- 4.2 L V6 removal issue
- Which Oil????!!!!!!
- 5.4 throttle body
- 5.4 Triton Rebuild
- Major Tune up time questions
- What oil to use in a 5.4L?
- Fuel Mileage Drop Off?
- CHIP or No CHIP??
- Almost a catastrophe
- what are the disadvantages of having underdrive pulleys and electric fans installed?
- online performance shops
- 5w-20 Centistroke Viscosity
- Need advice on purchase of 97 F150
- how do i change the pcv valve
- Help
- Electric supercharger
- 5.4L noise
- testing ignition coil
- Truck Storage
- Quakerstate 4x4 oil anygood?
- Engine Swap
- Denso IT16 Vs. IT20
- A little survey for clutch pedal squeeking when you push it to the floor.
- Like a Rock
- EGR Troubles
- Fan Clutch replacement
- Sluggish 5.4--Intermittant
- Anyone tried lowtemp t-stat for pinging?
- Warrenty Question
- Best oil filter removal tool?
- just won't start
- FREEDOM FORD IS FULL OF CROOKS! major vent
- mountaineer 5.0 awd upgrades
- cylider#4
- what oil you runnin' in a 4.6??
- not getting cool air into engine
- Heater Hoses
- Intake
- best possible HP #'s without a supercharger
- Help! Trouble Code P0442: Evaporative Emission Control
- 302 rebuild w/ a HO351 Cam ?
- Mustang GT 4.6 vs F150 4.6
- Can't get gas
- Fuel Gauge Problem
- Engine Swap
- Just bought truck...advice?
- The Idle talk again
- 0-100 Km
- If the dealer hooks the computer up to my truck
- Need quick help plz...
- Fuel Tank Pressure/Vaccum????????
- Intake... what to buy?
- Throttle Body Spacer???
- Anyone know?
- Air Filters
- whistling sound
- Whens this 3v 5.4 coming out?
- fuel pressure
- What are you running for plugs?
- Mobil 1 10W-30 SuperSyn For High Mileage Engines????
- f150 Lariate 351
- Opinion
- Quick help needed
- Check Engine Light Rough Idle, and Shimmy at 1800 RPMs
- New DOHC 4.6L
- Gas Mileage
- 4.6 wouldn't idle
- Loss of power
- More engine sites please
- 100,000mi. Question
- Ford ESP Extended Warranty - Great Price
- Fuel Mileage Increase After 40K?
- Pullies
- 4X4 System?
- Where is the 'door crack' problem located on the newer fords?
- Supercharged 5.4 images
- Volant intake prices!
- Spark Plugs
- Strange idle??
- Chip?
- Air Intake?
- motor noise?
- Electric Fans
- Ford 6/100,000 Mile Warranty?
- Help! Engine Trouble!!
- Do I have a Chance??
- Help
- Why do the Cheby's ext cabs look so much bigger than Ford's
- Strange deaccelleration
- Anyone ever change cams?
- Newbie questions
- PO446 Computer code on 97 4x4 Expy.
- 5.4 in 97 F150
- Code 9202-Oil Pressure circuit
- Green Filters
- Service engine light
- Air Intake Silencer
- Factory Oil Gauge???
- Performance Fuel Pumps for F-150
- Loss of part throttle power
- oil comsumption
- strange rpm change
- damn miss is back
- MitchF150~Please Look~
- oil pressure 4.2 v6
- rebuild kit for 97 4.2 v6
- air mod Q
- Can higher octane gas hurt?
- Mystery Miss
- Who makes Who's oil filter
- FL-820 oil filter from factory not the same as off the shelf (you gotta read this)
- Mods to new F150
- 99 5.4 Recall
- A/C Blowing out defrost vents only
- Supercrew 5.4 - Plug Change
- Plug repacement on 5.4
- Engine just stalled
- Safe to run different remote filter??
- Oil Filter thread size??
- Fog blowing out AC vents
- 2000 f-150 sparkplug?'s
- Need Help!!!
- What year changed to mass airflow ?
- Plug and wire change (again)
- I will pay for help.
- MSD makes...
