View Full Version : Engine
  1. What engines swap easily into a 98?
  2. Sorry to bring this up.... Spark Plug???
  3. Whining at start-up
  4. 2000 F-150 VERY hard to start! HELP!?
  5. chirping
  6. Cooling lines in throttle body
  7. 97 4.6L oil change
  8. DTC codes P0171, P1000
  9. engine
  10. Holy Crepes! - 2005 blow engine - 63k
  11. Block Casting Code
  12. 4.2L Swap to 4.6L or 5.4L???
  13. What's the skinny on oil??
  14. 97 4.2L Hydro lock, what’s next?
  15. Low engine RPM..good/bad?
  16. Idle on 1990 5L engine gone crazy
  17. mystery engine probem
  18. 351 Windsor/transmission match ??
  19. EGR Valve
  20. air-fuel temp gauge
  21. PI top end swap
  22. Good COP . . . Bad COP
  23. P0128 code
  24. 4.2L engine swap
  25. Who's valves rattle?
  26. Need Some Help
  27. Need Some Help!!!
  28. engine oil level
  29. Aftermarket 3V cams question
  30. Part number?
  31. lOST POWER
  32. cant trace leak, have nice smell. help
  33. 3 Valve spark plug removal pictures
  34. how do you remove the lower radiator hose?
  35. 5.4> Hemi
  36. Still Got Hesitation
  37. Supercharging a stock engine
  38. Removing THe Exhaust Manifold Tube
  39. stock 2002 internal hp
  40. underdrive
  41. "Normal" Oil Consumption
  42. 1997 4.6 leaky radiator loud noise
  43. Cam question
  44. Best place to buy plugs?
  45. Squeaky pulley/belt?
  46. '99 F150, 5.4L V8: Max Fuel Pressure?
  47. miss in engine??
  48. exide battery trouble?
  49. no spring in replaced COP... lucky?
  50. How do i know if my truck is running lean?
  51. 97 F150 will not turn over
  52. starter problems
  53. Help, truck will not start!
  54. Are these any good?
  55. Adjustable fuel pressure regulator
  56. another misfire thread ...
  57. Oil Filters...Hope this helps
  58. Working on P0171 but have a ?????
  59. Bolt on 8-15HP
  60. Dodge's new 09 Hybrid?
  61. 2008 F-150 Lariat Limited abysmal towing capacity!!
  62. still hesitates
  63. Fan Clutch
  64. 1999 f150 Coolant Temp sensor Location
  65. 5.4L Spark Plug Removal article.
  66. help with engine swap 1999 5.4L
  67. sorry about this post, but no one is helping
  68. Wierd One...Need Help with Knock
  69. Tapping on Start Up
  70. Is there something weird about E-85
  71. My kid tore it up !!
  72. 1997 F-150 no start when cold
  73. OIL story, little long
  74. Just changed COP,s and plugs(few tips)
  75. 07 STX 4.6 rough idle
  76. squeeky belt
  77. slight hesitation
  78. 3V Clacker!?!?!?
  79. Interesting conversation with my dealership regard 5.4 plugs and carbon buildup.
  80. lean cyl#2
  81. Willl a 4.6L intake fit?
  82. 01 F150 4.6 Truck Jerks alot, P1401 & p0300 are codes.
  83. Hello to all
  84. bent harmonic balancer
  85. big problem
  86. 04's first code!
  87. f 150 blower
  88. takes a while to warm up
  89. Spark plugs
  90. po102 still on.
  91. i go lean ???
  92. Is this possible?
  93. Check Engine
  94. Ok, so I cleaned the Throttle Body on my '99
  95. Head Swap Help Please
  96. Countdown to launch?
  97. 2001 F150 won't start
  98. Reverse flow or conventional flow?
  99. intermittent hard starting - COPs weakening?
  100. pls. help me figure this out!
  101. Fuel Injection to Carb swap..'95 F-150
  102. There's that ticking question again...
  103. Can't pull codes from truck
  104. faulty ignition relay soleinoid symptons?
  105. Catapillar does F150 Diesel studt
  106. Replacing injectors?
  107. Blinking battry light on dash near 2200 RPMs
  108. lean codes 171 and 174
  109. K&N oil on S&B filter...
  110. Is this bad???
  111. Which one - block, pan, plug heater?
  112. 4.6 redline?
  113. Cannot decide on which fan
  114. It may sound crazy but i think its possible!
  115. One more question
  116. bad injectors, coil packs, plugs, broken plugs all at 30k miles
  117. PCM Flash, lost power and millage
  118. engine start-up mystery-please help
  119. when is it time to change the O2 sensors?
  120. Spark Plugs and Seafoam
  121. Summit Racing UD Pulley Install w/ pics
  122. Project BULLETPROOF...dream or reality?
  123. "Thanks fellas"
  124. 2005 fx4 60k mile check up? just need some input
  125. '03 5.4 Vs. 4.6?
