View Full Version : V8 Engines
- Failure on coil pack #4 - info needed
- What is Ford's response to common problems?
- Any one put a 4.6l in an 85F150
- Remove spark plug and coil.
- 5.4 and 4.6 heads the same?
- Oil Pressure/Pump Question
- remote oil filter line leaks
- engine swap outs
- Gas mileage..
- Phenolic TB spacer? (NOT the darn Poweraid...)
- Any Tips??
- Castrol Syntec VS Mobil 1
- Fuel Milage
- My 92 has a miss
- loud clatter at idle
- New Motor Cold Knock
- Zex Nitrous Kit
- Sick 4.9L
- antifreeze smell
- Price paid for spark plug wires!!
- Help !!!
- Rolled over 50K now what?
- Surging at stoplight
- 4.6l Oil Leaker
- Error code 653?
- 5.2 vs 4.6
- WARNING for all FIPK owners
- Magnetic drain plug
- Engine Noise!!! GRRRRR!!!
- puff of smoke?
- ? Lot of rattle on start up?
- Bought Autolite Platinum Pro Plugs, which wires to buy?
- V-10 Swap in F-150???
- 1993 F150 Xlt 4x4
- Coolant Capacity with New FOMO Radiator
- F-250 more hp?
- Nowhere
- Big Engine
- Synthetic Oil
- Check out this virtual dash.
- grrrrrrrr
- 538 code
- When should I replace the EGR?
- Bad milage drop.....
- Granatelli MAF for 4.6?
- How do I know...
- Punctured Radiator!!!!!
- Airforce 1?
- Dealer Put In Free Engine Same Problem
- When to change Oil the first time.
- 4.2l running lean?
- engine spec
- query on '93 5.8 Liter
- I need some motor experts
- Airbox Mod explained (includes diagrams)
- Info on Mobil1 from Mobil Corp (5w20)
- Ford Disease
- Hhhhhhheeellllllpppppp
- I Need Your Help (Please Read!)
- Thinking about buying a f-150
- vibration at pullout
- AMsoil vs Mobil one
- Oil pressure light
- Complete Tranny Fluid Change!!!!
- Top Speed of Stock 2000 5.4 F-150?
- Airaid Kick Butt!
- squeeking/rattling blower motor (HVAC)
- Great deals on Steeda Parts....
- OIL on SPARK PLUGS (passengerside)4.6
- How to change the fuel filter?
- header competition...
- What size is MAF on 99 Expedition?
- Fuel Management Unit?
- Question on aerodynamics
- MPG.............3.55 vs. 4.30 gears??
- FQR Engine Reliability ??
- WTB: Airbox
- cold idle problem
- Burning Electrical Smell in cabin
- Where to buy the AirForce 1 FIPK
- Check Engine Lite
- oil filter relocation
- F150. No oil pressure in 4.6. Knocks.
- 5.4 liter engine pistion slap
- Puff of smoke
- engine chatter
- Help - My '98 5.4 Expy will not start
- System is too lean?
- Which ignition do we have?(1997 4.6)
- Take a look at this ebay auction!
- P0174 Problem solved.
- What material are the 5.4 heads made of.
- vibration from 5.4
- Need Engine Help!!!
- 380 HP "Optional" V8 from Ford
- K&N, Flowmaster,....now what?
- error code P0125
- Don't Laugh..Poweraid
- Headers
- 5.4 L Engines
- underdrive pullies!!
- expedition 4.6 oil leak Help!!
- flushing radiator
- Oil Gauge falling on startup
- waking a sleeping engine
- Trapped in Conn....need immediate help!!
- Nitrous Anyone
- Whistle at 2500RPM
- rough idle
- Spark Plugs
- Hey Hayden Fan Controller Users
- Ford 5.0
- diesel sounding on startup??
- My truck wouldn't start
- 0-60mph 4.6 5spd vs 5.4automatic
- fast idle
- Anyone want a free 5.4 in Houston?
- A REALLY silly question!
- User maintenance question. Newbie alert!!! Cross post from V-6 board.
- This may sound stupid..
- Error Code HELP!!!!
- 0-60 times, need your input
- Thanks for the suggestions
- 5.4 loss oil pressure
- Rear Wheel HP Theory 101
- What kind of fuel additive was that again?
