View Full Version : V8 Engines
- Help with piston slap??
- Ford recalls some 2001 police/fleet vehicles with 4.6:possible coolant leakage
- 1997 F150...diagnostic code 0412, coolant leak, no heat
- need help!
- High idle
- quaker state synthetic blend
- Cold Ram Air intake
- Most Engine Mods Worthless?
- airraid
- Hissing sound
- inline six troubles
- Ford Quality, where is it?
- 4.9L engine replacement
- 3 water pumps in 12000miles
- Thanks Subsribers for 20+ Hwy MPG, Rough Idle
- rough idle phone call!!!
- are these trucks worth anything????
- More power
- 75mm throttle body sucks
- soliciting help on a 5.4L
- For Neal thfreak re: next mod
- SUPER CHIP
- how much $$$?
- Where is the Redline
- 98SCREAMER
- Front Bumper F-150
- Good experience with oil change place!
- MUstang parts on f150
- abs brakes
- Can anyone break rubber w/ 3.55's
- Getting New Engine
- Hi, new guy here
- Has Anyone.......
- 5.4 leaks more than once?
- Where to get 23-tooth speedo gear?
- Would 4.10 gears make a significant difference over 3.73 gears in a 1/4 mile situatio
- Radiator and Engine Tapping Question
- Need help guys
- Smell of antifreeze when fan motor is on?
- Power steeting unit nitemare
- ? for Valvoline users..Dura-Blend vs MaxLife
- Need Help Diagnosing Engine Problem
- ROUGH IDLE OR NOT?????
- Free Radiator with purchase of Supercrew
- First oil change, trials and tribulations.
- '88 F150 4X4 will turn over but not start???
- Ford Bashing
- fuel pump keeps running
- Be Careful what you post/emails from ????
- NEW!!! 2001 King Ranch
- Best Synthethic Motor Oil?
- long tube headers
- pulling 2000# boat will I get better mileage w/OD off or ON ?
- o2 sensors when putting on headers
- when do i change my spark plugs?
- Best, most current TSB site?
- Burning Oil!!!!!!
- Custon FIPK
- Buying a 1997 5.4L 4x4 extended cab
- Switched to 180 degree Lightning thermostat...any possible porblems?
- k&n gen II kit
- Blown Brothers, NOS...is it possible??
- just got back from towing, elec fan update
- Which type/brand of spark plugs for a 4.6L?
- More on not so super "Super Cooling" package
- advice on trade
- K&N FIPK Whistle HELP!
- Anyone using Power Pulleys?
- NEW RADIATOR ON THE WAY !
- XLT EXTENDED W/SUPERCOOLING ON ORDER
- Mobil 1 or Motorcraft Oil Filters???
- fuel system codes
- Helix Power Tower
- Oil on spark plugs
- K&N air filter change
- How does my burnout compare to yours?
- Filter Injection Performance Kits
- Mileage
- water pump 4.6 help?
- MPG Increase with FIPK,'s, Velocity Tube?
- New radiator
- New Radiator Situation
- check engine light (yet another one)
- Kenne Bell Blower Update
- AIR FILTER FELL OFF !!
- 5.4 L Tapping@1st startup
- oil cap
- 2001 4.6L 240hp
- How do you calibrate speedo. for 4.10 gears on '97 4.6L?
- MagnaCharger Question?
- Stock Air Box
- Need help selecting a chip?
- Exhaust done....what's next?
- Service Engine Soon
- Mobil gas
- Warranty/Piston Slap
- exhaust issues
- Super CHip
- Update: Pinging '98 F-150
- Supercharger lacking power
- Put this in your gas tank.
- '97 4.6 F-150 leaking coolant below thermst
- dont need a locking gas cap on new model Fords
- No Guts with AC Compressor engaged
- Horsepower 2002 5.4
- It came in!!
- Time for a locking gas cap?
- Smoke After Oil Change
- fuel filter
- Poor Performance Now That It's Hot
- Could the oil filter be ANY tighter?
- Lightning Engine in ORP????
- Location of TPS??
- next mod ?
- Is PROLONG Engine or other aditives good or bad?
- I need Ford confidence
- advantages of EFI over carb?
- rear emd
- Need Advice On Ext. Warrenty Purchase.
- FORD did a oil change
- Which synthetic oil???
- REDLINE
- Picked up my new SCrew today...Radiator Question
- HELP!!! My truck is in for head gasket replacement!!!
- Check Engine light -Fuel cap?
- Platinum Spark Plug ruins Cylinder Head
- best exhaust for 5.4?
- Efficient Oil filtration Recommended
- 4.6 power
- What is the best way to break-in new car for best performance?
