View Full Version : Engine
  1. New 5.4 engine at 2600 miles
  2. IMRC stuck open or closed!
  3. 6.8 V10 stroker
  4. HELP! Stranded in parking lot!
  5. K&N Filters: are they worth it?
  6. MSD Dashhawk
  7. Rough idle after sitting for 9 days?
  8. Unusual engine squeak/bang
  9. Nothing Happens
  10. Cleaning intake ports and Valves
  11. manifold fitting coolant leak
  12. condensation/ water drip
  13. 1998 ford v8 f150 4.6 Injectors
  14. got a few problems with my 03 "boss"
  15. 5.4 capabilities
  16. Cali Gas Mileage...
  17. air conditioner low valve 1997 f150
  18. Opinions on fuel additives
  19. 94 5.0 problem with rough running at 40 to 55 miles ph
  20. Engine Ticking..Need Help
  21. Skipping runnin bad
  22. RPM Drop
  23. Ok , I give up , what is it?
  24. rough idle
  25. What cold air intake do I need?
  26. Electric fan concerns
  27. Oil Pan Clearance/Removal
  28. New Intake manifold coming. Looking for those interested
  29. 97 5.4 to 03 5.4 Swap Questions
  30. why use my horn when the iac gets evryone's attention
  31. Evaporative emmisions control
  32. Another strange problem with a little extra weirdness
  33. What good are 9mm plug wires?
  34. Tune-up?
  35. 2 warranty questions.
  36. 1999 F-150 4.2L Stumbling and Gas mileage goes up and down...HELP PLEASE!!!
  37. Cam Phaser
  38. PO401 & O2 switching
  39. Underhood squeak
  40. pulley is shaky
  41. O2 Sensor bad?
  42. Adding New Fuel Pump Wiring
  43. Fuel Filter questions
  44. strange "bucking" or "stumble"
  45. E fans
  46. Safety feature
  47. 1990 F-150 Coolant Leak
  48. Misfire on 3
  49. Which high mileage (non-syn) oil?
  50. HESITATION upon acceleration
  51. Spark socket ques.
  52. injector upgrade?
  53. 97' 4.2 v6 Blowing PCM fuse-HELP!!!!
  54. "Fluttering Squeak"
  55. Very Basic Intake Q's
  56. Clock spring
  57. Tier Gasoline (Less Carbon)
  58. start up problem
  59. Service engine soon, truck will not run.. Help!!
  60. Aftermarket Theomastat
  61. 98 f-150 cooling system problems
  62. You don't see this to often!!!
  63. 1997 vs 2002 4.6L differences?
  64. RPMs at idle goes crazy when the AC is on !!!
  65. Dampener removal
  66. 97 F150 4.6 Engine Fan removal
  67. Help!!!!!!!!!!!!!
  68. High Idle, 5.0 V8, IAC Valve?
  69. 97 5.4L Stalling
  70. engine blowing dark gray smoke
  71. 4.6 fuel injection
  72. 98 4.6L won't start..plz help
  73. Is it posible to swap engines on a F150 4.2L to 4.6L
  74. dumb question about serpentine belts
  75. 300 I-6 Revlimiter
  76. Trouble code
  77. problem after cleaning throttle body
  78. Fuel filter
  79. Mobil 1 Full syn oil.
  80. A Bit of "Oil"ly Advice Plz
  81. 98 4.6 my power sucks
  82. 4.6 timing module
  83. HELP!! Burning oil..possible blow by?? ring job?
  84. Electric Fans
  85. 1995 F150 5L stumbling and DTC 538
  86. 05 F150 4x4 vacuum diagram
  87. Repair Manuals vs. Me : I Win....
  88. 4.6 H.O. details/specs
  89. truck dies, starts after cools down (89 w/4.9L)
  90. 02 Sensor problem FINALY solved...
  91. cam phaser replacement...do it yourself?
  92. 98 f-150 blown plug high mileage
  93. Intake ?? sohc
  94. Mass air conv.
  95. Engine swap
  96. DPFE sensor
  97. Over Drive, When and When not to use it
  98. Low Oil pressure at Idle
  99. Cold Air Kit Causing Whistle!! Need Help
  100. Best engine cleaner for under the hood?
  101. PCM Problems???? Continued!!!!!!
  102. crankin wont start...
  103. Info Please
  104. P1451 woes continued
  105. What COP's?
  106. o2 sensors up stream/downstream huh?
  107. P0012...."A" Camshaft Position - Timing over-retarded (Bank 1)
  108. 05 Starting problem
  109. OK to push-start?
  110. PCM Problems????
  111. need help 5.4
  112. 96 5.0L Supercharge?
