- Removal/Installation of Engine + trans
- Rough Idle, strange smoke from exhaust
- explain this code P0420 pending
- Tranny/ engine mounting issues help needed!!!!!!!
- Cam Phaser noise
- Bad IAC ???
- Bumper to Bumper warranty
- P1000 on my 2001 Screw
- in your opinion
- COP Boots stuck???
- Very Rough Idle only in the morning at a certain time.
- E-Fan Turn on Temps
- Fuel system fuse location
- Changed plugs and coils this weekend..
- Changed plugs and COPs,now a #4 failure?
- When to replace Timing Chains?
- cam phasers and butyl pads
- Sparkplug Insanity Help!!!!
- Thottle Delay Fix?
- 4.6 PI Engine into non PI F150
- New Spark Plug TSB
- Block Heater?
- Debris in intake manifold
- Cheapest online prices for sparkplugs
- 06' Mark LT Questions???
- '89 F-150 Turning over, not starting?
- high speed miss
- Engine Swap
- cleaning engine bay
- Foaming the Motor
- clutch fan removal?
- 05 F150 4.6 engine source for purchases
- misfiring under load....
- Which Spark Plugs?! Please Help!
- 95 f150 - red and green lines?
- Accel Part #? (coilpacks)
- I get god mpg
- 2005 5.4 mods
- Almost dies at idle
- 05 Warning light /throttle code question
- Tired of searching COP'S
- 5.4 Triton
- What should I trust?
- Inherited the work truck need help!!
- What Next? plugs? Coilpacks?
- oil filter is tight.
- Replacing COP's on yr 2000 f150 4.6
- Motor Mounts
- Need Troyer EFAN wiring diagram
- Belt Squeak...Need Help Fast...PLEASE
- 90 F150 hard to start when hot
- 5.4 triton question?
- No one will give me input.... please help...
- just got a 04, 4.6L XLT super cab
- Ford Mechanics......cost of new heads 5.4L
- Need an Opinion... 4.6L or 5.4L?
- won't turn over
- Burnt small secondary battery ground (again)
- broken intake manifold inlet hose fitting
- Run your truck with water
- hypertech computer chip
- Steps in changing a Fuel Injector
- engine rebuild progress
- Fluttering type sound in my 97 f150 when I idle or at low speeds?
- another question for jbrew
- Stock Specs on 2003 5.4 2V?
- Question for jbrew
- 2002 misfire
- 99 F150 4.6 misfiring
- sealed plugs: misfire gone: new truck!
- Bad Gas Milage?
- Just picked up an '04 5.4L
- Spark Plug change 2001 Screw
- Gas Milage
- p0305 and p0316
- Comp Cams 102200 vs. 102500
- '90 F250 5.8 Temp Guage not working
- 460 in f150?
- Help with my F150, P0401 code won't stay gone
- What sensor is this?
- Another misfire solved! fyi
- Cold Air Intake Heat Shield Color???
- Check Engine???
- camshaft position sensor woes.
- Wet spark plugs during spark plug change
- What about this spark plug change?
- Ok Im getting really confused?? What to do Next
- 2001 Supercrew shut off
- will not start 1st time
- 2002 4.2 V-6 intake warping
- PO171 trouble code
- $20 Mobile 1 Full Synthetic Oil Change...
- standard coil pac's
- Seafoam anyone?
- help my truck puffs smoke & idles high
- Underdrive pullies for 5.4
- tapping at high rpm's
- Paranoid about fuel line!!!
- COP Tune-Up Kits
- Changed COP and still misses
- Truck wants to stall
- Ugh, what is my truck doing?
- Rough Idle
- My 2002 Ford F150 XLT test run
- P0455 - EVAP emission system leak (large)
- 2000 4.6L Problems.
- 1997 4.6L what else should I do??
- water temp sensor??? where does it go???
- 300 Inline 6
- New high performance mod!!!
- Need the Torque Numbers 03 Plugs
- Engine stalls upon acceleration
- O2 heater circuit what if??
- 97 f150 o2 heater circuit ?
- Ignition systems
- Granatelli Pro Series 60000V Coil Packs
- Truck Still Idle Hight In/out Of Gear
- exhaust making popping sound
- First oil change in 5.4 a royal pain
- Check Engine Light / Very Rough Idle
- E-brake maintenance
- High Pitched Noise
- complete electrical failure??????????
- 2000 5.4L Coolant temp sensor where is it???