- Airbox mod's PLEASE HELP!!!
- Warranty running out soon, what should I look for?
- '01 Alarm instaled on F150 '85
- Oil Leak On Pan, Going Back to Dealer Tomorrow.
- 4.55 to 308
- 2 Strange things on 1st Oil Change
- O M G !!!! NOT G00D .........
- FIPK install pictures, trying to deside on one
- Draining the radiator
- Another Airbox Mod. Question.
- Dynos in north central Ohio?
- Velocity tube?
- "PI" Heads, attention Neal & JMC
- Thank you contributing f150 online members
- Bosch + 4's
- 60,000 mi tune-up
- radiator upgrade
- OBD-II scan tool - Getting a STEADY light ?????
- Wrong Rad on 2000 F150
- HELP K&N or airaid?
- Want to increase your gas mileage?
- Gears?
- Redline 5w20 synthetic oil
- F-150 vs. F-150
- 98 EXP. TROUBLE CODE P0171 & P0174
- Rice burners
- Going to the track to run my truck tonight!!
- 4.6L engine ticking sound
- where to get info on older f100's?
- The Meaning of "Yeah, That's normal"
- Poor mans turbo
- 5.4 Smoke???
- X Plan...how much again??!!??
- I just checked the rear diff on my 99 F150 w/9000 miles
- In-line 6 mot0r
- Just spoke to my Ford service mgr re: problems between 1999 4.6 and 5.4 also read thi
- Qualified best oil
- I say not
- O2 sensors
- 94 F150 5.0 with bad pinging? Please help.
- Oil filters...what's good.
- Please help! Blowing starter fuses like mad
- ???19 MPG WITH 5.4L ??? THATS BULL!!!
- What is the next best oil filter???
- 5w20 at Walmart.
- Need help PLEASE today, Is this a good deal 1999 XLT for 1999 Lariat...
- Amzoil and Piston Slap
- Fuel pressure regulator
- Need 460 Fuel injected help
- Auto and Manual Trans???Horsepower eater!!!
- Radiator exchange done-now the tranny cooler
- Rough Idle
- K&N FIPK . . . really sucks . . . !
- TSB'S AND RECALLS
- jstang
- Drain your OIL
- anyone towing with 3:31 ratio rears ? will this be alot worse than my 4.6 with 3:55's
- WMS Velocity Tube VS Air Force 1
- rebuild kits?
- fan probs need help NOW!
- Lifter noise on start up!!!!!
- TOO MANY MILES ON 99'...they said
- Speed Limiter??
- what can i do to get about 260-280hp?
- New Airaid Intake
- Air Force 1 air intake system
- Belt Squeak Resolved. (Must Read)
- HELP - Dangling parts
- re: gear ratios
- GM Duramax Woe's
- Turbo race engine in Mustang 1800Hp
- V-6 Diesel in New F-150's Great Mileage
- ? on Rebuilding a 2 BL Motorcraft Caburator
- How much Stock HP in 4.6L
- Hesitation at 1800 rpm
- Need Feedback on the WMS Velocity Tube...
- Fuel tank size
- 2nd head gasket leak on 5.4 w/in 5k miles
- 4.6L s/c
- exhaust
- Where can I buy a crate motor?
- Just replaced # 4 coil pack
- Living on rice and water to pay for truck?
- Oil change warning...has this happened to you?
- Do Mobil 1 filters have anti-drain valve?
- 2001 4.6L Oil Leak? Need opinions.
- High pitch whistle
- AirAid Installed, One Question?
- ENGINE STALLS
- Need a Ford Engine Tech....
- WRONG RADIATOR AND DEALER WON'T REPLACE IT TRY THIS
- 5W20, knocking, warranty
- Blown Motor @ 85k
- A question for SUNDAYNIAGARA69
- 4.6 V-8 in 1998 F-150
- Whasup with the Fan Pulley?
- Does anyone make a supercharge for a 2000 F150 V6
- BigBadRedLiftedFordMan
- 5.4 engine
- need help!@!@!@!@!!@
- Thermostat instead of Superchip
- K&N Cleaning & MAS filiment?
- i have a quick question
- look
- Is it true the Chevy 4.8 has 270 HP , whats my 4.6 got ?
- power steering
- 351w for sale
- decisions decisions...
- I've got a baaaad feeling.....
- engine knocking
- K&N FIPK and Waranty ?
- AMSOIL synthetic motor oil?
- 5.4 HP
- Oil Filter Question
- HELP? anyone know this code?
- Too much air or not enough fuel?
- How to identify a 428 FE v.s. a 352/390 block
- supercharger
- Hey JimWright
