View Full Version : V8 Engines
- '01 F150 S'crew NOT getting hot
- K&N FIPK installation observations
- It's gotta be the gas!!!
- Oil Sensor (How do you take it off)
- intermittent idle
- Possible fix for cold startup squeal
- Dealers, what a joke.
- Changing out TB
- I think I found a problem with an ignition wire!
- ??IAC valve install question??
- Engine Error Code Help
- All Ford Owners Read
- 460 engine swap?
- 460 engine swap?
- Engine conversions
- Well, here we go again!
- Water Pump Help
- Cruise Control/Remote Starter
- gas filter clips
- Does anyone buy synthetic blends?
- Back to the $#%^%$#@ shop!!!!
- Oil Recommendation for High milage 5.0L
- Oil Misconceptions...
- Best way to check for a vacumn leak
- has anyone gone from 5-30 to 5-20...
- 5.4 Horsepower
- is 10W-40 overkill?
- Where does this wire hook up????
- Check engine LIGHT AGAIN!!
- Misfire ad nauseum
- Steam from tail pipes after engine is cut off....is this normal?
- What should it idle at?
- New Filter
- Final request for help then I'm off to the dealer
- Reman "engine" is done & home.
- Electrical Temp gauge reading off by 15*????
- ?'s for those with Plasma Boosters
- Typical performance upgrade questions
- Airaid users?
- which spark plug is best?????
- Idler Pulley
- Needs for supercharger?
- A motor is a motor is.........?
- What Changes Can I do under Warrenty
- Need Help
- Bad miss when warm??
- Egr
- rear plug removal on 98 F150 4.6
- OK guys, come clean...who`s using 5W30 oil instead of the recommended 5W20?
- Missfire in #4 (AGAIN!!)
- OK....this is REALLY gettin' old....pls help
- K and N filter
- Diesel
- Non-L 5.4 plug launches?
- Check Engine...again
- Spark plug change mileage?
- intake exploded
- Need Help - Green Foam/Liquid ????
- I found one problem! O/T
- Anyone Noticing Filings in their oil?
- Need help with Crank shaft sensor
- Lightning Engine Dimensions?
- ~~~no Spark At The Plugs Help!!!~~~~
- Bown Spark Plugs, Stripped Cylinder Head Threads
- 1998 Rear Window replacement HELP!
- remote oil filter
- Morning engine noise, sounds like piston slap? Check your oil!
- A matter of bearings
- If im on a budget, what headers would you reccomend?
- Spark Plugs
- Spiral Max????
- Full of Crap
- radiator pressure tester
- Flex-A-Lite 270 Kit Installed...
- ASP Pulleys Installed...
- Minimum Idle Adj
- Under Drive Pulleys
- just goes "click"
- 5.4 info please
- Missing at 40MPH
- White Pasty Film On Oil Cap
- Plug & Wire Change on 97 4.6????
- New Aftermarket Intake System???
- oil loss
- Can you explain dealers to me?
- I have new Hypothesis.
- Poweraid
- Long Sleeve or Short Sleeve?
- Where did the oil go?
- Part numbers?
- Super Charge or Turbo
- Pinging like crazy!
- Thanks guys, the P0401 may be history
- low idle after driving 10 minutes
- Changes to K&N Air Filter Design?
- 6.0 diesel motors
- Intake manifold question
- Air Force One intake moan?
- FIPK questions---->
- Halo Plugs
- What is FIPK??
- 4.6 with 3.08 getting 26+ mpg
- Compression Ratio on 5.4???
- 5.4L A/C question
- single digit tempatures, do you warm up your engine?
- K&N Filter recall???
- water in the plug hole
- Need help with high end issues, please.
- cooling fan question
- another question / plugs and wires
- measured resistance of plug wires
- Engine stumble any help?
- Hesitation and stumble
- Iac
- engine vin codes
- Screw mileage
- P_Ferlow and Conner
- Thanks F150online!!
- 97 F150 problem
- Specs for 2000xlt
- Autotap w/Palm......
