View Full Version : Engine
  1. What do look for in a high mile 5.4 (1998)
  2. new here
  3. What's a Fair Price for New Head Gasket Installation?
  4. Spark plugs???
  5. Pin from steering column
  6. 1999 5.4 Hesitation at low RPM
  7. Detonation?
  8. Throttle Body Spacers
  9. Anyone ever heard of a slinger for crankshaft
  10. super unleaded 10% ethanol
  11. More power to 4.6
  12. Belt squeal at throttle release
  13. To change or not change the plugs early?
  14. 4.6 liter knock
  15. Rwhp!
  16. Two Codes 327 and 332, lousy EGR
  17. Engine consuming oil at a rapid rate
  18. Fuel Economy
  19. Do I have a problem
  20. More power
  21. v6 to v8 conversion
  22. Radiator leaking
  23. 2005 4.6 V8 engine
  24. Troyer E-Fan questions
  25. For all you non-believers about 5w-20 Oil!
  26. new 1992 f-150
  27. Bad fuel pump?
  28. stripped iac bolts...
  29. IMRC Where the hell is it!
  30. Have a Problem Need help!
  31. Stupid move, need some intake help
  32. Limp Mode
  33. Gator Belt...
  34. doch block
  35. throttle body spacers
  36. does one lead to another?
  37. stutter
  38. Help Help Help
  39. Gas or Edge = Shaking?
  40. 07 ringing from under hood
  41. determine cyl misfire cause ? 2001 5.4
  42. AFE Magnum Force install problems
  43. 5w or 10w30 okay?
  44. engine light staying on
  45. 1990 XLT SC 5.0 manual - Pinging and slow idle issue
  46. Redline for 4.6 Ltr - Where is it???
  47. old school carb guys!!!
  48. Error Code P0455 and resolutions ?
  49. bad engine 97 triton
  50. will this oil relocation kit work on my 01 F150?
  51. Help P0402 Code
  52. aussi 5.4 need info plz
  53. Why different oils?
  54. Leaky Oil Filter
  55. Help: 4.9 i6 Tachometer Installation
  56. Throttle body spacer
  57. Saving An Engine
  58. Noise From Engine
  59. confirmed damaged engine.
  60. Whats some good OIL for a truck.
  61. 86 Bronco Engine Question
  62. Service Engine Soon Light
  63. 04 5.4 liter FlexFuel Conversion? is it possible?
  64. Engine knock
  65. Buying a 1992 F150
  66. Bad PCM Need Help Locating
  67. failsafe cooling
  68. 04 5.4 idling tick, and vibration when in drive
  69. 1998 4.6L F-150 Problem that i can't figure out
  70. how to remove/service injectors
  71. What's everyone's idle rpm's?
  72. Cleaned IAC, what next?
  73. Power stutter/hiccups & service engine soon
  74. is thermostat necessary?
  75. Fuel Injector Advice PLEASE!
  76. Bad COP (P0358)
  77. Oil filter relocation kit
  78. Hope someone here can help me
  79. 95 F150 302 Stumble/ Misfire
  80. rwhp
  81. f150 wont idle need help
  82. Blown Engine With Pics!!!
  83. 07 4.6L Questions
  84. 07 4.6 STX ummmpphhhhh
  85. royal purple? amsoil?
  86. temp. guage not working after having clutch replaced (not done by a cert. mechanic)
  87. oil leak near bellhousing?
  88. Recommedations please
  89. Friday Night Lights
  90. Like driving a brand new truck!!!
  91. HP Needed!
  92. Persistent misfire in #8
  93. Fuel Injector
  94. Service Engine Soon light
  95. Changing Plugs in 04' 5.4
  96. DPFE ...fixed...not replaced...FIXED!
  97. Fuel Milage vs Temp
  98. how much cfm for an e-fan?
  99. Diff between 87 & 93 octane gas?
  100. OK I need help with Main Bearing Caps
  101. Valve / Cylinder Head Rebuild Kit
  102. K&N air intake
  103. rough idle?
  104. Need help with a 5.0L
  105. DPFE question
  106. Ignition Upgrade
  107. gasoline question
  108. Hp Loss
  109. timing chain crank shft gears
  110. Need advice
  111. Opinions Please
  112. P0402 Code?
  113. Cylinder Head Job on 98 5.4
  114. Codes p0174 and p0171
  115. Idling too Fast 5.4L
  116. How Much Is Too Much?
  117. Airaid Modification
  118. Want to tow, need suggestions
  119. Cylinder 4 misfiring...
  120. '95 F150 wants to stall/idle surging
  121. Cams
  122. Engine dies on decelaration
  123. Puffing smoke when starting
  124. EGR exhaust tube wrench size PLEASE !!!
  125. Switching oil
  126. computor replacement?
