- 98 4.6L #2 Misfire
- Installed 16 new lash adjs. yesterday, still have startup noise.
- Strange noise on shut down 97 4.6
- brown/rusty coolent????
- engine rebuild
- bbk underdrive pully set
- Need help diagnosing Engine Codes
- cylinder 5 misfire
- anybody install a tank-type engine heater?
- Coolant Leaking from exhaust manifold
- CEL won't turn on - still misfiring
- Sooo many problems with my 02 4.6
- POwer Steering Fluid leaking through cap
- MAF Removal
- Fuel filter
- 5.4 Build up
- Ignition key reset sequence of Ck Eng. Light
- 0 degrees won't keep running
- Plug wants to blow??
- and the prob gets werid...
- New Diesels?
- avg MPG?
- how do you disconnect the fuel rail return line
- no start problem 1996 F150 5.0 engine
- 5.4L Fx4 2005
- gas mileage
- How to "supe-up" an engine when on a tight budget??
- 5.4 oil pan
- Whos done a 4.6 NPI to PI Swap???
- Truck Shuddering, Need Help!!
- Oil Pressure Gauge
- 6 radiators????
- 6 radiators????
- Injectors, When to replace?
- Help with misfire codes P0300, P0302, P0316
- Whistle sound
- V6 to V8 engine sway
- SUGAR in the gas tank! HELP!
- Truck Won't start with key
- Dipstick Tube
- Diesel
- engine problems
- Camshaft differances
- need help to ID a waterpump!
- Need Help! Yep spark plug change.
- Seat belt warning chime mute?
- Aftermarket Coils For 4.6
- Buzzing noise on my '99 F-150
- found E-85
- A few maint. questions
- Changing plugs, let Ford do it?
- Buying a used truck, what to inspect/change?
- 2000 F150 - Fuel Pump Problem: Help Me! Lol
- Engine running rough
- gas milage/brakes question
- who has the cheapest JDM Electric Fan Kits
- New COPS Installed!!!!
- Fitch Inline Fuel Catalyst
- Intake part #
- resistance in an IAC valve
- Squealing noise
- Tranny fluid
- 98 4.6 vacuum leak?
- 2000 F150 Startup Issue
- How do I ditch Factory Remote Oil setup??
- rough idle, stumble in 4.6
- Trick Flow Intake Elbow
- help with Altenator problem
- alternator question
- Efans!
- Leaky Schrader's valve
- Would having an oil breather cap hurt
- 4.6l runs lean on both banks
- Injector change question
- Porting and polishing the TB
- blowing serpentine belts
- A/C in intake for power?
- Oil Change?
- Fuel Pump Problem??
- F150 to f250 engine differances
- Fan Clutch Removal
- supercharge
- anyone have real dyno numbers from their 4.6??
- Which motor oil?
- Sticky Request------->
- modified mustang mass air?
- Engine FUBAR?
- Engine randomly shuts off.
- Buying E fan 07 5.4
- Stock Idle Speed
- E-150 problem
- Underdrive Pulley Install question
- 03 5.4 power
- Thank you
- running like ****tt helppp
- Quick starter question for a 98', 4.2
- Upgrades for Truck
- 85 f150 mystery ailment
- 3V Injector size?
- Going to see danny @ Swanson tomorrow
- PCV Line collapsed= high idle
- Engaging High Beams Kills Engine
- to overdrive or not to overdrive?
- p0351 Ign. Coil A Primary Circut Malfunction
- Check Engine light goes out.
- Oil pressure/Temp Light please help
- Sudden Drop in MPG
- I did it
- Another Oil Pressure Problem
- Location of PCV elbow - (running lean)
- Its time for the rear main seal to come out!!!!
- 5.4L 3V Oil Consumption
- Dead #2 Cyl, '04 5.4 3V
- Popping From Intake
- Power Steering Issue Please Help
- Stumbling 1991 302
- this dang 5.4 cop
- 5.4 misfire sounds like exhaust leak thru COP
- 32v engine wear???
- Wrecked my truck, COP went out....
- hesitation at 35 thru 50 mph
- Do the coils HAVE to be bolted down (I stripped mine)
- ignition switch
- Motor dies in drive?
- 05 white smoke at start up
- 2006 f150 engine gone?
