View Full Version : Engine
  1. Lightining cylinder heads
  2. timing chain tensioner
  3. evap hose from intake to purge valve 9G271
  4. motors
  5. Fuel problem
  6. sputtering
  7. Gas Type 87,89,93
  8. lost 1 thru 4
  9. spark plug insert
  10. 4.6L Head Gasket and Tranny <---- Bad luck, HELP
  11. EXPLODER Head Gasket Milk
  12. Coil PacKs for a 2004
  13. leaky gaskets
  14. about to kill somebody
  15. Fuel log - the last entry, and a first entry!
  16. I know this has been asked before however.
  17. I know this has been asked before however.
  18. performance inhancer study that needs verification
  19. 2 and 5 cylinder misfire
  20. High Idle
  21. Efans...what do they really do? Do I need them?
  22. engine build code identification
  23. Git-r-done!!!
  24. How to add more power
  25. POS thermo controller.....
  26. Mileage
  27. VIN number = options
  28. EGR code?
  29. IAC - how do you remove this sucker?
  30. engine question
  31. Stange Noises from my 08'
  32. 02 Sensor Install
  33. 03 Expy, same engine as 03 F150? Plugs?
  34. Found a vaccume leak, need some information...
  35. brand new '08, is this normal?
  36. whats the stock fuel system good for?
  37. Truck runs better than ever
  38. Disconnecting the throttle cable
  39. thread for Built54
  40. i hate my truck now
  41. Sparkplugs
  42. PO401 and PO303 codes
  43. 16" electric fan review
  44. Alternative Fuels
  45. best cold air intake
  46. Air Filter?
  47. cleaning engine
  48. gas tank repair?
  49. early 5.4 vs 3v 5.4
  50. Just hit 100,000 miles
  51. throttle cable
  52. FAL E Fans setup
  53. Rough idle
  54. Chance to buy new motor
  55. after previous suggestions need more specifics.
  56. HELP ASAP..Clutch fan!!
  57. ...are Tacomas any better?
  58. Fuel Pump ID
  59. K&N FIPK Pictures
  60. Cleaning egr ports on 1995 f150 5.0
  61. new cats
  62. 10% Ethanol gas in DFW!!!
  63. p0446
  64. cold air intake(4.6 manual)
  65. I am a very sad panda...and im realy P*** check this out...
  66. Motoblue COP's
  67. Should I burn my truck?
  68. heads ??????????
  69. specs
  70. Need Advice On Updates
  71. unexpected problems
  72. best spark plug?
  73. siphoning gas out of my truck
  74. 1994 f150 code-paper clip
  75. OBDII code readers?
  76. Which COP's
  77. Won't Start on cold mornings!!!
  78. Cel P0401
  79. 1991 F150 5.7 Idle
  80. Cleaning Intake manifold
  81. engine light stays on
  82. Any available techs please read
  83. 12mpg stock 02 F150 = bad fuel injector?
  84. Increasing 5.4L Horsepower
  85. just cleaned MAF sensor...
  86. Anyone with newer 5.4 and a dashhawk
  87. Additives ...
  88. 02 sensor
  89. Fuel Pressure Regulator help
  90. plugs and plug wires
  91. 04-ticking engine
  92. 5.4 cops
  93. Intermittent miss on 93 F150
  94. Thinking about doing a 4.6 to 5.4 swap
  95. Ticking after new serp belt?
  96. No Start After Clock Spring Replaced
  97. Triton 4.6 L HELP ME PLEASE-OIL PROBLEM
  98. 2000 5.4 stalls
  99. Identifying an 8 bolt crank
  100. Coolant causing misfire
  101. Temp gauge
  102. engine dies at idle
  103. 4.6l..........impressive
  104. What size wrench is needed to remove the fan clutch?
  105. Check Engine Light ON......Then OFF???
  106. Circulating Coolant Heater Install ???
  107. Anybody
  108. Wont Pass Emissions!!!!
  109. Spark Plug Questions For '02 5.4L
  110. Clunking Noise
  111. Stupid missfire... 06' 4.6
  112. Emissions help.
  113. clicking, ticking, and knocking
  114. Sputtering 4.6 AGAIN!!
  115. Is anyone using Granatelli Ignition Wires?
  116. Tensioner cut into my timing cover (pics)
  117. Global COPs
  118. V-10 Opinions?
  119. Need some Plug help in Houston area
  120. What's your thoughts on K&N Air Filters?
  121. noisey engine
  122. Running rich
  123. Cleaning Throttle Body "05
  124. help!