- Fuel Filter(s) for a 2001 5.4L
- Got a recall notice??
- Pep boys charges$80 for code or reset. Check Engine light still on
- timing belt
- wet oily sludge in my throttle body
- New MSD Coils, but still cutting out, HELP!!
- Ignition Coils
- filings in engine oil - 4.6
- Please help me out with this discison about oil
- Whew that was a scare......
- Just installed plugs wires and coil pack.
- Filter where oil tube connects in airbox?
- BEst bang for your $ on a 5.4
- Engine idle RPM
- Check Engine Light Constant Problem
- Head Gasket Question
- Ford to upgrade Triton V10 6.8L??
- 2001 f150 4.6l v8
- Replacement Engine Opinion
- Reset Check Engine Light
- Hey, Hapynzap
- Revving in idle with my '03
- Remember how I wanted a 302?
- Redesigned Spark Plug for 5.4L 3V
- 2000 F150 serpentine belt squeak
- Idle speed? 550rpm low?
- Ford engine specs...
- Engine Surging
- Rev limit on a 5.4
- Enigine help with 97+
- Help with oil change
- Changing Spark plugs
- Need advice on spark plug change
- The new 'burnout' thread!
- best plugs,wires, coil packs
- Gas mileage question
- Help with aligning the timimg chain on 5.4
- Strange squeal...!
- Engine Missing
- Low oil pressure light this morning
- Engine rattle under load - cold
- FORD extending EGR warranty & refunding.
- Funny smell
- Causes for low mileage?
- Charcoal/Carbon Canister?
- need some help with heads
- V10
- piston slap went away
- Tune ups!
- 89 f-150 cam question
- best motor
- Check Engine
- Regular vs Synthetic Oil
- part# for motorcraft double platinums?
- I think i figured out why the engine light was on!
- req"d maintenance
- Engine Problem..RPM's going waco..Please Help
- Burning oil after oil change??
- Fixing/Checking The Starter
- 5.4 oil consumption
- vacuum squeal
- 1998 F-Series Engine Displacement
- SSCULLY, need your help, please!
- Timing Chain 5.4
- where would the best place be to buy seats for F150 ext cab
- Anyone got an Aerostar or something with a 302, or a 305?
- What is wrong?
- When should I do these things????
- intake moan
- lightning supercharger
- Engine
- Firing Order Please
- Cables?
- Spark plug cables?
- EVR Solenoid
- I hate computers in trucks!!!!!!!!
- Engine light, Seems like a miss....
- 99. 5.4 EXP rear coolant leak
- Yellow Coolant
- horrible warranty problems....
- 5w30 VS 10w30 oil
- Tornado
- 4.6 Getting 25+ Miles Per Gallon!
- Motor Oil
- Another Classic save...READ!!!
- Which oil filter do you use??
- TAD Solenoid? Code 81
- K/N filter
- Fuel Additives?
- Is the factory Temp gauge real??
- Plugs stripping head during removal
- general choke question
- Lets see some HIGH MILEAGE DOMETER pictures!
- Iac
- Best fuel/oil cleaning?
- Cams
- Spring compressors
- Engine Whine in Drive & Reverse
- What do removed spark plugs look like?
- EGR Extended Warranty
- 4.6 to 5.4 switch?
- Loud whine at start up
- code p0401 possible vacuum leak?help jeff laws et all!!
- fuel filter
- Where is the IAC?
- Speedometer not working right
- 6.8 V10 Engine Swap
- Radiator Upgrade
- Engine Power and Performance Comparison
- EGR flow excessive, code #PO402
- Power Steering pump Major Whine!!!
- Help with start ups
- Cause for hard start ups when below freezing.
- Terrible Noise When Starting Up
- Spark Plugs question
- What is this part?
- Will a FIPK make my catback louder?
- IAC Part Number
- MAF Problem..Please Help!!
- Help with a driveshaft
- Air Intakes
- Chevy Horsepower
- 5.4 SOHC Engine height
- Anyone have an old Aerostar or somethin like it?
- Tryin to find out friends hp
- Fan clutch replacement needed?
