View Full Version : V8 Engines
- a/c and heat prob
- Clacking noise?
- Does anyone make an elec. fan kit for 4.6 truck?
- what is TPS tuning and how do you do it?
- Engine Bay Cleaning...help
- Possible to put V10 in F-150?
- WEB SITE Specificaly for SOHC 5.4L ?
- ?s for Neal
- 5.4 or Diesel
- PI head swap
- supercharger/turbo
- Which Oil to Use
- Advice!
- MIKE IN LA HELP!!!!!!!!!!!!
- Looks like synthetic 5w20 is here
- Finally fixed my pinging problem!
- OBD II Scanner
- 5.4 vs. 4.6
- Just got a K&N air filter
- obd 2 system
- F150 4.6 Vs. GT 4.6
- what size fuel pump
- how the #### do i change my spark plugs?
- Please help with Engine trouble on '98 4.6L
- Any way to turn off the antilocks?
- Change Fuel Filter @ 15,000?
- 5.4l oil leak
- Is this true about synthetics???
- Proper TPS resistance range
- ABS System
- K&N Generation II FIPK for 97-00 4.6/5.4...$199.95
- SUPERCHARGER which one
- Blower voiding warranty work ?
- I did the Diagnostics test with the trip meter button and a code 5284 showed up ??
- 2001 radiator
- New Engine/Loaner Car Help!
- 5.4l on Desktop Dyno
- Desperately seeking help!
- Codes on Radio Display???
- radiator fiasco: good/bad dealer list
- Something to remember!!!
- 1/4 mile times of 5.4L engine?
- Engine missfire under heavy load
- K&N FIPK GEN II...where is a cheap source?
- recommendations on new wheels/tires for '01 F150
- Rough idleing
- Where to find 5W-20 oil
- 5.4 engine problems - need help
- Performance mods for a 4.6L??
- Question for ML on Piston Slap
- Possible for self-made tubing for intake?
- Check out Ford's new supercharger!
- Re-3000RPM Idle
- Fuel Injectors
- PCM code readout on odometer?
- What is the HP Gain from Polishing a stock intake.
- Problem with K&N FIPK intake tube -- help needed...
- What else?
- Battery, Alternator/Reg., Short ????????????
- Is it worth it?
- Why I changed radiators???
- searching a 5.8 esi Engine for f150 1990
- 1998 Engine Swap?????
- has anyone tried the APC intimidator FIPK?
- actron obd scanner
- Does anyone have over 150,000 on a 5.4?
- 2000-1 Speedo correction?
- Firing Order For 4.9L I6
- Towing Temps
- F150's Have Bad Starters, etc.
- 1997 F150XL V6 4.2 Coolant Leak
- Think I got piston slap
- check engne light, black smoke, miss firing,trans acting up EASY FIX!!
- AM I Losing power?
- Hesitation when hitting the gas.
- What is this?
- truck shakes like crazy!
- ProCharger?????
- Lariat Engine?
- K&N system
- 5.4 blowing smoke AGAIN!!, need help!!!!!!!!!!!!
- which mobil 1 oil?
- My Truck Is In The Shop
- mustang 302 into a 92 f150?????
- ring gear on flywheel
- oil in air filter box
- Headers on a 98 4.6
- Superchargers
- Lightning Cold Air Box for the Regular F150?
- Oil leak when hand-tightening filter...?
- Spark plugs ??????
- NEW 5.4 Heads
- 5.4 high pitch sound 1-2 shift
- Lightning in a Cobra
- What is FQR?
- Killed a Tundra
- fuel filter question
- Powrer and Brake-specific Consumption?
- specs on the 4.6l
- Wrong Battery in the 00 & 01 Tow Package 3 ?
- 5.4L specs
- Chevys great pages
- Electric Fan
- Response from K&N on FIPK performance during hot weather...
- Power Pulleys
- K&N FIPK warranty issue
- Hesitation when hitting the gas from a stop.
- How do you tell if engine is FQR?
- mix syn with dino ?
- Trailer Pkg. Radiator (Help)
- Early Maint. on my 98??
- what could i do?
- efficient upgrades for xpedition
- Oil Brand & Fuel Mileage
- Replaced Exhaust Manifold with JBA Headers
- Triton 5.4L - fourth year on the 10 Best Engines list.
- Has anyone got a straight answer about using 5W-30 in 2001's?
- Minor engine Surge
- navigator rims for sale
- V10 Mileage
- Clutch,Flywheel and Pressure Plate?
