View Full Version : Engine
  1. K&N - 9whp/16whp on stock F-150/250/350
  2. 2004 5.4L PCM trouble
  3. freeze plugs
  4. 2004 5.4 chain tentioners
  5. 5.4 3v Misfire
  6. p2006 unknown code
  7. What to do.....mass air conversion
  8. heat on with a/c
  9. Poor power when passing and engine noise
  10. Stalls when going into gear
  11. Supercharger for 07 Lincoln Mark LT
  12. Ready for long tubes
  13. 5.4 Cam Bearing Reconditioning?
  14. Guages not working.
  15. power upgrades?
  16. Could it be anything other than my heater core??
  17. coolant flush?
  18. 5.4 vs 4.6 v8
  19. 5.4L Spark Plugs
  20. 97 f-150 won't start
  21. LP truck
  22. Cam holding tool?
  23. 1997 f 150
  24. Cam Swap Procedure
  25. supercharging 07 mark lt
  26. engine running bad
  27. UD Pulley problem
  28. help with a 94 5.0 power steering pump
  29. Penetrating oil for O2 sensor
  30. losing coolant
  31. 5.4l v8 problems!!!!! Help!!!
  32. Yellow clear fluid all over bottom of engine HELP! *PICS*
  33. What is the trick to remove the lower radiator hose?
  34. Engine stumbles and dies with K&N but fine with Wix
  35. 05' F-150 5.4L....spark plugs broke!!!!!!
  36. intake manifold runner control location
  37. Major vaccuum leak
  38. Running ruff
  39. Now it won't run at all
  40. fuel pump
  41. What seems to be the problem?
  42. PCV location on 2003 Heritage Edition
  43. head gasket job
  44. Which supercharger to use on a 2005 4X4 F150 supercab XLT platinum edition
  45. more power for 98 F-150 4x4!!!
  46. 2006 5.4 Dealer broke spark plug on last (warranty) visit
  47. Cruise Control fixed
  48. new heads
  49. 4x4 engages but has noise issue now....
  50. Want some input for E-fan turn on temps!
  51. My 5.4 swap
  52. Should I buy my K&N from here?
  53. Weak starter?
  54. throttle doesnt work?????? 2007
  55. 2001 5.4 hesitates up to 2000rpm
  56. I need some help with a spark plg question.
  57. cylinder missin. first thing that comes to mind to replace?
  58. 02 5.4L water coming out of right tailpipe
  59. 4.6 to 5.4 swap in progress
  60. will the lightning fuel pumps set up work with a stock 4.6 harness
  61. 6 cyl starter too close to exhaust
  62. check engine light on HELP!!
  63. Block heater
  64. IAC Question
  65. 2004 5.4 engine problems, HELP
  66. P1151 on 1997 Expy 5.4L
  67. 300IL6 pops through carb
  68. Blue smoke on a 97 F-250 7.3 powerstroke.
  69. Sudden Oil Pressure Drop
  70. compression ratio
  71. Oil use
  72. valvoline synpower
  73. How NOT to mod an engine
  74. Spark Plug Problems 1999 5.4L F-150 HELP!!!
  75. Winter-ize my truck and g/f's car..
  76. LOOKED at the 5.4
  77. Perplexing overcooling on 97 4.6
  78. supercharger question
  79. 5.4 vs 5.4 supercharged
  80. The "After-Rev Drop"
  81. water pump stuck: triton
  82. fixed the engine tonight...how should it help?
  83. Well, there's your problem!
  84. 4sixxx is out. . .pics
  85. 400hp at the wheel
  86. Someone please help if you can!
  87. do i need a new MAF sensor going from a 4.6 to a lightning engine
  88. autometer oil pressure
  89. Do Ford Gas Tanks Have Anti-Siphoning Blocks?
  90. P0301, a misfire and many new parts
  91. 92 351w cracked head????
  92. doing a lightning swap got some fuel system questions
  93. Fast tick/rattle!?
  94. rattle at start up
  95. 2008 f-150 5.4l does it have a MAP sensor and where
  96. I found a 5.4!!!!
  97. 1994 I-6 compression issue
  98. Old truck sound/misfiring what is the problem
  99. running bad help
  100. swap 4.6 sohc w/4.6 dohc?
  101. need help
  102. Thanks to this forum!
  103. Fuel pump info
  104. bank 2 is dead, why?
  105. o2 sensor location question
  106. Cylinder misfire.... need advice
  107. lightning motor swap in 98 4x4 f150
  108. 5.4 crate engine
  109. need to improve my mpg
  110. 2007 F-150 5.4L Using Oil
  111. Proper gap on 2005 Troyer-charged!
  112. Sporadic and delayed Start up
  113. Replacing 90 degree elbow on back of engine
  114. Starting HEAD Gasket job
  115. Misfire a WOT
  116. replace oil pan in 97
  117. spark plug replacement on '05 5.4 engine
  118. starter wiring
  119. Header Question for jbrew
  120. creepy sound
  121. Spark Plug Question
  122. rpms slow?
