214. ebay aftermarket part question
  215. 4.6 is fine....
  216. 4.6 swap to 5.4
  217. codes PO305 and PO314
  218. 5.4 oil leak(s)
  219. Fuel MPG really stinks on 5.4`s.....
  220. Is my block cracked? pics here
  221. engine elec. schematic needed for 5.4L 24v
  222. engine noise got me worried
  223. Oxygen Sensors
  224. 99 5.4 4x4 low/NO oil pressure & noise REPAIR!
  225. Fireing Order For 5.0
  226. Anybody heard of HESCO out of Birmingham?
  227. shop manual
  228. Location of R304 Relay???
  229. 99 Xlt V6-4.2l Engine Stalls At Take-off
  230. 2003 Ford Exped ????
  231. fault code Q?
  232. Mass Air Meter Extension Harness?
  233. anyone change an alternator on 99 5.4L?
  234. Power Steering is Loud
  235. normal on start up?
  236. year and type engine
  237. mass airflow sensor?
  238. whats the problem
  239. possible IAC problem
  240. Well, chalk up another 4.6 blown head gasket
  241. E3 spark plug experience???
  242. Dielectric Grease
  243. Pulley!!
  244. oil pan gasket
  245. Q's about fuel injectors
  246. error code P1538 resolved
  247. 2002 Expedition Hesitation
  248. Couple problems with 06 Screw
  249. pls help
  250. I need some help removing a fuel filter