  126. Key Starting Problem At Times
  127. starting porblem..help fast please
  128. Changing C.O.P'S
  129. 2004 5.4L Engine Issues
  130. I searched...
  131. Another Serpentine Belt Question 99 F150 4.6
  132. AF1 vs. VOLANT
  133. engine missing
  134. Engine or Tranny? Chatter when in gear and rev'd up
  135. 5.4L to a diesel
  136. Just Purchased New 07 F150 4x4 Screw 4.6
  137. Sport
  138. PI swap for 4.6
  139. 03 4.6 Has A Miss
  140. 2002 4.6 smashed sparkplug
  141. 2006 5.4 HP ratings ??
  142. What else should i replace?
  143. 3.0 ranger engine swap
  144. Revs up in gear and In park/neutral!!! Help!!
  145. performance probs???
  146. humming noise??
  147. spark plug rounded threads
  148. plugs and wires upgrade!
  149. EcoBoost gas turbo direct injection
  150. 4.6l tuneup
  151. Driving With a misfire?
  152. Just pulled the first plug from my 5.4 3v...
  153. ebay find cop cheap
  154. High idle, rough running
  155. 2009 F150 Article
  156. Throttle Position Sen. Values
  157. Have codes
  158. 1972 400 2v cubic in Ford.
  159. Idle Speed
  160. ac clutch
  161. New f150 engines
  162. 331 stroker kit
  163. Synthetic or Conventional?
  164. Engine won't start up
  165. Get your owners maunal for 1996-2008
  166. egr pressure sensor
  167. code trouble help please
  168. How much oil?
  169. Engine tapping/noise
  170. need help with motor!
  171. 99 4.6 misfiring
  172. Oil Cap and Neck Milky Looking Sludge
  173. engine swapping/upgrades
  174. 4.6 DOHC in a F150
  175. Time to embark on custom turbo kit!!! (long)
  176. MSD Coil packs???
  177. Coolant bridge / coolant crossover tube
  178. lifter noise
  179. P1131
  180. warranty ?
  181. Rpm Surging
  182. longggggg post (sorry)
  183. Plug changing tricks?
  184. throttle body cleaned nice!!
  185. and another light comes on
  186. 1986 F-150 control module
  187. 2009 f150 6.0L diesel?
  188. Intermittent Starting Problems on '01 4x4
  189. water crossing...
  190. 98 f150 4.2L V6 Gas Mileage?
  191. Strange Idle
  192. do I really need to use 5W-20?
  193. drive cycle
  194. Good Truck Log Software?
  195. No codes 4.6l has died
  196. 97 F150 running rough when started
  197. need heat
  198. help with code P0171/P0174
  199. P0406
  200. 02 sensors disconnected
  201. 2000 Ford Lightning Engine Change
  202. P0171 Code
  203. First Start After Oil Change Is Rough ??? (2004) - PLease Help???
  204. egr valve??
  205. '94 F-150 300 straight 6
  206. 250,000 miles 5.4, may need new engine...
  207. throtle body cleaning o5 f-150 5.4
  208. oil in spark plug hole
  209. Smell antifreeze but no leaks and no fluid loss
  210. 05 fuel injector problem
  211. Will someone tell me about underdrive pulleys??
  212. One of my Troyer fans died
  213. Meizer water pump
  214. These cop's are 2 year warrenty, anyone bought from them?
  215. 13-14mpg?!
  216. Plugs keep backing out
  217. PS pump problem
  218. Cycling compressor & seeping headgasket.
  219. whats left to add power to my 4.6?
  220. My Mark LT is a turd
  221. 99 f150 won't start
  222. whic cold air intake for the 5.4l
  223. o2 sensors
  224. Mileage On Serpentene Belt?
  225. Global COP's model differences
  226. Help with posting 02's - anyone
  227. Sorry guys, but I have to ask...
  228. Low/Rough Idle
  229. Oil Filler Cap, Snapped?
  230. Engine still misfires
  231. F 150 engine start problems
  232. Aluminator
  233. Hesitation...still!?
  234. Engine Wear VS Viscosity
  235. So it's time for a tune up *help*
  236. Intake Manifold Runner?
  237. Changing to a Different Weight Oil???
  238. No Factory Reomte Start?????????????
  239. freeze plug size in a 4.6L?
  240. Oil Change
  241. Junk Yard Airbox & NEW K&N Filter Gasket !
  242. Sohc 4.6l ?
  243. I need a radiator
  244. Oil filter O rings?
  245. Need help - drive by wire
  246. 7qt oil pans for are 4.6 5.4's?
  247. MAF cleaning question
  248. starting problem
  249. How do you get the camera link to your gallery
  250. Bucking when accel slowly or give lil gas