- Ford not using real gauges for cluster panel? [A MUST READ]
- aluminum driveshaft
- silver & black flareside
- Ram Air?
- what to do first
- 4.6 L oil leak/motor replacement
- Lightnings
- piston slap question
- Changing Over To Synthetic "Question"
- 4.6 requires 5w-20?
- 5.4L Specs. and info?
- WHO HAS A PRO-M 80MM MAF?
- 5W20 Oil- Who makes it???
- Y2K piston slap
- Motor Mounts
- Fans in Fords
- Where to get a replacement 5.0L
- Am I alone?
- 4.10's from Ford Racing
- Check Engine light
- HELP!!!!!
- How many cubic inches is a 5.4?
- I beat a 2000 F150 w/ 5.4 How?????
- Mods and tow rating
- Yee Haw..... Just got my Airaid FIPK
- Amsoil Introduces Its 5w20 Motor Oil
- Engine Flush
- 4.6 vs. 5.4
- Intake mod. opinions? (Put cone on end of K&N drop-in.)
- Oil on "D" side oil pan bolts?
- What the heck do i need to do the job? come on you Lightning guys
- Burned my motor down
- What exactly is a TSB???
- Mobil not gonna make 5W-20 synthetic anytime soon.
- 3000RPM Idle
- Pics of engine!
- 98 EXPEDITION CODE P0171 AND P0174
- Battery not charging. Help!
- I hate Chevy's!!
- Need Help with Next Mod...
- Which air filter?
- 4.6L LACKING POWER
- Need pics of electric fan install: Flex-a-lite #250/260
- 1998 F250, need help identifying a couple of things
- Motor-Up, Prolong, Slick 50...worth it?
- Help, PLEASE!!!!
- Y2K Ford Piece of Sh*t!! Help!!
- Bosch Platinum+4 plugs cause engine damage?
- Went to the Track for the first time.... I got #'s
- Advice on 94 5.8 liter engine
- Some questions on the 4.9L
- engine leading oil from dealers.
- Looking to buy and build 150 XL
- I'm was told my motor is ruined....help
- Detonation
- Question about the 5.0........
- cam compatibility question for 1992 302
- How do you know if it's Romeo or Windsor?
- ATTN: Old Timer
- Ford Platinum Spark Plugs--Anyone get over 100,000 miles on them??
- Dealer Says K&N Caused Belt Noise
- Tundra Problems site?
- what does your 5.4 get for fuel mileage?
- Low Idle with Air Cond. running
- Neal more questions for you
- Fuel Filter
- Corrrect idle for 2001 4.6 ?
- heater coil???
- ??Chevy problem sites??
- Lightning engine swap
- F*#^in Header Gaskets!!
- Engine Miss/Dies
- Inaccurate speedometer!!!!
- 2000 Source book
- supercharger info
- Fuel Filter Dilemma
- Question about the 5.8.......
- radiator
- INSIDE INTAKE
- HOW MANY MILES??
- Test
- Installing A/C
- shakey cold start
- Engine noise when shifting.
- v6-v8 swap
- Maybe my truck isn't so bad after all...
- Dumb oil question
- Mike I need advice!
- please help me
- 1401 Engine Code
- what do you think of a 1997 ford f150 extended cab 3rd door 2 wheel drive
- 5.4 oil leak and out of Warranty !#@!
- TPS setting on 4.6, what is yours stock?
- High Idle when cold - now Check Engine...Help!
- Weird truck problems
- What's this!!!!!!! Built Ford Tough ??
- Synthetic Oil
- 5W20 Oil???
- V8 or V6
- Getting rid of "high pitched" whistling noise from K&N FIPK
- SMOKE!! PLEASE HELP!
- oil on frame, crossmembers,block 99 5.4
- water run out tail pipe
- Pinging '98 F-150
- How many gallons are left when the "low fuel" light comes on?
- 5.4 Engine cold start knock
- TPS Mod
- Gasoline, what brand do you use?
- good laugh
- superchip codes
- First real competition
- Do I have a tow package?
- TPS mod (mine was already at 1.286???)
- An observation
- My 4.6 is only getting 12 MPG
- My 4.6 tops out at 95?
- Engine Temps
- Intimidator Intake
- Powerdyne Charger
- 5th wheel?
- why does battery icon come on?
- Jacobs ignition on 4.6L What is involved? Is it Worth It?
- Hey Neal...need your opinion please.
- Dodge Dakota in a race
- 2001 4.6 horsepower
- Another 99 5.4 Oil Leak
- Which spark plugs?
- Urgent to every F150 Owner! **PLEASE HELP**