- new spin on old debate-FIPK's
- 4.6L 5spd VS 5.4 auto 1/4 mile
- Cold Air Intake Question???
- I know this is a tired subject, but oil filter suggestions.
- a good muffler
- rad ance from ford and there pissing me off
- Smokin 4.6
- Spark plug question?
- New Engine
- Airforce One certification
- engine codes
- Can we stand just one more discussion on K&N filters?
- F150 oil pressure/pump problems found
- helix throttle body spacer
- 1997 Check Engine Light
- 5.4L Piston Slap
- air box mod
- Engine Replacement Questions??
- 5.4l
- Oil Change Intrevels w/Synthetic
- 2002 5.4 Head Leak Problems Straightened Out?
- What the average mileage for a Xcab 4.6?
- head gasket under ESP?
- Your worst MPG
- 7.3 L Powerstroke, Are They A Good Engine?
- Trouble Code P0174
- Dodge's slow 5.9 R/T....?
- zMax, what do YOU think?
- Help..'01 SuperCrew won't start....
- help
- Can We Go Here Again?
- Anyone know os these?
- 5.4 oil leak again
- Tug-of-war with F-250?
- Not again... V8 vs V6
- SVT Lightning...
- Burning rubber smell . . .
- Mass air flow Aftermarket question
- Anyone have Warranty problems w/Intake
- How do I trigger the odometer display?
- Okay, so who won???
- litre - cubic inch conversion
- 4.2 engine noise, clicking lifter sound
- Troubleshooting Code
- Dnag....Already have 11,000 miles
- Funny engine/tranny problem
- V6 goes down tonight
- Raced a 2002 Dodge...
- 97 f-150 bucking between 70 and 80
- Best Spark PLugs......
- Sudden milage shift (lost 40 miles a tank)
- 4.6l
- belt & idler pulley
- Great webiste for 4.6L performance parts!
- Howdy Ags!!
- Ford is no longer replacing 5.4s w/PS
- Any diff between 5.4L and 4.6L????
- 93 Lightning cam trouble.
- Which spark plug to use???
- spark plug change-out
- swap a 4.6 for a 5.4????
- once gas light is on
- timing chain, gears etc.
- 18-24 mpg
- Fan whine
- 99 F250ld What Should I Do
- Rattle at start-up?
- Engine Knock
- loss of power and fuel consumption
- Cobra 4.6 parts in F-150?
- Should I run synthetic??
- 5.4 in the F150 and F250
- Rough Idle
- exhaust manifold noise?
- Thinking of trading Screw.
- Help with rust
- REBUILT FORD 5.4 Long Blocks
- Another radiator question! :)
- Adding Prolong or Duralub engine lubercants.
- 5.4L problems??
- slow ideal
- fan from 95 camaro?
- MPG Diferrence 4.6 VS. 5.4
- EEC-IV Codes
- Lack of engine power?
- mass air sensor upgrade problems??
- Noisey Startup
- Real Oil or Synthetic Oil
- squealing noise
- Need help w/ ping
- Oil On Underside Of Truck.
- interesting to read..........................
- Rental Vehicles & Warranty Work
- AirForce 1 intake?
- SuperCrew Oil Change.... Easy.....I Think Not!!
- Who uses the Fumoto Oil Change Valve?
- Sweged in tube on 4.6 intake - leak
- Engine (dyno 2000)
- used engines
- Location of PCM
- Stock Air Box Modifications?
- 2001 5.4L Head Gasket Oil Leak
- Steeda UnderDrive Pullies
- My Neighbors Are Giving Me The "WTF?" Look.
- open v. limited slip v. lock differential
- oil pressure problems
- No tire spin????
- I have seen ASP Headquaters... I'm testing for them
- 85mm Lightning Throttle Body on a 4.6?
- broken down
- Cleaned the MAF Sensor
- 4.6L great millage
- How much is a Volant Intake?
- Where is my cylanoid?
- Hypertec Chip
- drain plug
- superlift tru-speed
- Aahh!! Crap I'm pissed!
- HEY Neal
- 160-deg. Thermostat Probs
- Steering Stabilizers
- ? on '99 oil leak
- Installing pullies
- Defective oil pressure switch causes erroneous reading of zero pressure when cold