  123. Looking fora new ride
  124. Heater Core?
  125. How long should it last?
  126. skipping problem
  127. Pinging under load - Wrench light on
  128. Bizzare engine codes
  129. fuel pump relay question
  130. help chatter noise
  131. Supercharger with PI Heads
  132. Hot oil?!?
  133. My oil gage problem
  134. charging problems
  135. Location of Rear End Type
  136. 4.6 to 5.4
  137. Hi everybody, im new and need some help.
  138. Burning #5 coil plug way to fast
  139. Please Help because Dealer seems to not be able to!!!
  140. Fuel milage
  141. Can I replace a 4.6L with a 5.4L in my 98 F150
  142. Blown Head Gasket...whoa.
  143. K+N Filters
  144. Just some upgrades.
  145. HP Advice
  146. crunchiefs engine swap
  147. What brand of motor oil do you use?
  148. PCM change
  149. pinging or knocking?
  150. My E-fan Build. with pics.
  151. missfire after replaciing air filter
  152. Dids this on the weekend...
  153. My top speed!!!!
  154. 8 month sit?
  155. Dyno Estimate
  156. Weird rumble/shudder
  157. engine swap
  158. Cold start problem
  159. 1997 4.6 oil
  160. Hose identification
  161. cylinder misfire
  162. Pinging???
  163. Installing a 2008 5.4L 3V in a 2004 Truck.
  164. New Screw Member
  165. Camshaft Position Sensor on a 2004 4.2 EFI
  166. My lightning swap project thread, pics and info!
  167. Help on F-150 engine pull
  168. 5.4L hard start question
  169. 5.4 cylinder numbers
  170. Motor Build
  171. Which oil?
  172. Changed Plugs and Mileage dropped?
  173. What could this mystery harness hanging off my truck be??
  174. CHT sensor issues...
  175. Tsb 08-14-3?
  176. PCV Elbow - 2004 5.4L 3v
  177. spark plug wrench
  178. 2004 5.4L oil loss
  179. How long should i be smoking in cold weather?
  180. Truck cuts off when slowing down
  181. It happened again and dealer wouldn't look at it...Please Help!!
  182. Temp gauge not working on 98 f150 5.4
  183. drone and power loss any ideas?
  184. Spitter and sputter pop and crack.
  185. parts sugestions and 4.2L 4.6L questions
  186. engine coolant temp senser
  187. 04 5.4 3v into an 01 4.6 SCREW?
  188. Sorry for the highjacking, but.......
  189. Help Please
  190. Engine runs rough everytime i start it
  191. Attn Ford Tech's 2004 5.4 Ltr Coil Failure issue Question ?
  192. IAC Valve
  193. port throttle body?
  194. Humm..What to do...
  195. Ticking noise
  196. Backfire question?
  197. Power goes flat when passing
  198. throttle body
  199. Figure this one out
  200. 03 f-150 wont start
  201. Question about my 05 5.4
  202. Can broken egr tube cause codes
  203. 5.4L 3V Catastrophic engine failure
  204. Ignition systems
  205. cheap and easy performance upgrades
  206. Weird Problem
  207. 5.4L Cylinder Numbering
  208. Quick question...coil pack
  209. 02' 4.6 Screw
  210. Dead Lifter
  211. Am I the only one who thinks this is a steal of a deal?
  212. Rough Idle and Smoke
  213. Noisy Lifters on 2008 5.4L.
  214. links requested re: cyl. head R & R
  215. Problem with 2004 Ford F-150-emission?
  216. Engine Noise
  217. How many Quarts of oil, 2006 4.6?
  218. Choke Stuck
  219. Its making a noise...
  220. Idling Problem
  221. Don't wait to change those plugs!
  222. Post your mechanics tricks
  223. crunchief's f 250
  224. Second opinion please
  225. Looking for a "guide" to rebuilding a DOHC 5.4
  226. blown plug, bent side electrode
  227. Rough Idling
  228. Best Service Manual for 1997 F150
  229. Changing PCV on F150 1997 4.2l
  230. 05 4.6L heads
  231. My Truck Used Oil
  232. Shudder while slowing down?????
  233. Coolent got Flushed Still Nasty!
  234. Fan Clutch Removal
  235. When i clean my Throttle Body do you need to let the spray dry?
  236. Engine hiss and tick on a 2000 4.6L
  237. Free mods
  238. best options for crate motor?
  239. Got Awhole bunch of things done on my truck today.
  240. 2002 F150 4.6L Timing Chain Rattle
  241. Hesitation, rough idle after throttle body cleaning
  242. 05- f150-5.4 triton
  243. 2001 5.4L SCrew - Spark Plugs Ft.Lbs. ??
  244. Barely runs
  245. Low Idle drops between 300-400 and dies
  246. stumble/missfire
  247. 1997 F-150 replaced timing cover now i don't have oil pressure
  248. Slow radiator leak - help a poor girl!
  249. AGH! 1996 F-150 Fuel Rail
  250. Champion plugs and misfire 5.4L 3v MUST READ
