View Full Version : V8 Engines
  1. Charging a 4.2 6Cyl...will this work??
  2. Mass air sensor
  3. Estimate on horsepower?
  4. 4.6 vs. 5.4 L ??
  5. Ported Heads anyone have?
  6. SD limo
  7. 5.4 v-8
  8. Check engine light
  9. When to trade??
  10. 2000 Expedition Located in Rhode Island....Place to UPGRADE?
  11. Which engine
  12. Power Mirrors
  13. Update for "Ian.N" Engine tach.
  14. engine stumbling on acceleration
  15. engine missfire
  16. Question for Thf Freak
  17. Dyno results.......Again
  18. Sweet car
  19. Perspective, Patience and Pride
  20. what service stations/stores use Amsoil?
  21. Can Somebody Explain ?
  22. Was just wondering.Flareside or Fleetside??Why and Why not???
  23. Switch from Mobil 1 back to Valvoline
  24. K&N FIPK Installed -- feedback on noises?
  25. Piston Slap!!
  26. Crank Question?
  27. 04:04 PM
  28. Question about 5.4L fuel injectors?
  29. Installing a "real" oil pressure gauge.
  30. Performancs Mods for 5.4V8
  31. Nice Performance Mod
  32. Spark Plugs
  33. I like that april fool joke that was cool,hehe
  34. about to open inlet from fender to 6 inches...any negative effect?
  35. Blew out the Block heater!
  36. Reference to Rough Idle concern
  37. Valve covers for 4.6
  38. Order a new inake option!!!
  39. Crankshaft Pulley - Help with removal
  40. what kind of oil do I use?
  41. Question for truck experts
  42. Does anyone know
  43. Just me?
  44. Runnin' out of ideas!! -- Help
  45. WARANTY INFO ????????????????????????
  46. Mike in LA and RJ -- I need your help!!
  47. How long to install FIPK?
  48. Bad Check Engine lite
  49. billet grill installation/what kind?
  50. New Chevy C3?? HOW WEAK!
  51. Engine oil changing habits?
  52. antifreeze in plug hole
  53. Regarding the cooling upgrade
  54. 95 Powerstroke beat my 5.4!
  55. engine whine
  56. 90mm maf????
  57. Improving MPG?
  58. Rear main seal
  59. Electric fan question (again)
  60. 1997 4.2L engine problems
  61. What gas do you use?
  62. Looking for Help.
  63. K&N Air Filter?
  64. strange engine noise today
  65. Not really an engine ? but.something is rattling when i step on the brake ?
  66. 5.4 Tranny
  67. Heavy Duty Electrical/Cooling Pkg
  68. Another Question For JSTANG?
  69. P1141
  70. Any Piston Slap in 2001 5.4l engines?
  71. Enginge Vibration
  72. Piston Slap
  73. Mustang 4.6 is the same as F150 4.6?
  74. Pics of true dual exhaust
  75. firezapper
  76. 5.4 Crate motors cheap
  77. HOLLEY THUNDER SUPERCHARGER
  78. superSCREWED
  79. MSD ignition
  80. Wrong Raditor(Dealers reaction)
  81. Ford Techline says I can't modify my truck
  82. FINAL FOUR!!!
  83. Which oil is best?
  84. Roots style supercharger.
  85. Superchip ???
  86. Anyone-Amsoil BY-Pass Photos?
  87. Header Gaskets!!
  88. Flex Fan
  89. Intake tube diameter?
  90. Changing spark plugs
  91. HELP! Pinging & knocking
  92. Any Performance Upgrades For A 4.2L?
  93. Dealer Competence???? Cant do simple repairs
  94. Stupid check engine light.....
  95. Relivin' my teenage years
  96. NEED GOOD PERF. AND MPG SETUP. HELP.
  97. Piston Slap?
  98. K&N Filter!!
  99. Head Gasket replacement?
  100. Does anyone buy regular cab trucks anymore ?
  101. crankcase breather?
  102. Reset Computer
  103. Triton Valvetrain Lubrication
  104. 4.2 to 5.4 switch or Supercharger?
  105. Is it too late for synthetic?
  106. 1998 4.6 with real problems...HELP
  107. mufflers
  108. Does anybody have 1/4 MILE TIMES FOR STOCK 4.6/5.4 4X4
  109. Hypertech Power Programmer III, now for 97&98 Fseries
  110. Please reply --> Specs
  111. Heater doesn't work.
  112. Does anyone have Nytling92's e-mail?
  113. More durable: 4.6 or 5.4?
  114. If you are waiting for/been refused a new radiator...inside
  115. If you recieved new radiator...inside
  116. Does the 5.4l Have an RPM Redline?
  117. Engine stops-will not start
  118. Insulating HVAC hoses
  119. Help! Simple Job Gone Bad!
  120. what is this T100 i have seen below some f150 badges
  121. Truck doesn't heat up!
  122. Speed Limiter
  123. Oil Usage when hauling?
  124. Fuel Pressure in the tank
  125. To Those That Have New Radiators
  126. any body located Toronto????
