View Full Version : Engine
  1. does it really help???
  2. How Hot is Too Hot???
  3. Exhaust manifold leak???
  4. P0171, P0174, this fixed it
  5. Scan Gauge II intersting new feature
  6. pcv kit,where can i get one
  7. Truck wont burn out.
  8. Can this guy really answer ALL of our oil questions? Who is Jim Fitch anyway?
  9. Lacking performance
  10. rear wheel horsepower
  11. slow acceleration
  12. F-250 V-10 spark Plugs
  13. Can My Truck Pull This ???
  14. 2001 F150 4.6 stalls on start sometimes
  15. Where is the low pressure side port for A/C?
  16. Free Synthetic Oil
  17. New Flex-A-Lite 270 Installed on an 06 4.6L Screw: questions
  18. 03 Recall for Cruise Control, have a couple ?s
  19. Rotella T 10w40
  20. some problmes
  21. Low km 4.6 L
  22. 4.6 plug gap??
  23. Engine to replace 4.6 ?
  24. source
  25. Alright already
  26. didnt know where to put this
  27. Octane differances
  28. Replacing Injectors - or Cleaning?
  29. Location of PCM..2002 F150 S-crew
  30. Removing the oil pan - do I really have to raise the motor....
  31. new fuel filter and still loses power
  32. 7 quarts = 4 quarts?
  33. spark plugs
  34. setting timing on 4.6
  35. hello
  36. Possible to mix different oil types? (Engine)
  37. injector Question
  38. The dreaded knock and the dreaded pull....
  39. 99 5.4 tapping loud on passenger side only
  40. Engine Stumble at ~1500RPM
  41. 1985 inline 6 overheating.
  42. Installing a fuel filter
  43. K&N Question for you guys...
  44. PO308,PO172,PO174,PO175 Help Please
  45. 92 flareside wont start
  46. Where Is Bank 1 O2 Sensor Located
  47. where to find parts(other than dealer)?
  48. Blew the head gasket
  49. Studder Problem
  50. Electric Fans
  51. O2 sensors
  52. Coolant in oil '97 4.6 lt.
  53. 97 F150 Cam Sensor Code PO340
  54. stock psi for injectors
  55. 1994 4.9 runs good then rough after restarting
  56. Diesels
  57. o2 sensors
  58. Overheating
  59. knowledge I Lack
  60. Accel Coils and pict
  61. Anyone heard of MOTOR LATTE?
  62. 1993 5.0 Running Rich
  63. borg-warner o2 sensors
  64. Safely clean the radiator
  65. bolt ons 99 vs 03...
  66. Code P0401 EGR Flow Insufficient
  67. Sea Foam Help
  68. F150 excessive oil consumption
  69. Replace piston bearings by pulling oil pan
  70. Engine Knock - replaced cam phasers, now lifters?
  71. P0308 Jbrew
  72. lifted trucks oil changes
  73. Wrech Light, Engine Light, and ABS light. 04 4.6L
  74. Truck has no low end
  75. The Mysterious Ford Gas Gauge
  76. F150 ext.cab.5.8 EFI VERY rough idle problem
  77. 99 4.6 ping
  78. 80 F-250 only starts when the key is let off??
  79. Light weight/ heavy weight?
  80. 302 in a 97' (modular) truck?
  81. how to get better gas mileage
  82. Is my truck a Lost Cause ?
  83. What do I do for a tune-up?
  84. # of bolts on starter?
  85. Cab Air Filter
  86. Sea Foam
  87. Is my 5.4 seized up?
  88. engine sounds like a rattlesnake under load
  89. How long do f150 5.4 last like milage.
  90. Looking For More Power In 5.4
  91. For those interested in Mobil 1 Extended Performance 5w20
  92. performance package for sale
  93. 95 F150 Help Please
  94. 97 f150 problems
  95. Got Troyer 16" Performance E Fans Today??
  96. temp sensor not in right spot?!?
  97. Finally 4.6 Misfire fixed!!! Yipee!!!
  98. 2006 5.4 block with internals/7000miles (no heads) . How much ?
  99. picture request
  100. supercharger for my '02?
  101. A/C Clutch
  102. 4.2 V6 2wd oil pan removal
  103. How many O2 Sensors on a '97 4.6L
  104. Help needed very fast
  105. 97 4.6 code po102?
  106. 1999 4.6 missing when warmed up
  107. Check Engine Light
  108. Video a few of you have been wanting to see.
  109. 95 150 fuel pump ?
  110. 97 4.6 stalling
  111. I don't know where to post this..
  112. cold air intake ??
  113. Fuel Injector 4.9
  114. Engine Studders...
  115. "Leading Edge" Synthetic oil and additives, plus dyno test video
  116. Synthetic Oil change intervals
  117. IAC replaced, vac lines checked...now high idle
  118. 4.6L V8 layout in current model F150's
  119. Exhaust smells like it's running rich
  120. TSB? 99F150 Cutting out A?C?
  121. Carb'ed and Dist. 4.6
  122. top speed?
