View Full Version : V8 Engines
- Ford still has my truck
- Still having trouble with wiring............
- Timing Belt/Oil Pump
- WHY ALL THE SPAM ADS IN THE CLASSIFIEDS?
- Custom hoods?? Help if you can.
- 75 MM BBK and Magnacharger Intake
- Synthetic oil clarification
- Idle problems
- Who makes 5w-20 synthetic motor oil?
- Mustang Recall
- Wiring?
- 5.4 will not idle !!!
- how many gallons of Antifreeze do I need
- Has anyone seen or used this mod?
- Windsor 4.6
- MAF cleaning
- stats on 4.6L
- I Went To The Track
- Rained last night, stalled this morning!
- anatomy of an engine failure
- Single vs. Duals
- Anyone using the G-Tech to get engine performance readings?
- Mobil 1 how do I change
- Why won't my 4.6 start?!
- AirForceOne
- Spark plug question
- 4.6l cracked cylinder head
- MAF Question
- thinking about old meets new...
- stange noise coming from under hood
- Priming your Oil Filter
- What could this be?
- Throttle Body, Mass air, now what?
- piston slap/engine knock
- Air Force One
- Check your starter/solenoid wires!!
- Rough idle at ~1250 rpm...need advice...
- rebuild costs
- Door crack and piston clap
- How do I get my spark plugs out of a 97 4.6?
- 2001 fipks
- bunch a newbie questions (sorry)
- CHIPS
- anti-drain back valve?
- Cleaning MAF Sensor
- 1990-1993 fuel leaks
- Long-Lewis Ford,Birmingham. Exercise in futility!!
- AIRAID
- Pinging In Winter & Rear-end "Clunk"???
- oil pumps
- 4.6 vs 4.8 vs 5.2
- Airaid and now low idle.
- ?'s 2001 HD cooling pkg & break in
- 5.4 with Z-33 here are the Results.
- I had a bad O2 sensor!!!
- Airforce One Intake
- Which FIPK?
- Which is Better!
- Help! 5.4L PS Replacement Expectations
- engine swap with FI
- belt noise??
- Electronic Problem
- Temp.Guage Manual
- 5.4 FIPK, then adding MAF & TB later ?
- throttle cable adjustment HELP!!!!
- 300 I6 is stripping timing gears
- AMSOIL - OIL ANALYSIS IS IN!!!
- Missing?
- Remote Oil Filter
- JBA Headers in hand need install info?
- Dirty Throttle Body??
- Might be interested in checking out this sight
- My baby is back!!!
- K&N FIPK Generation II vs. Generation 1
- Rain/Engine miss
- MPG Perspective
- where is my oil sender
- Valve seals leaking!
- synthetic oil
- Spark plug removal on 5.4
- Throw this in Chevy's Face!
- thermostat question
- 5.4 Head leak
- Ported MAF
- Transmission question
- 75 MM Throtle Body Upgrade ?
- Help with next mod
- Pre-fill the oil filter?
- engine pinging like a mule in a tin barn while towing
- chunky,clunky idle on 4.6/hey bad idle guys?
- Power Steering
- ford man 3 are you out there???????
- i never re-gaped my plugs after the supercharger
- getting a FQR or NEW engine? how to tell?
- Airaid throttle body spacers
- Anyone hear of a FRP/SVO Lighnting blower kit for a reg 5.4L ??
- Inline 6 Exhaust Question
- Sudden Drop in Oil Pressure
- I think I have bad gas! Help!!!!!!!!!!
- Burnt Coils
- Common? Leaking Antifreeze....I think?
- which oil filter do you use???
- Ignition system upgrade
- Thanks F150 Online! / Useful Information for your F150
- Intermittant Problem Starting
- Lightning motor swap
- cruise control
- AIRAID VS. K&N---------HELP
- where's the MAF?
- flashing air bag light
- Truck takes forever to start
- 2000 K&N FIPK w/Carb certification
- Motorcraft Oil Filters
- Airforce One Installed for 1 week now...
- 5.4 FQR engine?
- how much powe do think i have.
- neal the hp runs in 14s,what do you think i can run
- Headers?
- new 5.4w/black oil smelling of gas
- Spark Plugs/Wires
- cold start clicking
- Mobile 1 filters
- '97 4.2L with Oil Pressure Problem
- 98 5.4 vs 97 4.6
- which engine?? 5.4 v. 4.6
- Piston Slap relief
- knock @ low rpm when warm
- THIS "ACTIVIST" WANTS TO TAG YOUR TRUCK
- buying a 1995 Ford F-150 XL extended cab SB
- Hey Magnacharger brothers.....