  127. 4.6 V-8 and a 3.55 LSD
  128. Is ford supposed to provide a rental for warranty work?
  129. Anyone in the South had Radiator Problem Corrected With No Trouble?
  130. engine light on/not idling when cold
  131. Flashing Air Bag Light
  132. overheating
  133. 4.0 Ford/4.0 Mazda Same engine?
  134. 2000 F-150 Piston Slap???
  135. Damn thing hauls a**!!!
  136. Starter went out at 273xx
  137. 4.6 Horsepower
  138. engine flush
  139. What have you done since new?
  140. Is it safe to buy?
  141. How to test your performance mods on the road....
  142. new radiator ordred NO problems
  143. someone once posted, "Is this supposed to be covered"
  144. 97 Engine Tapping
  145. replaced 4.6 - 99
  146. upgrading Spark plug wires
  147. Radiator Situation
  148. engine idle...help
  149. Where is the VAT sensor
  150. Does a Skinny Radiator = Skinny Shocks?
  151. HELL OF A NOISE
  152. How much vacuum on EGR
  153. mexico
  154. Oil Line Leak
  155. Need advise on gauges.
  156. Service Bulletins at NHTSA
  157. FIPKs VS Filtercharger
  158. Question for JSTANG?
  159. Coolant leak - Timing belt cover $450!?!?!
  160. Screen windage tray question
  161. Extended cranking only when partly warm....need suggestions.
  162. five dead fords on the side of the road…….
  163. question for steve41
  164. 5.4 engine miss
  165. Timing Chains
  166. airaid filter--what is k&n part number
  167. How to identify 5.4 w/ 260hp
  168. Coolant replacement in progreess..........
  169. what does airflow sensor do.for a engine
  170. Stock hp on 1998 5.4L Triton - F150?
  171. Wrist pin going out???
  172. Recall on short tail pipe???
  173. Question: switching from synthetic to conventional oil
  174. throttle cable
  175. your thoughts on the 97 4.6 v-8
  176. Best price for K&N Generation II ?
  177. Ignorance: Whats a blower do?
  178. Big Mouth/ PowerStack air filters for FIPK
  179. Low emission vehicle exhaust smell
  180. Fuel Filter
  181. Where's the PVC?
  182. Diect hits ignition systems?
  183. semi synth oil only for 2001 Fords...?
  184. Oil Change,,,5 quarts or more?
  185. Radiators
  186. Clean Engine?
  187. Do the 5.4's respond to cooler thermostats
  188. Purolator Air Filters
  189. Upgrading Torsion Bars on V6
  190. won't idle
  191. 4.6L??
  192. replace injecters with MAF?
  193. what do u think?
  194. original eng question
  195. Looked at 2000 brand new Lariat LOADED,wrong radiator ?
  196. Upgrading fuel injectors on a 5.4L
  197. Diesel V6
  198. Front end Lift F150...TIP
  199. 2001 4.6l HP
  200. Stumbling on acceleration
  201. Water Wetter?
  202. Sparkplugs?
  203. 4.6 Engine timing
  204. Are performance chips worth it?
  205. 5.4 Cold Engine Knock
  206. HP difference between F150&F250?
  207. Check Engine Light
  208. Valvoline 5W-20 at NAPA
  209. Chip Install and a UPS rant
  210. Larger oil filter be used on remote loccation?
  211. Oil Filter Relocation
  212. Fuel reservoir & valve
  213. Engine Check Light
  214. Does WMS Velocity Tube use the stock size air filter?
  215. smoke in the morning
  216. 4.6 missing HELP!
  217. Need help with DPFE Sensor
  218. spark plugs and wires
  219. What will it do
  220. Speed-density controlled EFI and a cam?
  221. Oil inside intake manifold???
  222. How loud can fuel injectors really get?
  223. No power to fuel pump
  224. neal is right about the 8.8 in the trucks!!!!!!
  225. 4.6 L Oil Leak
  226. Wet valve cover
  227. Engine Performance
  228. EGR Problem - Check Engine Light on 5.4
  229. Gutless 4.6-
  230. Reply from K&N regarding FIPK vs. Filter
  231. What shop/repair manual do you use?
  232. Online Source Guide?
  233. An Open Letter To Ford, Re: F-150 Radiators
  234. engine code location?
  235. Check Engine Light appeared after installing High Flow Air Intake
  236. Not getting fuel
  237. Air Raid Filter
  238. 4.6L Oil Leak
  239. Ride in a 7sec 1/4 mile mustang!
  240. Centrifigul vs Roots type superchargers
  241. "Run-Rite" fuel system cleaner >>>
  242. Engine quits Intermittently and Won't Restart for 5 Minutes
  243. Artificial limitations on the 4.6?
  244. Lower radiator hose
  245. Ram Air hood?
  246. HEADERS
  247. Harley F-150 Horsepower Question
  248. Head Problem
  249. Engine Sensors
  250. New pics of family ford vehicles, as well as my new K&N
Search Engine Friendly URLs by vBSEO 3.5.2