  113. New to the FORD Forum
  114. 02 sensors
  115. Which SCT Mass Air Meter
  116. 5.4 Spark Plug removal video
  117. help 2001 harley 5.4 supercharger
  118. ice breakers
  119. P0302 - Cylinder #2 Misfire
  120. MISFIRE is driving me CRAZY!
  121. Won't start Help!!
  122. Wheel well removal
  123. Which COP?
  124. weird problem
  125. Evr?
  126. Causes of Burning Oil?
  127. 99 F15O 4.6 Hard to keep running on start up
  128. 01 F150 Missing Under Load
  129. Strange hiss or vibration
  130. Using oil?
  131. 99' F150 4.6 HELP(rough idle)
  132. Idle issues and low oil pressure
  133. Performance COP value?
  134. 4.6L Startup driving Bog
  135. Strange problem
  136. Change Timing Chain
  137. Changed oil, now wont start
  138. Good news / bad news
  139. 5.0 #4 plug broke..
  140. 5.4 Woes
  141. Just bought a 2000 F150 XLT 5.4 Triton
  142. Misfire and rough running
  143. Code 172
  144. Valve chatter
  145. past 2 weeks ive had an exhaust leak, today its worse
  146. How To Change Drs Side Plugs ?
  147. 5.4L No compression???
  148. trying to degree cams
  149. "conventional high mileage oil"
  150. if you had 2,000 dollars what would you do
  151. Fan Clutch Storage
  152. stock horsepower history
  153. Clicking Noise In Motor
  154. wheres all the abbreviated terms you guys use
  155. DTC Nightmare
  156. how to do tuneup ?
  157. 5.4 Redline ?
  158. Anyone with Cracked fuel line?
  159. 5.4 e-fan
  160. 92 f150 5.0 help please
  161. How good is synthetic motor oil really?
  162. correct O2 wiring harness voltage?
  163. p0191 code
  164. Body Lift and Access to Engine
  165. Pulleys??
  166. Ok what path to take with 97.
  167. Cleaning a 07 throttle body
  168. coil help . . .
  169. removing throttle body
  170. No spark 99 f150
  171. Not Missing but Not Firing
  172. 12-13 mpg, is this normal?
  173. 2003 5.4L - I'm scared... Please advise
  174. COP / plug replacement advice
  175. Drained Radiator and Block, only 3 gallons used
  176. 1998 4.2L conversion to small block v-8?
  177. will it fit?
  178. Where is the PCV Valve on 1999 4.6
  179. should i replace plugs in 5.4
  180. Link to TSB
  181. How many miles on your 5.4L engine?
  182. F150 hard starting
  183. 2005 F150 4.6 Tuning
  184. Oil?
  185. 2002 idle problem
  186. 03 F150 O2 Sensor
  187. 2005 4.6 "clicking"
  188. 99 150 5.4L firing order-#5 misfire
  189. e-fans
  190. 347 stroker kits for f.i. 302
  191. Truck Won't Crank, Please Help I've tried everything!
  192. 2 pulley vs. 3 pulley underdrive?
  193. will only start after a good rest
  194. Clicking noise
  195. where the heck is it???
  196. Not much power
  197. engine swap?
  198. 2003 5.4L running very rough in the morning
  199. Spoke to Scan Gauge today
  200. Blue Smoke!
  201. Surge under acceleration
  202. Too Lean
  203. 5.4 PI head swap possible?
  204. Engine stutters in gear only it seems.
  205. smoke coming from engine bay
  206. 7.3 glowplug change help
  207. Fuel Line Disconnect @ Fuel Rail
  208. Fuel Pump at constant 12V?
  209. gas smell in cab
  210. Inexpensive power upgrades?
  211. Rough Idle
  212. 2004 f150 obd11 troubles
  213. Cracked Head
  214. 4.6l engines
  215. Top 5 power mods
  216. 1998 Explorer -> Throttle Body
  217. Vibration when stoped at light
  218. Engine oil analysis
  219. Good idea?
  220. Need help with decision to purchase.....
  221. electric fan questions
  222. how often to change oil
  223. engine number
  224. Fuel rail problem after changing COP #7
  225. 05 slight misfire?
  226. recharging ac
  227. Gauge Needles vibrate when truck starts! Help!
  228. oil pressure sensor question
  229. Heater Core
  230. Wet Engine "Gunked it" Continued!!!
  231. Gagage needed
  232. HELP!!! Engine stalling
  233. Head Replacement
  234. Hard starting when warm
  235. Oil leak
  236. 2003 Ex fuel pressure regulator check?
  237. check engine light
  238. Engine failsafe mode
  239. Idles low and dies, runs good w/foot on gas
  240. 90 F-150 dying problem
  241. OBD2 scanners on sale
  242. Loss of Power!
  243. 2002 f-150 5.4 V-8 fuel filter?
  244. what's the difference?
  245. which friction modifier do I use
  246. Any Idea on what kinda grinding noise this is?
  247. F150 won't start
  248. Cel
  249. 1994 F150 5.8L How much life left?
  250. 85PSI Fuel Pressure???
