- thanks f150online!
- Annoying noise at idle in the cold
- What would cause new 5.4L to stumble?
- Rough Starting
- Vacumm Check
- first oil change
- Aaaaaarrrgh!
- Performance Options?
- P2195 and 2197 Again
- Misfire on Cylinder 4
- 4.2 Pulleys
- 5.4
- GRR i hate sparkplugs!
- stumbling on acceleration '05 5.4 29k
- What to clean a MAF sensor with? Brake Clean?
- Bank 1 & 2 Lean and Large Leak? Just got back from new engine and SES light on?
- factory oil
- Look at the Garbage in My Fuel Filter
- What is a 4.6 Windsor???
- rough idle after fixing heater
- changing coolant??
- 2000 F150 2v or 4v?
- ford dealership warranty challenge
- A sign of a bad Alternator?
- Alternator?
- 4.6 or 5.4 replacement
- Chattering noise...
- Is it just me?
- plug blows and cops
- Accelerator sticks when cold
- crown vic
- Remote oil filter lines leaking
- 5.0l 302w
- long time cranking
- Oil filter location
- Need MOTOR ADVICE 4.6
- cylinder order
- quick question about removing iac
- Swap 97 crown vic engine into 97 f150?
- 04 F150 5.4L...5w30?
- 98 4.6 thoughts?
- help truck running rich!!
- Anyone ever cure their accseleration stumble?
- P0171, P0174, P0304 codes
- MSD C.O.P.'s- anyone used them?
- 2004 Screw won't start_sometimes
- 1994 f150 5.0 liter- thermostat replacement
- My service visit yesteday...
- Need engine in 01 5.4 Trans slipped when starting off? What to look for?
- A few Questions about maintence
- Need help on cylinder head!
- Best high millage oil
- Buzzing sound on 300-6
- Mobil one
- Engine Break-In Suggestions
- Need opinions FAST PLEASE looking at another F150 CHEAP that needs work
- how to replace left cylinder head gasket
- high idle @ start
- Which years had the Spark Plug blowing out the heads?
- Which kit is best for Spark Plug repair? Lisle?
- Make Check Engine light go on??
- Triton 4.6 Faster?????
- Truck stumbles on occasion at acceleration..
- 4.6 HP rateing tuned ?
- Does this MPG sound right?
- 1994 F150, weird issues...
- location of pcv on 03 4.6
- Where Would You 6 Buy a Rebuilt Engine?
- $1000 mods
- Service Engine Light
- p1000 & p0308 engine missing!
- help
- help please!
- 2004 updates?
- K&n Fipk???
- Fuel filter help!!
- water in oil????? help!!
- e fan temp switch
- Help changing spark plugs in 4.6L V8 2001 Supercrew
- Head temp sensor?????
- Long Block Gasket Question
- 04 5.4 misfire 3k-4k rpm
- Changing out COP(Coil) #7 pictures
- Ring Job - 1999 F150 5.4L
- How do you release the line from the clutch master cylinder?
- Ford Recalls 1.2 Million SUVs, Trucks
- Changin Plugs & COP's on 5.4
- Fast idle at start up
- Totally lost...please help.
- I guess I got a good one
- RockPick, i need you to unlock DTC thread.
- Changing head gaskets in a 5.4L 99 Expedition - Anyone have a PDF manual or tips?
- E-FAN Report
- 03 5.4 tach wire
- 07 SCREW Vibrates at 1,700 RPM
- 5.4l EGR Valve replacement. Anyone have picture of engine?
- Low idle and stalling
- Have Motorcraft Spark Plugs Been Renumbered???
- 5.4l Engine Swap
- 4.6 life expectancy
- Is it just me
- I broke something!
- wierd howling noise....rough idle, wont start cold, and the sound of water?
- fuel system cleaners...is it all just snake oil?
- 2004 cai
- 97 f150 4.6 intermittent rough idle when warm
- Studdering and shuts down at idle
- Engine semi-permanent shut-down
- Code Scanner Suggestions
- Just got back from autozone AND!
- Got my first Check Engine!
- Engine Shudder at WOT - Warranty Ending - Please Help
- started porting another intake
- HELP 5.4 spark plug broken off today 2005
- Vin number help plz
- Annoying whine????