  127. E85
  128. '05 Dying at stops & while driving!
  129. Power Steering Repair Cost
  130. P0174 & knocking and pinging
  131. Belt Squeal......at 350 miles???????
  132. Hey Jbrew!!!!
  133. help with Air intake kit
  134. Denso's
  135. navigator motor
  136. running rich
  137. battery dying
  138. Air filter & ECM reset
  139. water inside oil fill cap?
  140. Question on changing COP's
  141. Q on TSB's
  142. EFI to CARB?
  143. Be Careful Out There
  144. A/c Issue
  145. Bought 01 5.4 Lariat SCrew, need help with Automate 415
  146. 98 F150 4.6L Melting Plug Wires on 1 cyl
  147. What effect does insufficient egr flow have ?
  148. How many 05 - 07 5.4 Tritons have gas in air filter?
  149. 4.6 LTR-1998 Exp.-Replacement Spark Plugs?
  150. 125,000 mile maintenance
  151. Upshift/downshift issues - Lack of Power?
  152. Diesel in an F150?
  153. lets see some dyno graphs
  154. Tweaks for power??
  155. Power steering issues
  156. Lightning Engine
  157. Cleaning injectors
  158. Multiple Codes
  159. Crank position sensor?
  160. Does this sound right?
  161. Facts on using Nitrous on a 4.6 with auto & 3.55 gears?
  162. Negatives to programmers????
  163. Anyone using nitrous on 4.6 with auto & 3.55 gears?
  164. 87 f-150 ignition trouble
  165. Quoted $288.00
  166. Issues running 10-30w oil in 1999 5.4?
  167. Harmonic Balancer Questions...
  168. Need help with oil types!!
  169. Replacing stock 02 sensors '03 5.4 Offroad
  170. Got a code for the catalytic converter
  171. upper plenum question
  172. Do prorgamers really work?
  173. F150 Vacuum Line Help!!
  174. cam question
  175. 01 F-150 5.4L Triton P0125 code Insufficient Coolant Temperature For Closed Loop Fuel
  176. Lifters making clicking sound
  177. Programmers
  178. The Mysterious Silencer
  179. Anyone swear by another plug other than Motorcraft?
  180. Knock Sensor
  181. troubleshooting p1451 code
  182. Truck sputtering!
  183. "New" and need some Help
  184. Do stop-leak products work?
  185. high rpms when stopping
  186. 96 F150 with 200,000 miles
  187. Quick Oil Change Question
  188. '97 4.6L overheating
  189. :)
  190. :)
  191. Need some help with this Vin.
  192. 4.6 Piston Slap
  193. high idle
  194. Truck Runs Great...can't stop a CEL 1401
  195. Autolite spark plugs double plat. in a ford?
  196. Throttle Body Spacer...
  197. TP Stage 2 experience '03 5.4 Offroad
  198. Oil capasity
  199. 97 4.6L runs rough / back fires in gear
  200. 2004 V8 4.6l 90K miles?
  201. Air Conditioning
  202. New Battery.. shifting problems????
  203. Wrong Oil
  204. vibration
  205. 2006 5.4 screw hesitating to start
  206. 99 f150 stutter in gear
  207. lower intake 2001 lightning
  208. Engine running rough and has 17 codes
  209. Dealer ordered a Flex Fuel engine??
  210. Misfires on S/U/Rich Bank 1
  211. 1992 F150 302 EFI - ticking
  212. 95 150 fuel pressure / runs rough
  213. Few K&N questions...
  214. Will this work?
  215. Newby
  216. Coolant Leak alternatives
  217. Tune-up question...
  218. Blown Piston/s
  219. heated pcv system
  220. 5.4 3v Break in oil consumption.
  221. Work truck package?
  222. Disappearing Oil!!
  223. Internal Strenght of 4.6 triton V8
  224. Can a 4.6 V8 smoke 33' tires with an LSD?
  225. Fumoto Valve
  226. Knocking/Rattle
  227. 95 f-150
  228. intro/question
  229. 5.0 bolt size
  230. 5.4 engine block question
  231. Cop's
  232. Please Help Me!!!
  233. Cam Timing?
  234. Efan or Air intake
  235. I need help before I kill this F%&*@#% truck
  236. switch from synthetic to dyno
  237. gasoline
  238. 4.6 supercharger for an 05
  239. Can anyone tell me what this is/does?
  240. Complete COP Failure?
  241. 5.4, rad overflow hose placement...
  242. 07 F150. Which Oil?
  243. Heater core bypass
  244. Advice On Modifacations To Gain Hp
  245. air bag code 27
  246. Changing Plugs for 04'
  247. new F150 diesel?
  248. What Is Wrong?
  249. Acetone as a MPG enhancer
  250. NEED HELP!! Truck Bogged down real bad