  123. Thx JBrew
  124. i think the belt is slipping
  125. Inline fuses and plunger switch
  126. Is this the EGR valve?
  127. Help - Engine Sputter & Shake
  128. Q's about oil
  129. 4.6 triton misfire
  130. Not trying to start a fight
  131. Need help please
  132. Throttle body
  133. 1997 F150 code P0301
  134. Navigator display's PO141,PO171 and PO174
  135. 4300 Mile Road Trip
  136. Rough Acceleration... sometimes
  137. Checking For Vacuum Leaks? Starting Fluid?
  138. Dumb Question
  139. Do they apply nickel anti-sieze at the factory?
  140. Fan clutch?
  141. Wich engines or bottom ends will fit ?
  142. 2000 F150 5.4 Stalling Theft Light ?
  143. MAP Sensor - to hose or not to hose
  144. Dropped a socket and can't find it!!!!
  145. 87 f150 EFI no start condition
  146. weird rattling noise????
  147. 05 F150 5.4 running rough
  148. black box aboce spare tire
  149. Oil pan removal help
  150. screw running rough
  151. Post Coolant System Flush Warm-up Issue
  152. 2005 F150 Engine Swap - Gas to Diesel
  153. MPG Plus plug wires Or E3 plugs, try' em???
  154. No more plug problems in '07?
  155. Console Shifter.
  156. Oil Bypass Kit: Would you put this on your truck?
  157. overheating when towing
  158. Very Confused!! Help Needed Please
  159. The Dreaded P0171 & p0174 codes
  160. Flex Fuel??
  161. Help with EGR housing
  162. Help with permacool efans
  163. What Gains Can I Get from a Super Chip, and Where Can I Get One?
  164. Whiring sound when accelerating in 1st and 2nd gear
  165. '92 F150 pressurized fuel system question
  166. Engine idles fine, but "cuts out" when driving...
  167. 95 5.0 Engine won't start
  168. I6 Mild Camshafts?
  169. Efan adventure on an 03 Expedition
  170. PI Heads????
  171. Oil leak
  172. DPFE Question
  173. What Happened?? Please Help
  174. Repair Manuel/subscription???
  175. Strange Whistle
  176. What do these codes really mean?
  177. bad head
  178. Engine Stall Help!
  179. after market throttle body and maf
  180. Help with Engine Tick 97 F150 5.4L
  181. Breaking it in?
  182. i think something is wrong
  183. Remote Oil Filter Suggestions
  184. Oil Change after first 1000 miles?
  185. What aftermarket fan controller to use with a Troyer Dual 16" kit?
  186. Ranger down! Ranger down! Dad needs help...
  187. Engine swap
  188. Torx bit size to remove tensioner?
  189. dash staying lite up
  190. Oil sending unit / sensor 1990 Ford F150
  191. heat shields
  192. throttle body spacer
  193. Cold air intakes
  194. edge question
  195. 2004 vs. 2005 FX4?
  196. 97 F-150 with leaking fuel line (with pic)
  197. Coolant Leak, Broken Intake Manifold
  198. E85 vs. Gas 87 octane
  199. Help Quick
  200. 07 5.4L Stock-HP, Torque, SFC vs RPM Charts
  201. 5.4 with 2 problems...
  202. What oil and filter?
  203. wiring questions
  204. Using oil?
  205. $10 Air Intake got +2-3mpg
  206. 5.4L internals
  207. Need some advice before rebuild
  208. need engine advice
  209. Help!
  210. truck will not idle
  211. 04 Heritage Cruise Control issues
  212. Oil temp above normal
  213. Motorcraft Filters (K&N Part II)
  214. What is this and should they be hooked to something?
  215. question on my ranger's engine
  216. Troyer dual fan kit ?
  217. Troyer Performance Dual 16" Electric Fan Kit for 1997-2003 Ford F-series, 1997-2002
  218. What's Up With This!!!!
  219. engine swap 88-95
  220. 4.9 hesitation
  221. K&N Filters
  222. aftermarket fuel pump, 1 way valve?
  223. Promar Reman 5.4?
  224. ideas for a replacement 4.6 motor
  225. 460 bougs when i step on it.
  226. Kindergarten Question - Oil Filter
  227. Oil loss at the dipstick.
  228. o1 5.4 200 miles to a tank of gas whats up
  229. help!-overheating issue
  230. Oil Usage 4.6 L 02 Super Crew
  231. alternator
  232. stalling, what the dealer said...
  233. Vacuum Diagrams for Lightning
  234. E FANS?? Do They Work?
  235. newbe motor quez!!!
  236. Need 01-03 F150 Intake Manifold
  237. 175,000 can i still add and be ok?
  238. Might be alittle OT, but the 02 was a humping
  239. 351 Engine Swap
  240. 2000 5.4 bogging down
  241. My Truck starts to shake....
  242. Spark plug blow out questions?
  243. o2 sensors?
  244. got a couple hundred buck burning a hole in my pocket
  245. Horrible missfiring but no diagnostic codes appear
  246. Another P1074 case eventually P1071 too. but it's not the elbow
  247. FFV and Towing
  248. Speedo not working ..... any ideas?
  249. Slow idle when clutch is released and another Q
  250. Changing spark plugs on 2001 5.4
