View Full Version : Engine
  1. COPs arrived today. Now what?
  2. PO401 code
  3. 2003 5.4 SC - my fuel mileage
  4. Where is the number 6 plug?
  5. Is 9.5 mpg normal?
  6. Help
  7. 2004 f250 6.0 diesel injector problems?
  8. Road trip fuel economy test
  9. Engine Intake and Fuel System Cleaning
  10. nitrous?
  11. rear wheel power
  12. stock rods rating? what hp?
  13. PO300 Code
  14. Who is in the 200,000 mile club?
  15. Aftermarket Coil on Plugs (COPs)
  16. Aftermarket E Fans
  17. DPFE Presssure Sensor Keeps Failing
  18. Help! 2000 F150 V6 problem
  19. Engine looses power on takeoff
  20. Cleaning the Engine
  21. Poor Fuel Economy - 2005 Triton 5.4L
  22. Intermittent heat and overheating '97
  23. 4.9 running hawt
  24. Ford 4.6 Small block
  25. 5.4 Sparkplug Question
  26. Still Running Lean
  27. F-35 Fighter could be the last Manned fighter built!
  28. my LED trip meter keeps resetting!
  29. oil
  30. Efan key on and Thread in type temp sensor
  31. No power on low end
  32. High idle at start up
  33. Grrrrrrrr! :mad:
  34. Idle wanders when heater is on
  35. Truck Starts, Won't Idle, Then Dies --Help!
  36. #2 Misfire Confusion!
  37. rough-dead idle
  38. Performance Ideas!!!
  39. Harder to start...
  40. my 05 is cutting power and flashing service light
  41. Pulstar Pulse Plugs
  42. plug problemo!
  43. the dreaded knock, lets figure this out.
  44. should i be happy? (i think so)
  45. Well finally did it.
  46. 5,4 supercab
  47. high pitched squeal
  48. noise in motor
  49. lean 02 sensor?
  50. Bad Starter
  51. Synthetic Oil?
  52. Cracked Distributor cap and timing belt
  53. squeaking and chirping
  54. coils going out
  55. Throttle Body spacer
  56. e fans and pulleys
  57. supercharger
  58. supercharger
  59. supercharger
  60. e fans or pulleys
  61. gears
  62. High RPM hiccup during shift...
  63. sparkplug shot out
  64. drivetrain swap
  65. i need more go
  66. hpw do I....
  67. 2004 XL 4.6L looping Idle
  68. New Motor or Not
  69. Superchargers?
  70. 02 Sensor ???
  71. Truck acting wierd when rainy
  72. EGR Delete
  73. Diesel Vs. Everything else
  74. No Heat in '97 F-150
  75. Need help with moisture in plug.
  76. Running lean?
  77. Oil pressure problems when its cold
  78. 2 things about engines
  79. Good battery, good alternator, but no charge
  80. Frustrated, and kinda lost
  81. slipping
  82. Engine Acceleration Question.
  83. Ignition Problems?
  84. codes po171 po174
  85. Loud Knock 4.2
  86. Engine swap 1996 4.9L to 1997 4.2L
  87. strange knocking noise....HELP
  88. Another CAI Question...
  89. Engine Noise
  90. Noise and Vibration????
  91. 5.4 engine change
  92. Quick Question Plz help
  93. Spark plugs
  94. performance torque converter from a F-350?
  95. performance torque converter from a F-350?
  96. heater core
  97. Checking front differential oil level
  98. I Only Got Until Tonight To Fix It H.e.l.p
  99. problem with 06 f150, need advice
  100. Edge Evolution programmer
  101. 4 Wheel low not working
  102. Made the switch to synthetic oil
  103. 5.4
  104. Performance mods (non bolt on)
  105. idles rough
  106. Ive never been so glad i changed a fuel filter
  107. V6 or V8???????
  108. 2000 5.4 Rattle
  109. MSD for the F150?
  110. Rough Idle?
  111. MAF Sensor cleanup
  112. possible IAC problem
  113. Fitch Fuel Catalysts
  114. misfire at 2,100rpm ONLY?
  115. Why does my truck shake at stop lights
  116. Power wash perdicament
  117. Carfax report
  118. Time-Sert Repair Complete!!!!!
  119. 2000 Mini Van Light Problem
  120. Loud Rattle
  121. need info on coil packs
  122. Stutter @ WOT
  123. Help!!!!
  124. starter grinding
  125. P0455 Code
  126. 2002 starting issues.
