View Full Version : V8 Engines
- What's the real deal on Slick 50?
- O2 Sensor or something else
- WMS YET????
- What size tires?
- Does anyone smell burnt oil?
- make the noises go away
- Expired Warranty Engine Replacement
- Fuel Problems?????
- Hey guys or something
- poweraid
- 5.4 Rough Idle/Miss
- 99 F150 4X4
- Fuel Filter replacement
- Windsor vs Romeo engines
- What would it take to make a y2k sc 5.4 a 13 sec. truck?
- "Spark" my interest.
- Freaking THIEFS at the dealer!
- AMSOIL???
- For the novice: WHAT IS A TRITON 4.6L and what makes it different
- noisy lifters when starting
- Superchip with CNG/Bi Fuel
- What type of oil is best
- Dangling open connector, what for?
- Increased V10 Horsepower for 2000. What did Ford change?
- Warranty on Piston Slap Replacement Engine?
- Tornado Air Swirler
- Performance Upgrades?
- Reset Engine Computer?
- Magnetic oil filter bands?
- need advice-oil problem
- Check this one out!!!!
- Gas Mileage
- Bypass Govenor
- XanMan
- New 5.4L engine
- yo
- 4.2 and AUTO is a money burning combo!!!!!!
- Anti-freeze leaking
- Gas Milage 4.2L V6
- Could You tell me the Horse Power On My Pick-up
- Spacer for the Thottle Bodies
- Rough Idle On 4.6
- thank you DonC
- velocity tube & mileage
- VELOCITY TUBE HELP
- engine build dates and problems
- Muffler and Air Filter
- emissions: EFI or a Carb?
- Whats the Horsepower on this Ting?
- Anyone use Additives?
- writing the check for the 4.6
- O2 Sensor
- In for Timing Gasket Recall -- Now Need New Engine
- Throttle reponse
- What a mess.
- 351 EFI Performance Engine Rebuild??
- Check spark plug after 45,000 miles
- Update on Piston slap. Revised TSB
- To warranty or not to warranty
- 5.4 Horse Power
- Low Octane Fuel Mileage
- Mike Troyer, the answer man!!
- Coolant temp?
- 5.4L oil leak
- 5.3 Piston Slap
- Can tires effect performance
- 4.6 '98 f250 ld, what now?
- CNG F-150
- UH-OHHHHH !!!
- New 1999 5.4 modifications and new warranty
- 4.2L AirAid?!?!?!?
- Water in #5 Plug well
- 300 horsepower
- Low Idling!
- Power
- BLOWN OUT FROST PLUG!!!!!!
- Ford Vs. Chevy Engine Wars! GO VOTE NOW!
- Magnecor Plug Wires, Where To Buy
- Cooling System Leak
- 1999 f-150 4x4 how many greas fittings and where ??
- Throttle Body and HP & TQ increases (V-10)
- K&N FILTERS
- Engine Block Heater
- Who has Never had Engine Problems?
- Who would buy a Ford?
- Factory Tachometer
- 4.6 HP Disspute
- 2003 Ford HP and other figures.
- NEED HELP PLEAS
- TSBs
- Oil and filter change on 1999 4.6,no sweat why all the crying ???
- engine spark knock or pinging.
- Supercharger recommendation
- Flip Chip by Superchips
- 5.4 Triton vs. 5.3 Vortec Power Ratings
- Bucking...
- More V10 problems
- Sold on Velocity Tube
- Mobile 1 0W-30 Oil
- Ford 99 5.4L Triton Engines
- Tornado
- 460 with excessively high idle after coil and plug wire replacement???
- Our diag.: PerfectoTruckus- Compulsive Horse Powerous- F150phrenia
- Just dusted my buddies '98 Z71 350!!!
- 2000 Lariat 4x4 Alternator Output
- Check Engine Light
- FORD ENGINE TROUBLE? CALL FORD CEO HERE ARE NUMBERS
- Air Intake Question
- Engine Oil Drain Valve
- 100,000 mile tune up interval
- Fresh air hookup
- Hesitation
- K&N Filter
- V10 problems
- New Motor?
- Anybody use remote starters?
- Engine Idle
- Engine Knock
- At how many rpm's do you shift your gears?
- 93' 302 injector cleaning
- HELP!!!!! 1999 Engine 54L backfiring
- Ram Air
- 30K Service
- Dead 4.6l
- found a TSB for idle vibration on F-150
- wheres the fuel filter on 2000s
- fuel pump?