- 2003 5.4 Fan Shroud Replacement
- Step-by-step Lightning swap
- "Whining" noise when hitting gas/driving
- cai fit
- Missfire Cylinder 6
- oops?
- Engine rattling
- 97 Expedition 5.4L - 2 Coil Packs or 8 individual coils
- More power
- Whistling MAC throttlebody
- 7.3L powerstroke
- Code questions
- 2004 4.6 motor trouble
- Replacing an IAC on a 5.4
- p0307,p1151 low rpm misfire
- Abs Light
- Oil capacity
- e-fan wiring question
- Another missfire..
- New Performance Coil
- How to Replace O2 Sensor? Help . . .
- weird noise comming from intake tube
- Intake tube?
- Filters?????
- This truck is HOT!
- Questions about Engine and Trany
- idle's a little on the rough side
- Oil filter
- Heads
- P2195 and P2197
- converting 4.2 to V8
- Who Sells The Best Intake System for the $$$?
- quick differential quesion
- Mixed Wrong Gas
- losing power
- Broken bolt, Lower intake.
- electronic throttle response
- sticky throttle f150 2001
- supercharger
- motor wont get hot
- motor want get hot
- '98 5.4L F-150 - question about changing serpentine belt tensioner
- cops
- OBD-II code reader recommendation?
- 5.4 Heads best choice?
- best engine for the job
- 1995 4.9L check engine light
- thanks
- Stuttering/Power loss at 3500RPM on a 97'
- 351?
- Problem changing #2 plug
- Accel COP's are Junk
- How much oil 99 5.4 with oil cooler
- Code 01
- 1997 4.6 rough idle high mileage
- New engine now starter problems
- Romeo heads on Windsor block?
- '07 5.4L question
- check engine lite
- Cold Starting
- Sensor Location?
- engine locked up (revised)
- Strong Sulphur Odor
- Code P0301 And A Really Rough Ride
- Got moisture?
- Truck warm up/thermostat...
- Engine locked up
- The little engine that could...
- 4.6 swapped to 5.4
- P1288
- engine bogging...
- lightning heads...
- full throttle power...
- Sudden fuel mileage drop
- '05 Hesitation under Heavy Acceleration
- burn out
- evolution prolems
- 2004 4.6 Sparkplugs
- Rebuild Video 4.6/5.4
- Need 5.4 for 01 Reman or Used? How much should it cost?
- FilterMag: Works?
- E85 Gas station locations right here!
- low idle
- 1997 5.4l
- fuel issues...i think
- cooling system question
- Nervous about plug problems
- Code 401 on 1997 F150 155k miles
- torque-Curve design increases air intake volume
- IAC Question 4.2
- Electric fan change???
- truck not pulling like it used to
- New 5.4 and E85...
- Hope for those with broken plugs.
- Autolite Revolution HT0 Spark Plugs
- Do we need an F-150 Hybrid?
- Would this fit?
- Oil Pressure Problem, please help...
- Spark Plug Tip Bent?
- Ran outta gas!!!
- New Guy, Needs some Help regarding Water in Oil, Thanks to all in advance
- 4.6 same as mustang?
- 07 4.6 continues to turn over after started
- Weird wobble
- I changed spark plugs, now i got problems
- cylinder head help
- Cleaned MAF, getting gas mileage
- Flying spark plug
- Supercharger
- Intermittent rough idle, '86
- Should i port or buy new heads?
- need help with water pump
- What can I get selling this?
- Anyone ever used Z-Max?
- How does running lean hurt an engine
- 19lb vs 24lb injectors
- Stock 5.4 N/A Block
- Water in fuel?
- Replace COP's with Spark Plugs?
- start then die
- Fuel injector and COP connectors
- Smoking the Tires!!!!
- head gasket: fixed but now what?
- Fx4 Off Road
- Global Automotive
- truck doesn't like to start and is showing engine light code P0191
- Misfire
- new idea for ford.
- 03 cobra engine in 07 f150 with 4.6
- 5.4L 3V Throttle Body
- Idle problems. What I have done so far.
- 04 F150 Block Heater Help - Anybody
- engine replacement questions
