- update on truck
- o2 sensor code/heater circuit malfunction...help!!!
- Swapping EFI 302 With 351???? Please Help
- hooked up a scan tool today....
- check engine light misfire 5
- dtc code?
- Big Problem on #4 spark plug - 1998 5.4L
- 2001 5.4l parts suggestions
- Engine idles up and down when defroster is on
- "Service Engine Soon" - great, now what?
- What is a custom tune and who can I get to do it?
- '98 4.6 harmonic balancer to '01 balancer swap???
- water in the intake
- Engine cutting out -- 05 5.4l
- 4.6 longtubes
- 5.4 3valve is ticking louder and louder
- Help!!!!!!!!!!!
- Engine Dying
- Lots to read - intermittent hard start
- 5.4 01 Screw would like to do eaton swap need info....
- 4.6l ????
- need advice diagnosing problem
- Bad Fuel Pump?
- San Antonio Tuners?
- 2004 Ecm Calibration Updates ?
- Bad Cop, Good Cop....
- strange exhaust noise?
- Tell me about the spark plug tick...
- Spark plugs 4.6l
- SPAL fan controllers
- COP's????
- 01 250 5.4 mileage?
- Whirring noise on startup COLD Weather
- 2002 5.4 Fireing order?
- Is this a Head gasket?!!?? Please HELP!!
- 1994 f150 5.0 code 332
- no start sometimes
- Error Code 0420
- Changed fuel filter (good) Truck Dead (bad)
- pulleys
- ? About washing engine
- pully help
- help trucks running poorly
- F150 engine missing at idle and on road
- Champion's Double Platinum Plug for 5.4L 3V
- 2000 explorer 5.0 in 1997 f150
- 2005 5.4 running rough
- trouble with oil change
- engine problems, 05 screw 5.4l
- engine swap
- Lightning swap into a 4x4 F-150????
- How much oil does my 5.4 07 F150 hold?
- studder at acceleration
- Headgasket parts list...valve seals?
- need parts for 03 5.4
- Modular Engine Lift Bracket?
- FTP and code P0453
- 99 5.4 rod knock
- Oil Pressure problem
- 4.6l coolant sensor location question?
- missing
- Do-it-yourself Spark Plug Remover
- Anyone buy a Jasper Engine
- No pedal response from my Expedition
- Spark Knock and fuel mileage
- temp sensor
- temp sensor
- HP and torque from Scan Gage?
- Where are the TSB's
- burning oil and gunk buildup in top pans
- Must buy an engine in the next 48 hours
- gas mileage sucks
- 2008 v6 Mustang Vs. 2003 F-150.
- mods needed to beat 5.7 tundra
- hard to move manual 4x4 shifter
- Jiffy Lube
- Oil pressure sending unit
- need help with misfire...really confused
- engine coolant temperature sensor
- Jumping rpm
- 99 4.6 explosion(5.4swap?)
- help with miss
- Need help with TSB
- Puttering sound; loose spark plug
- 6 mpg isnt cuttin it
- stupid question
- Shaking between shifts
- new oil gauge
- 97 f150 cooling issues or blown head gasket
- missing
- Its Running good
- Truck Revs when put in park
- 98 f150 4.6 swap to an 01 4.6 questions??
- Mis-Fire Woes......
- 92 F150 power mods
- 4.6 speed upgrades
- intake noise? and pore response
- computer
- Knocking review
- trouble code p0401
- Bogging down
- Motoblue solid COP boot connectors opinions?
- What kind of engine did I get?????????
- Camshaft???
- Misfire help on escort
- HELP I cleaned my TB and now wont start
- How to get the max of low end torque for towing????
- Quintin - 2004+ Spark Plug Socket
- Dielectic grease.....How to? 5.4v8 2valve
- 100,000 Mile Plugs
- Farting sound........ my truck has gas
- Should Ford Bring The F150 Back To The Basics??
- PO301 and PO305
- Should I buy an '04 5.4?
- Slow?
- COP Help
- Help???
- truck stutters/missin
- Engine Swapy
- Trouble removing Spark Plug
- Noise at 2000 rpm... any help?
- 2002 Troyer Tuned 4.6L
- Engine
- Troubleshooting P0174
- Starter might need replacing?