- Tune Up
- tuneup
- MAF Mod
- Dropped 105 easy this morning...
- Post 2000 Wheels On 97
- horsepower
- rev limiter
- MAF and throttle body
- 2001 super crew 4x4 off road
- Which Oil is Best
- Washing Engines
- Neal "the H.p Freak" Needs Your Guys Help!!!!!!!!!!!!!!!!!!!!
- Mobil 1 to dino question.
- Edelbrock Headders
- k&N FIPK squeals. You can hear IAC valve
- Edelbrock 75mm T/B
- 5.4l Cams
- 4.6 underdrive pulleys
- Airaid vs. Procomp Intakes
- Chevy 4.8/5 speed
- I need a pic of a 98ish 5.4 motor please!
- 390 heads on 302?
- Miss in Hot Weather(95' W/5.0)
- Techs., just one more question.
- Identifying Edelbrock intake manifold
- Airforce1 and loss of low end
- Please help....need techs...
- on a hot day....
- Techs. know anything about rear axle size?
- Received my dual fan kit
- check engine light
- Windsor and Romeo, what is the diff. besides...?
- Does Z-Max really work?
- scanner purchase
- Finding Ford 302 and 390 engine pictures on the internet.
- 92 f150 running rough stalls out
- fuel pressure regulator
- Ping Or knock
- 20w 50 Oil
- Mobil 1 5W-20 to be available by years end?
- Anyone tried Motorvac?
- Accel wires bad after 15K miles?
- vibration and loss of response
- F-150 Diesel?
- Harmonic balancer removal help!
- crank pulley...
- just wondering.....
- Quick Question
- Quick Q on AF1
- Injectors??
- water pump nightmare
- Avoiding a piston slapper and oil leaker
- Different size plugs?
- oil changes
- Sparkplug mod for aftermarket high output coils
- Underdrive pulleys w/ sound system
- Bad coil packs
- Mobil 1 users.....
- Thumbs up to Airaid!
- Remanned engines
- Carlisle all Truck show.
- Techs. is this normal?
- Cracks on ALL Flat Surfaces
- V10 Block on Ebay
- Help, Cylinder#1 Misfire
- low rpm's and rough idle
- 2004 Model Info and 6.0L diesel problems
- rough idle
- Swapping out a 4.6L for my 4.2L
- CE light question...
- Denso Iridiums Plugs
- Gears and Gas Mileage
- spark plugs this weekend (5.4) any helpful hints
- K&N or AirforceOne
- Ford Powerforce concept...the next F-150???
- Synthetic oil in my older motor?
- STP fuel treatment
- Possible altenator problem?
- switching over to PI heads
- What's the best
- Air Force One?
- 1986 Ford F-150 engine swap?
- Where is the inertia swith on 94' 5.0?
- bad c.o.p.s which 1's u had?
- replacing vacuum tubes
- '93 F150 Surging
- MAF mod
- Sticking Throttle Blues
- throttle response
- Spark Gap Set Incorrectly @ FOMOCO?
- Dirty engine after air box mod
- Headlights died!!!
- 3.73s or 4.10s?
- FQR Fred Jones Crap ?
- fuel line and injector cleaner.
- awful sound coming out of my 94 f150 5.8
- Code question
- Air Intake Search
- Did anyone switch to 10w-30 visc.?
- Techs. Can a Synthetic oil cause a new modular engine's lifters to fail?
- Billet stuff for engine compartment???
- ram air
- radiator cover
- rough idle cured
- Silicone Hoses???????
- help! elbow to heater coil rusted out
- Hollowing Out Maf???????
- 4.6L Aftermarket parts
- outrageous
- Sparkplug Upgrades
- Just changed wires & plugs 98' 4.6
- Replacment OEM Engines-- R they good quality?
- Fumoto Engine Oil Drain Valve - 10% off
- How do you notice a difference with synthetic oil?
- Quick question..which side oil leak?
- Gasoline, is it all the same?
- Engine dimensions.....
- high revving 4.6
- WANTED: PI heads/intake
- pi heads
- help w/ timing chain's please
- k&n fipk2
