View Full Version : V8 Engines
- MAF mod underway!1
- Another Check engine light.....
- starter issues
- Whats with the high idle?
- Fuel Filter
- Starting hesitation (4.6l)
- How many miles can I expect from my 4.6?
- Horsepower on 99 5.4 and 01 5.4?
- Need help: New truck needs new engine - what should I do?
- Can Any One Help
- Ruminating About Radiators
- 5.4 won't maintain idle
- Idel adjustment on 5.4 Screw
- Wrong radiator
- Lightning 90mm MAF work?
- Whats a safe oil temp?
- gas in carbon canister
- Rattling Noice when Accelerating
- Trasko Oil filter
- Ok "guru's" What is the mileage diff. between overdrive and drive ?
- 4.6L SOHC to 4.6L DOHC ( NEED HELP !!!)
- Timing question
- 100,000 yesterday
- Engine build up advise
- tick when motor first starts up
- ford f-150 stalling problem
- Mobil 1 question
- Electric water pumps!
- 5w-20 Motorcraft Synthetic Blend replaces regular 5w-20?
- possibly a weird q
- Mobil 1 not enough detergents ???
- 1999 Fuel Injectors 19.24.30 lb
- V10 chip??? anybody install one
- is there a way to test coil packs
- Largest possible swap
- Anyone running JET power pulleys?
- Temp. Sending Unit
- shaking and hesitation on throttle up
- 8.1L Avalanche
- JET Powertech Performance Module
- Helix Power Tower
- ready to order with x-plan
- Troubleshoot this one.....
- 5.4 Triton clicking
- What is up with the Belts?
- Double Oil Filters
- 1997 4.6l triton engine horsepower?
- Need Help! "Service Engine Soon"
- power increases
- CONVENTIONAL VS SYNTHETIC (here we go again!)
- K&N Filter Question size??
- Engine Horsepower
- automatic engine oil primer
- 4.6 Power Change
- Oil Filter on too tight
- I've come to the conclusion that K&N Sucks...
- 01 5.4l Blue Smoke on Start Ups
- How oftern do you clean your K&N Filter?
- I've got it too!
- 4.6L Oil Filter
- Asp Power Pulley Fall Apart!!!!!!!!!
- diesel f-150?
- Holley Power Shot air filter?
- Rattling Noise on Cold Start
- Horse Power
- Winter Blend Differences
- Superchip on a 5-speed?
- AMSOIL dealers...need info
- Engine Flush?
- K & N filter replacement
- Weird idle or my imagination?
- What year?
- Hipo 5.4
- Can anyone help with ticking noise?
- Hesitation at acceleration
- 4.6 vs. 5.4?
- I heard that there is an F-150 radiator class action suit
- Has anyone installed a Helix tower of power? If so did you see any improvments?
- Fuel Filter
- AMSOIL 5W-30 or 20W-50
- cams or heads
- Swapping 4.6 into 4.2, can it be done?
- pining under light acceleration
- engine noise
- When was my truck made?
- Stalling after battery change
- Intake Silencer
- Pre-Luber
- Synthetic Oils
- airraid,kn.airforce, which is best?
- Advise for buying high mileage 92'?
- Piston Slap - I've got it!
- Where is the Engine Code?
- Cost of truck
- Towing with wrong 1.02 radiator
- flex fans
- Chip for 4.6L
- RECALL: Wiper motor
- Microchip in key
- Header information.
- Oil Leak
- Heads
- 5.4 equals what Cubes?
- Not just 4.6 rough idle, check this out.
- Truck shudders at 1500 rpm's
- A/c Pump Bearings Gone??
- I found new headers
- A/C Temps different ???
- 5W-20 synthetic from the factory?
- Who makes Motorcraft's new 5w-20 synth. blend?
- 4.9 litre 300 6
- Scan Tools
- Odometer Codes
- power steering seal leak
- New to this forum...leaking heater hose fix?
- Rough idle on 1999 5.4
- I finally did it...I GOT MY NEW TRUCK!!!!
- what e.t.?
- Follow-up 5w-20 Oil
- Radiator Nirvana!!!!!
- Regional Rep Phone number?
- Fipk
- Engine Stumble at Initial Start Up?
- noise after washing engine
- F150, 4.2 Engine Trouble
- Ford engineer says "OK to use synthetics"
- 5w-20 weight...what?