  127. motor swap 4.6 to 5.4
  128. spark plug removal on 04 5.4
  129. p0300- suggestions please
  130. Tic Tic Tic
  131. 5.4 auto vs. 4.6 5 spd
  132. 90 F150 5.8 Engine Vacuum Diagram Needed
  133. Swap or no? need opinions
  134. cleaned my TBI now my idle is messed up
  135. Two Sets of O2 Sensors + 1 EGR = Check Engine Light
  136. H.p.
  137. Silly 303 code......again.
  138. Is a K&N Filter really worth it?
  139. engine swap
  140. Trouble Codes
  141. Blew a Plug...Renting Time-Sert
  142. Need to replace radiator, LFP?
  143. Rolling back in Drive?
  144. Power Steering Pump
  145. new here - need some advice
  146. 4.6 and 35's
  147. Anyone have spark plugs break at 20,000 miles(5.4L 3V)?
  148. What am I doing wrong ...
  149. Which heads to go with
  150. Need help identifying noise
  151. Techron
  152. police interceptor engine in f150
  153. Catalytic Converter or water damage?
  154. Tune-up recommendations
  155. 97 f150 Check engine light, O2 Sensor
  156. 4.6 L Remanufactured install in 1997 F150XLT
  157. Truck is Shaking at Idle
  158. oil ? should i go with ford
  159. Gas in my oil? HELP!!!!!!!!!!!!
  160. 2003 F150 Dead!!
  161. P0401 Error Code - What does really it mean?
  162. Powerstroke gas mileage
  163. Show Some Luv For de 4.6L
  164. Coolant light came on and guage is hot
  165. 1st service engine soon light on 02 screw 4by`
  166. 4.6/5.4 swap
  167. Check Engine Light and no power sterring or brakes
  168. power stroke or cummins
  169. Misaligned Vaccum lines cause BIG HEADACHE
  170. 1997 5.4L, Lean Code, Tranny?
  171. couple of questions
  172. 2007 F150 FX4 5.4L Problems
  173. grease fitting questions- 03 Expy
  174. Engine swap Q's 01 4.6/auto into an 00 w/ a 5 speed
  175. location of ect sensor
  176. 2001 5.4 heater core pressure regulator
  177. Mpg
  178. 95 5.8 engine codes
  179. boost
  180. Engine Cutting Out!?
  181. 5.4 engine problem
  182. 97 f150 4.6 Engine Swap questions
  183. lightning swap
  184. cam ?
  185. 85 f150 timing gears
  186. 5.4 Spark Plugs THANK YOU!
  187. 5.4 question
  188. current 5.4L V8.....
  189. I am out of warranty - one last trip - please give some advice.
  190. cold air intake suggestions..
  191. weird? problem engine in failsafe mode when I jump started it with a tuner?
  192. engine stop when turning to the left
  193. Engine Break-in period
  194. What am I in for ?
  195. "cylinder missing" question
  196. Testing COP's
  197. 99 Cobra 4.6= 98 F150 4.6
  198. Finally Freakin Done - Heres the results -
  199. Changing Coil Packs
  200. 5.4 3v
  201. LOST Throttle body srcew
  202. Motor knock
  203. what plugs...
  204. high idle at startup
  205. Looking for PI heads
  206. Fuel Milage question
  207. ignition tech question...
  208. Low fuel and random misfire?
  209. Engine Bogging!?!?!?!?!?
  210. 04 5.4 and synthetics
  211. Calling Jmc
  212. MAF questions???
  213. Want to see inside a running engine?
  214. Issue with truck passing Mass state inspection
  215. PFE and DPFE operation and diagnosis
  216. spark plugs
  217. Hesitation and rough running after fill up
  218. Upgrading the engine to V8
  219. Horsepower
  220. 5.4 knock
  221. Tune up time?
  222. 2004 5.4l dies when shifting from R to D
  223. Please help knocking
  224. 5.4L crate motors
  225. cops
  226. IAC / buzzing sound?
  227. P01451
  228. other cars/trucks with: 300 4.9L six cylinder
  229. Last Chance Before Mechanic
  230. temp sensor
  231. "Help" Battery Drain
  232. 05 fuel filter
  233. Troyer fans
  234. I Fubarred Help
  235. 1997 4.6 Water Leak
  236. F150 Engine runs rough starting at 47mph .
  237. O2 sensor replacement
  238. Rear main seal 4.6
  239. crazy knocking tranny or engine
  240. fuel pump ?
  241. rpms dropping
  242. changed all 8 cop's and spark plugs and....
  243. water dropping off of heat shield ???
  244. 1997 4.6 won't start
  245. Trouble code P2106. Plz Help
  246. Help With Screw On Coil . . .
  247. need some good advice
  248. anyone out there
  249. 04+ 4.6 sc kit...???
  250. Internally or Externally balanced?