- Pull DTCs without scanner or programmer?
- shift kit questions
- Best bang for the buck
- Cylinder 4 Misfire
- general maintenence Q's
- E Fans Temp.
- Knocking On Cold Start In Cold Weather 5.4L
- Brown foam on oil cap
- Coolant problems!
- 96 MARK VIII Engine????
- coolant drain plug location
- Engine Shut off.
- Rattling Noise
- Upper Intake Manifold Cleaned!!!
- It's Official...I Regret Electric Fans!!
- Acceleration Problem
- K&n Cai
- under drive pulleys
- Buddies truck having problems
- Loud Squeal at start up
- fuel injectors
- does the throttle body spacer work
- Superchips?
- Lifter tick, or exhaust man leak????
- Gotta Be Freaking Kidding Me
- Starting problems..
- Heads
- engine rebuild
- P0401 - frustrating
- Coolant Burping out of overflow cap...
- Timer Sert 5553 versus ATD 5400
- Very Worried " yellow liquid dripping from exhaust"
- 2003 with 88k miles needs 5.4 motor replaced
- Possible diesel swap to an 2004 F150???
- This is a test and only a test
- max hp,ft/lbs on stock rotating ass
- 1990 XLT Lariet 300 Inline 6 Eng Removal
- Losing Power
- 96 F150 Engine shutting off
- oil filter wrench?
- Vibration/Corroded driveshaft
- oil filler cap gunk???? Need help.
- throttle position sensor
- Error Codes - Sluggish Excel. (Stall) SOB!
- Letter from Ford
- who stole my oil? Its gone
- Power Steering Pulley Play?!?!?!
- No Gas Pedal
- Mobil 1 oil change intervals
- Coolant Temperature Sensor 99' 4.6L
- Low Voltage Problem
- Engine shut off on it's own while running???
- 4.6 Power
- PCV Valve '04 Heritage 4.2L V6
- p0712 TFT Low input
- Knock Knock - Who's there?
- TPS question
- Need serious help FAST!!!
- Oil dipstick tube help
- Timing Chain Broke and piston hit head
- Please tell me what this is .... Oil related
- Tranny Issue!!!
- Governor
- NEED STOCK INTAKE FOR 4.6 2004 model
- 2004 5.4 bogs down
- serious problem with ....
- Miles out of a tank of gas..
- 98' 4.6 swap to 5.4...again !
- Bush Killed The One-Fifties!!!
- MAF sensor vs IAC
- I need info on 5.4 litre engine
- just got my truck... questions about what mods i can put on it
- Oil filter removel???? 5.4
- Super trucks
- tuttering/Power loss at 3500RPM *Fixed*
- Check Engine Light
- misfire at higher speed
- ...found on road dead
- 4.6 cutting out
- 302 to 351 engine swap in a 92 F150
- Spark plug replacement on 5.4L V8
- Coolant smell
- Will not idle(sometimes)
- Erratic idle and codes....still.....
- Oil Weight (But not your Typical "Which One" Question)
- varnished cyl. head
- Engine Shaking on Start Up, unknown cause
- 4.6L, Need more power
- Can a lightning supercharger fit on a 06 5.4
- First oil change and...
- Need Help!!!
- oil
- headers
- where can i get pistons
- OVERHEATing!!!dagas volcano HELP!!!!!!
- Engine Problem, '05 F150 V8 64k miles 2 wheel drive
- The guy at Autozone says...
- heater actin funny
- a/c removel for 97
- P1401
- Fuel Pump dismantling instructions
- Broken COP connector - replacement?
- 98 Ford F150 code P0420
- $2000 budget?? suggestions??
- oil pressure
- Looks like peanut butter under my oil cap?!
- 2005 5.4L Dying
- 12mpg for only $.02 !!!
- 10 engine codes please help
- Never jump a truck battery from a car battery?
- strange noises, help!
- broke plug . NOW What?
- 5.4 Rough idle
- Gauges
- Looking 4 best air filter kit K&N??
- engine swap
- fairly happy with...
- New to Forums: 97 4.6L 4x4 problems
- Cold weather and mileage
- Fuel mileage
- 250 km on a full tank !!
- 5.4 stroker kit??
- What spark plus & trans fluid should I use?