- Smelly Exhaust (Fumes & Stinky CAT) & Check Engine Light?
- Monster Trucks
- tach signal
- F150 engine swap?
- OMG ---> Need help I'm dity!
- Backfiring
- Any know problems with 4.6L (1997)
- Trouble starting my 5.4 Liter F150
- Pinging 97 F150 4.6L
- Clean the MAF after pulling the air silencer? (TB side)
- Anyone know of a ranger message board?
- Am I hitting the rev limiter when flooring from 1st to 2nd?
- Dealer support for Piston Slap
- Tune Up?
- !984 Engine ratings
- The Velocity Tube is here!
- Roush trucks
- Recharging K&N
- FIPK vs. Airbox mod's. *** A K&N TECH'S OPINION. ***
- Why is my truck a DOG?
- Possible Piston Slap?
- Gotta' question..................
- Pics of my truck & airbox mod.
- www.geocities.com/thepyromaniackid pics of my truck
- Just a ? on horsepower
- Piston Slap again
- 4.6L Oil Capacity
- Anyone read new Truckin yet?
- Piston Slap Problems
- Ford is spec'ing 5W-20 oil now!!!
- sythetic survey
- Bad gas milage ??????
- Where are my freeze plugs?
- Metallic noise upon startup
- Hi, I'm new, opinions on synthetic oil?
- piston slap deal
- to rich for the likes of me..... Superchargers
- Need 1/4 mile times
- Powerdyne Supercharger Supercrew
- Does K&N require carb. adjustment?
- my bad Mehal........Need Cheap Supercharger.....
- Oil Filter & noise
- tap, tap, taping in the engine bay
- Holley Thunder Supercharger Kit
- swap 99' 4.2L for a mustang cobra 4.6L??????
- New Engine????
- New problem with puel pump????
- Holley Thunder SuperCharger
- ANY POWERSTROKE OWNERS- WHAT KIND OF MILEAGE?
- Won't idle in cool weather
- WON'T CHARGE, NEED HELP
- engine swap/jacobs
- V-10 Design observations
- FLOL!! 4wheel parts mag, 300hp 4.6! HAHA
- www.my-f150.com?????????
- K&N Problem
- Catback Or Superchip ??
- Temp Gauges, Engine, Trans & pos Rear Dif, Help!
- TEST!
- DEAD FUEL PUMP ???????
- MAKE A 4.6 INTO 5.4?
- What is the small "radiator" in front of the radiator for?
- How do I PROPERLY disconnect the speedometer?
- K&N, Airaid or Velocity Tube?
- Engine ID'ing?
- Idling problems caused by Too Much Airflow?!
- bi-fuel CNG
- Tritons w/ pure antifreez
- 6qts-vs-7qts Who's correct?
- Clacking noise in engine
- Engine "tuning" after all these mods.?
- Why don't we sound as good as the Mustangs?
- Cold Stall
- engine clicking
- I've had about enough
- Flowmasters VS. Straights
- Can I get any more from my 4.6?
- How many out there with Re-occuring Oil Leaks?
- Inconsistant engine performance
- "CHECK ENGINE" Light after SuperChip
- oil pressure gauge
- Piston rods
- Engine Specs
- Rusty Spark Plugs.
- Rough Idle
- Bigger Mass Air Flow Sensor
- 4.2L Performance Parts... where?
- Truck not starting!!!! need help!
- Factory exaust sound- 4.6 - 5.4
- I want more UMPH from my 4.6!
- NITROUS
- ESP problem
- Does this sound normal...or not?
- Warning New 5.4 V8 Buyers
- Only 14 days to order my new duel fuel...
- Cleaning the Engine?
- oil pressure drop
- Ford 5.4L vs. Chevy 5.3L & Chevy 6.0L - No "feelings" please.
- Electric Fan on pretty quick
- Inigition Problems
- Oil Filters
- Vacuum leak on 300 CI 6 CYC
- What is a Triton?
- Magnacharger Info
- 2001 F150 4WD Bi-Fuel (Propane/Unleaded Gas)
- amsoil
- Duel Fuel propane engine
- does anybody know the axle codes?
- Mods for Lariat 4x2 Longbed
- Didn't Know Where Else To Post...
- Fuel Injector cleaners??
- Wrecked my baby
- Its givin' it up
- Noisey Engine
- MAF's and IAB's
- Purpose of vacuum guage?
- +4s and FMS 9mm wires install
- Autotap OBDII Scanner - full review (long)