  125. slow heat in '98 5.4
  126. Taurus fan
  127. Acorns under the hood!
  128. New purchase
  129. cylinder law suit?
  130. f 150 engine swap
  131. Have to keep pumping the truck to keep it running
  132. High-pitch whine in below freezing temps
  133. Oil pressure gauge
  134. Tuneup
  135. Cai
  136. cold air intake
  137. Has anyone had this code P1409
  138. Since my engine is pulled with bad plugs.??
  139. maf sensor and tb cleaning
  140. IMRC Help
  141. Oil Press. Question
  142. Instrument panel at start up
  143. 5.43v Plug Change Interval?
  144. P2196 & P2198 Rich Codes
  145. Rough idol
  146. p0401 and Performance
  147. Engine swap/ ECU problem?
  148. headers and dyno soon
  149. hesitation and noise
  150. new to these trucks...need help!
  151. Vibration at certain RPM's?
  152. Newbe Question
  153. Timing slightly off at 168,000 miles
  154. 1992 F150 5.0L Error Codes
  155. New to forum and FORD
  156. Inlet Air Temp Sensor cleaning
  157. '97 4.6 to '92 5.0 motor swap?
  158. barly starts in cold
  159. Techron in E350 = Bank 1&2 too lean???
  160. Charging Problem
  161. E-fans
  162. P0171 P0174 lean codes
  163. Radiator Failure / Warranty
  164. Heavy duty alternator delete
  165. Replace Fuel Line
  166. DPFE Sensor
  167. Tsb & Recalls....
  168. A baffling develpmnt w/04/5.4
  169. e fans keep blowing fuses
  170. Oil change question
  171. '05 Acceleration/tranny problem ???
  172. e fan questions
  173. Long Crank
  174. Spark Plugs!?!?!!?
  175. Code 1131
  176. '04 STX 4x4 Engine Missing
  177. trying to make a long story short
  178. 99 5.4L sometimes wont start and funky idle
  179. Fuel Filter
  180. thermostat question for cooling system experts
  181. Injector Position
  182. Forced Limited Power
  183. 5.4L kickdown question
  184. 95 F150 Missing at idle
  185. P0355 Code after Motoblue COP install
  186. Best way to drop oil pan in a 5.4?
  187. I had my truck detailed and now its sick.
  188. running lean?
  189. How much increase in power will i see in boring out the cylinders?
  190. Fuel injectors '05 5.4L
  191. engine start up rattle on 2004 F150 5.4
  192. Neco engines in Ct??
  193. ---- Anyone Use 89 Octane on their 4.6L? ----
  194. Need Advise on coolant leak
  195. New heads and cams.
  196. bank 2 sensor 2 engine code
  197. cam phasers
  198. help my brother
  199. water injection systems...
  200. Performance Modifications??
  201. mystery??????
  202. What can I do to improve my f150
  203. Egr problems on my 1994 f150
  204. PCV Elbow - solved the mystery
  205. help please
  206. blown head gasket
  207. 66 ford Galaxie
  208. first oil change..problems?
  209. Engine shiver
  210. Rear O2's
  211. 4th radiator
  212. Need some advice with my 5.4
  213. changing plugs on 5.4 3v
  214. back fire
  215. 150 with 5.4L 3V towing
  216. Rough Idle & Engine Dying After Start
  217. new headers
  218. 98 4.6 miss!! HELP!
  219. questions involving seafoam and TB elbow
  220. Proper spark plug for 1997 5.4
  221. '02 F-150 V-6 were is the PCV valve hidden?
  222. Throttle Response and gears?
  223. engine starting
  224. Mod Interchange Manual
  225. DPFE sensor
  226. 89 F150 300 Rebuild
  227. question
  228. 1997 5.4L 4x4 antifreeze leak
  229. TSB's
  230. Broken spark plug 2004 F150 5.4L
  231. pacesetter header ?
  232. Any easier way to remove oil filter?
  233. Single or Double Pass Rad
  234. Royal Purple fluids
  235. gas mileage drop
  236. 99 F150XL 4.2, excess motor oil problems
  237. Stalling problems
  238. engine recognizes misfire but...
  239. Code P1000, Clearing Question
  240. radiator hose
  241. What build date did Ford add threads?
  242. Heads - everythings White inside?
  243. Major Tuen Questions on '97 4.6
  244. gas tank?
  245. when does the winter blend start?
  246. Cast Iron or Aluminum
  247. P0133 Code?
  248. Cleaning my '01 5.4L throttle body???
  249. I Need More Power!!!
  250. Need Help ! ! ! !