- Need some experiance
- How much $$ for machine shop work?
- Dispute Settlement Board
- supposed ping solution
- Superchip
- Easy But Effective Mods
- Anyone Make A Tb Bigger Than 75mm???????????
- Getting rid of the Governer
- Accel Coils
- oil pressure sensor
- FIPKs, Heat, and all that jazz...
- 99 5.4 HP rating
- Air Raid Vs. K&n
- Anyone in So.Cal had their 1.02 radiator replaced?
- Ignition Switch
- Hot weather hesitation solved.
- Not enough oil, or is the dipstick too short?
- FIPK and dealership service dept.
- Question on ASP pulleys
- Dum question on oil change.
- To much tranny fluid
- 4.6 engine knocking
- getting ripped off? (chevy question)
- Ignition ???
- US, Canadian Tow Packages are Different
- Looking for the Texas Ford guy who sells cheap ESPs
- idle
- engine miss
- F150 vs Silverado vs Ram vs Tundra (a Review)
- Synthetic Oils
- Engine "tick" and hesitation
- WARNING Mobil-1 Filter users
- 94 vibration
- Can't remove spark plugs help!
- Question about superchips for my new truck
- more power
- Oil Change Interval Using Synthetic
- How worthy is a 351M in regards to........
- 5.4L Oil Filter cross reference
- rattling noise at approx 1800 rpms.
- Left Oil Fill Cap Off; Check Engine Light ON
- Ford settles ignition lawsuit
- piston slap wav file
- What damage did I do with running 12qts. of oil for 6k miles???
- 1/4 Mile times?
- attn:rice haters
- How do you pull the slack in the throttle cable at the pedal?
- Where are the grease zerks on an 01 SuperCrew??
- The end of MTBE in CA
- engine parts online
- does the A/C really affects gas mileage?
- 4.6L design flaw?
- Heater Core
- FMS 9mm Wires and Ford Double Platinum Plugs
- Is there an easy way to improve HP?
- engine removal
- Best/Custom Ported or New Performance
- Which size radiator do I have?
- diferences between a 1997 4.6 and the earlier ones
- Concerns with M. Troyer-perf center
- Finally gonna get my dream truck!!!
- 4.6L engine reliability
- 3" Performance Accesories Body Lift
- Engine Starts then stalls intermittently
- Eratic speedo needle and weird shifting. Any ideas??
- Remote oil filter question..
- V6 - V8 Engine swaps
- coolant flush: one or two drains on block?
- Best Oil Filter?
- check engine light...
- California Fuel Fiasco
- Switching from EFI to carb
- Installed Electric Fan and WOW!
- 2.2 Radiator
- Shaking AND Vibrating....
- Its not a F150 but....
- 5.4 V8 in a 2WD RegCab
- 4.6l V8
- `Guys I need some help, Big Time!
- 2001 Expy 5.4L, Superchip, Airforce 1, Gibson, Y connector!!
- Longer lasting coolant
- Underhood Temps.....Big Difference in Performance
- Brake-shift interlock problem on 2001
- EGR sensor
- Does anyone know?????
- Tell me I'm Crazy
- 5.0 for the new body style F150
- 4.6 changes between 1999 and 2000
- Consistency
- Slight hesitation in 5.4
- 4.6 Tire smoking??????
- service engine soon light
- Air Box Mod
- Check Engine Light On!!
- How do you keep engine from racing when first started
- 5.4L missing bad during accelleration (Help!)
- Questionable Engine Problem
- Lightning engine on ebay
- Pistons welded to bore...friend's car
- What's this Gen. lll and Gen. l stuff
- A/c
- 5W 20 oil
- Bad idle is gone!!!!!!!!!!!
- oil in air filter box
- Engine light comes on.
- rough idle & bucking
- HELP! 4.2L Surge @ 73 mph
- Wrong MAF sensor??
- maintance 200,000kms
- a ford with a heartbeat?
- Need Help! Short Question on Engine.
- Here she is....
- need opinion on purchasing a 2000 leftover
- Whistling sound w/ Afraid TBI Spacer
- Why so rich?
- Newbie here!!
- 97 302 conversion
- inline 6 300 ci performance mods
- Air mod
- Ratios
- Speed limiter ?
- Fuel Filter Problems