- 98 4.2 fuel pressure regulator
- Whistling at 2000 rpm
- oil light on
- bad oil on the cap
- coil pack swap
- Aftermarket Temp Gauge Sender Location ???
- no power
- My P0304 Fix
- Cold start throttle respoonse
- Ringing noise from engine?
- trouble shooting
- Knock Knock
- Low Speed Usage
- Noisey Time???
- Engine warranty spark plug,coil, injector
- cam question in my new engine
- P0325
- power steering
- Engine screech on start up - cold mornings.
- Fuel Module on '04 SCrew 5.4L V3
- The tapping is still there! Any ideas?
- Miss
- 06' blue smoke
- 2002 5.4 misfire with no DTC....(code)
- Need Help Truck Mis Firing
- antifreeze
- help check engine light cam on..
- MEchanic Search
- Engine swap
- K&N air filter: worth it to improve fuel economy?
- Terrible Gas Mileage
- Comp Cams Question (Built 54)
- PCV elbow 5.4
- will a 06 5.4 go in place of a 97 4.6
- Gas tank in place of spare tire??
- Nooby to forum.....help
- 5.4 engine noise
- Carb Cleaner for Plug Removal
- 5.4 3V sparkplug blew out!
- engine codes
- IAC Problem / rubbing noise?
- Engine issues after TB cleaning
- Cylinder 4, 5 and 6 missing when warm.
- need some hlp
- New to F-150's...School me!
- F-150 92 4.9ltr Suggestions
- Trouble Code PO171
- 97 Failed CA Smog Burning too rich
- mustang intake swap
- have a spark issue also says lean
- 5.4 misfire
- Troyer Fan Relay...Green Wire to Switch??
- Code #P0304 CYL 4 Miss fire HELP
- intake modd from trucks?
- What headgaskets and bolts?
- low grade misfire?
- Running perfect. Then shuts down. HELP!!!
- Starter problem
- Engine lopes at idle occasionally...help!
- starter eating flywheel
- Knock Knock
- 1998 4.2 Idles high like 1800
- TOOOO many codes
- thoughts on a used Explorer?
- I need some help
- Fuel filter change
- lpg conversion???
- Help...
- plug blew out
- 3.8L Mustang V6 Starting issues..
- plug blew out a cylinder..please help ASAP
- 2001 F-150 changing spark plugs,...HELP!!!!
- hesitation when accelerating???
- 5.4 Kenne Bell with fuel injector issues
- Difference between 04 and 05+ 5.4 3V's?
- 2005 F-150 codes...what do you think???
- Well I guess I will be the first???
- God Has Blessed Me All 8 Plugs Are Out
- Truck Misses At Low RPM
- Transmission change/ flush
- 99 stock ford f150 4.6 Coversion to a 99 mustang gt 4.6
- Sputtering when accelerating
- Need suggestions ( Ford vs Chevy )
- Rebuilding
- help code p0175
- Global automotive coils
- What temperature on my 2005 5.4?
- a/c compressor?
- 3.8 supercharger on 4.2
- what is most weight you have pulled with your F150 4X4
- 1998 5.4 swap/rebuild with other years
- help fast. fuel issuehttp://www.f150online.com/forums/images/smilies/mad.gif
- e85 Conversion
- a little hangup in my gas pedal
- Talk to me about fuel injectors.
- whats wrong?!
- Exhaust Smoke?
- I Need Major Help
- windsor or romeo
- 1999 F-150 Miss fire (5.4L)
- New motor don't work
- High Pitched Engine Noise
- Slow accleration
- 2002 5.4L Misfiring Under Load/While Passing
- Autocerm
- any 4.6 upgrades?
- HELP!!! P0455, P0171, P0175 Codes
- engine block heater results
- pulse plugs
- swap a 4.2 with something else
- Ideling issue
- best plugs for 01 5.4l?
- how different is the placement of motor mounts??
- Turbo charger
- Tune up results in broken spark plugs and a huge repair bill
- engine not starting well
- throttle cable trick ?
- engine dress-up kit
- someone help, im a dummy
- testing injectors
- 2003 4.2 6 cylinder - remaned
- Global Automotive
- Help! 98 f-150 blew out spark plug
- Best Plugs for '01 5.4L?