- resetting computer
- who can tell me about Airaid?
- need help please
- Should new driver reset old computer?
- UPDATE: THE UNSOLVABLE PROBLEM...SOLVED!!!
- Air intake systems review......(LONG)
- wrljet.com
- IMTV, How does it work?
- 1/4 times for 4.6L 5spd 99 f150
- HOMEMAID ! !
- URL for horsepower/torque ratings
- CARBON REMOVAL?
- All the performance parts I found for the 4.2L !
- 4.6 to5.4
- Poweraid revisited
- Cold start noise
- 1991 F-150 351W Build-Up
- What is this air box mod?
- Spark Plugs
- de-carboning?
- What mods should i make?
- The UNSOLVALBE PROBLEM!! Even for my genius mechanic
- 10 TIPS ON HOW TO BUY YOUR NEXT CAR/TRUCK!!!!!
- ROUGH IDLE AND HESITATION IS GONE YEE HI!!!!
- HELP Moisture in Crankcase
- Synthetic Oil
- Pulley ? for bob.pellegrino
- Oil Change
- Squealin' Tires
- 351 in post 95' body style F150, did they?
- Banks Intake/Exhaust systems
- Intake Q's
- Valvoline Max Life Oil
- K & N filter effect on Canadian Warranty???
- what is going on with the "wms" group buy??
- Mobil1 Filters
- Alternator whine at low speed
- Horrible sound on Cold Start!
- When to change plugs?
- Ok now what (rough idle) again
- Changing injectors & MAF=60HP?
- Oil mark on dipstick?
- HP per $$$
- Need some Advice
- XanMan
- '99 4.2L 4x4, more low-end power??
- f150 problem
- Electric Fan Clutch
- 3/8" or 5/16" gas line removal tool for...
- Wetness under bottom radiator hose.
- Romeo 4.6 and PS
- never seen 20 mpg
- starting problems/ stator valve???
- Oil Temperature Gage Reccomendations
- This one is the biggest.
- FQR 5.4's w/ piston slap?
- Motor UP Infomercial
- rough idle check list?
- 1999 4.6 should i make a change to the air intake ?
- 12 mpg v.s. 20 mpg
- Changing Plugs
- kenne bell air intake pkg /post in other body
- How do you change your oil filter?
- 5.4 & 4.6 Oil leaks
- 300 inline six gas hog
- Whats' the deal with gas tank?
- Plugs
- Our 2000 has a vin ......where will it be built?
- Would you do it??
- rough idle
- Computer Codes
- Dyno Testing
- Airraid question
- Intermittent stall problem after engine start?
- 71¢ for a fresh air system
- rough idle???? please describe it
- This is a test
- WMS Velosity Tube "Group" buy.
- Engine shuddering/ first significant problem! Help?
- K&N/Velocity/AirRaid vs. factory warranty
- 4.6 vs 5.4
- hey andthensometoo
- Need different gas cap
- Start Up?
- How do you add your truck imfo to the bottom of your question ?
- gas line removal tool
- Whats the final word on POWER AID ?
- The Old Big 6...
- Effect Of UnderDrive Pulleys On Vehicle?
- My Velocity Tube Set- Up
- WHY DO YOU DISTRUST DEALERSHIPS????
- Power chip pros and cons for 4.6 triton
- "Service Engine Soon" light
- Weird noises at startup in a 4.2
- Help identifying replacement 5.4 engine
- Check this out!
- Power Pullies
- Recent K&N Filter...MPG Go Down?
- Warrenty For 5.4L Replacements?
- WHY CAN"T I SWITCH TO AMSOIL????????
- Power Band and gas mileage?
- Anybody heard of this one
- Piston slap and additives
- 4.2L V6 is there any recall's for the V6?
- Air induction mod questions!
- 13 mpg on 2nd tank of gas is this right?
- do the 1999 4.6's have a pinging problem ?
- How many miles before switching to mobil 1 ?
- push-starting
- WMS Velocity Tube Survey
- Jasper Engines
- Engine placement
- 4.6 oil leak
- crank pulley/serpentine belt
- Need help ford guys
- pinging (detonation)
- 4.2 Serpetine Belt
- red line
- shift high or low for better mileage?
- Painted Radiator Cover!!!