- '99 Spark Plug Question
- EUREKA!!!miss/vibration is gone,Thanks Guys!
- *GREAT* Service manual for 04-08?
- Really need some expert advise...5.4 swap
- DPFE tube
- Hopefully nothing to serious...
- Electric cooling fans
- 2007 4.6L Rough Idle
- 04' Plug Change
- Force a High Idle
- 2000 4.6 engine misfiring <<<
- 06 Fuel Filter Replacement
- Head replacement 2v to 3v.
- Spark Plug Design Change?
- 1998 buck's at 40
- 4.2 reputation ?
- FREE Horse Power!! Tricks????
- Replace Ford 5.4L Coil-Over-Plug's with standard coils?
- u can't wait to see these pics of my new instal(sarcasm)
- How many CFM's
- Any 4.2 built engines??
- How many CFM's
- Problem
- P0174 P0302 miss at idle
- Problem
- what a pain
- 2003 f-150 4.6l - what years heads are interchangeable
- Engine swap in 97 4.6 to a 5.4
- seafoam for carbon buildup?
- Lets see some Lightings!! I really miss mine
- Wont get up to temperature.
- Is it OK to change from conventional to synthetic oil...
- Spark plugs
- inertia switch
- TPS signal
- Missing vacuum hose
- 99fi50 4.6
- 2005 Screw FX4 5.4L issues
- performance heads + camshaft
- my truck has 99,999.0 miles pray for me!
- RPMS stay high when i start the truck?
- 100,000 Service
- Homemade E-Fan
- AEM Intake?
- Head Gasket??? Please help me.
- just installed my ASP U/D pulley set
- Rough Acceleration 2001 5.4! COP's???
- 0171 and 0174 cure
- Help with thoughts of a engine swap!!
- slight hesitation at 40!
- Troyer electric fans help
- engine turning over but no fire....?
- what will give me the most horsepower
- Vibration question
- 2003 F-150 4.6l - Stripped Spark Plug Hole
- High Mileage (what’s going out next)
- Engine question for you guys...
- Champion Develops "FIX" Plug for 5.4L 3 valves!
- Spark Plugs and nickel anti-seize
- TPS and #1 coil pin on ECM
- Identifying fule injectors
- Oil light
- 4.6 plugs vs 5.4
- knocking and low idle
- More Mods???? Need More Power! Help
- Ticking noise while at Idle
- supercharged 5.4 to a 4.6
- Exhaust leak from exhaust manifold!!
- #5 coil pack
- Knocking Sound Only at Idle?
- BBK 70mm for the electronic throttle...
- injectors? P0300 P0307
- Rough Idle Help Please! Thanks!
- Question about vacuum leaks
- Sputtering and unusual idle at cold start...why?
- Fan Removal
- Can i swap these? need some help.. pics!
- code: lean mixture on both banks and misfire on rt bank cyl2
- anyone every heard of a v-10 swap
- Idler Pulleys
- Coils
- Gas
- Timing cover/front cover?
- 4.6 litre killed #4 cylinder
- removing the throttle body, coolant line?
- So i guess I'll never learn....
- Heat problems
- cylinder miss
- 2004 F150 Really messed up please help!!!!
- Need help ( Bucking , Chugging )
- Help Please!!!
- ECT Sensor
- 1998 Stx Won't Start In Cold Weather
- Holy *****....
- Water in the oil seperator
- K&N Intake Filter Options
- Truck Stuttering Occasionally
- 1997 F150 justs click when key is turned
- Fuel Problems
- gas
- Intake coolant leak& PO307,308
- HELP truck barely runs in lower RPMs, shakes and stutters
- 5.4 #4 plug ejected - all hell breaks loose
- Troyer Underdrive Pulleys
- EFan FAL270
- dual alternator ???
- 2004 blown head gasket super chip
- 2000 F150 idle speed doesn't increase when cold
- Incompetence? Or blatant theft?
- Are They All The Same?
- Codes P2270 & P0054
- is this a coolant problem?
- missing or sputtering 5.0
- Thermostat questions
- Horsepower
- PI heads for 1997 4.6
- Truck running lean, can't find the problem
- ud pulley install
- 1999 F-150 4.6L P1504 code
- Any Ford Techs. No Injector pulse
- Under The Hood
- Need A Little Advice.
- Low Fuel Light
- Lower Intake Manifold Gaskets: Help Needed
