View Full Version : V8 Engines
- Question for Neal...
- 1988 300 (4.9) motor in to my 1994?????
- PIP in Distributor??
- Great Deal on Airforce One
- Got a Code....need help.
- Might Buy F150, would appreciate help and advice. Plese read
- Changing plugs--any special tools?
- How much would you pay...
- Hum or Whine under the hood
- draining radiator
- Code Scanner
- plug wires
- Engine Swap From 4.2L V-6 to 5.4 L Triton V-8
- additives ?
- Traded ol' Smoky
- Pedal rumble???
- Question for Mike Troyer
- Any bets on whether or not piston slap will still be here in the '04 models?
- blowin up the bow tie
- Rev limiter
- rough idle?
- Engine Upgrade
- How do i get a code,,,with out going to Auto Zone?
- trailer round plug,how do you get the center pin to be hot when in reverse ?
- code 8
- #4coil
- Oil Change
- Misfire Cylinder 4
- Specific Synthetic Oil Preference?
- Ported eaton blower
- Power Steering Noise
- 4.6L Problems
- Belt tensioner pulley bearing noise at 40k miles?
- First oil change
- i want to put a new cam into my expedition for more power where do i go to find one?
- Service Manual or CD??
- Just Noticed.?.?.?
- Head and cam swap from a 99+ GT?????
- New 5.4 owner
- O2 Sensor specifics
- Dyno Tune
- good 4.6 mods?
- Stock Throttle Body
- Arbitration concerning piston slap
- runs like crap
- Oil Question----->
- Any advice for Header install?
- Fuel Pumperooo
- 95 F150 Turns over but no start..sometimes
- What In The Heck Is This???
- New wires and plugs for my 4.6
- 4.6 Performance Problems (long)
- Due For a Tune-Up
- Anyone put their engine on a fuel injection cleaning machine?
- Performance Upgrades (Mike Troyer)
- FRAM "SureDrain"???
- finally received a code
- Rotella 5-40
- Oil lines going to the filter
- Po455 & Po302
- Important.....Time to get together about plug blowouts!!!!!!!!!!!!!!!!
- Air Intake Sound?
- 5.4 Stripped Spark Plug hole
- Broken Injector Connector
- Oil recommendations
- Chirping
- Bypassing the DPFE sensor
- F-150's Engine and Power compared to other trucks in price range
- Rattling sound
- oil Filter relocation
- Plow truck
- Good Spark Plugs and Wires?!?! Your Opinions?!?!
- Dealership Oil Changes
- 5.4 Intake Manifold on 4.6l
- FoMoCo Engine Oil
- 4.2 L 1999
- First Oil Change...
- Thinking of buying F150, need advice on engine issues!!!!!!!!!!!
- No start after shut off/ then restarted
- 2001 5.4L rotating assembly
- Water temp gauge (temp probe installation spot)
- Motor Oil and Filter?
- New Amsoil air filters?
- seprntine belt routing diagram???
- Natural Gas Conversion
- Infrared Thermography
- Rough Idle and gas tank humming
- Hesitation at 65-70 mph
- Got any pics of painted plastic pieces underhood?
- maybe we should have got a f-150
- Ok I give up!!!!
- broken bolt holding in EGR valve
- help with vibration damper
- More "blah blah blah"
- Replaced IAC....still doesn't idle right.....
- Bucking at 1500 RPM
- Noise
- Mike T underdrive pulleys
- Sorry here is the link
- Found this on E-Bay
- power pulleys
- How do I set the ign timing on my '92 F150 5.0L?
- 4.6l Iac $123.86????
- changing plug?
- ALTERNATOR Squealing
- what to expect as it ages
- Is it bad to drive to the shop with bad coil?
- Engine Oil Temperature During City Driving
- 5.4L coil pack
- 98 f150 5.4L 2v to 4v
- ABS Light is on
- exhuast smoke
- Mobil 1 question
- Triton 4.6l 2v to 4v conversion
- CRC Fuel Injection Air-Intake Cleaner
- k&n vs. kool blue?
- In the market
- Air Force One Intake Question
- Almost embarrassed to ask this
- Check Engine Soon Message
- Looking for Local Georgia Members.
- Track Times
- anyone know how to clean an iac?
- K&N FIPK OK for Off Roading
- Just want to ask a question
- Will T-bird headers fit?
- Starting Problems
- Why is my truck hesitating?
- 2003 F150 4.6 auto upgrade questions
- Rattling sound at idle?
- How to make custom intake
- Service Manuals
- Hearing a noise and don't know what it is
- Need help, wife's GM won't start
- Electric Fan
- Carbon in intake
- '02 SuperCrew - jerky gear shift
- 5.4L triton ignition coil problem
- Gasoline
- Intermittant Wiper Prob.
- 4V Heads & 351W
- Engine
- Cost of repairs
- antiseize
- Dumb question
- 4.6L runs good but won't idle..
- winter oil(dino) and cold starts
- 1991 F150 knock & ping & SMOKE
- Oil
- 4.6 to 5.4 or New heads?
- 20000 miles without an oil change!
- 5.4 P0401 EGR repair
- Piston Slap on 2003 5.4
- best gas milage ive ever gotten---->
- hesitation while accelerating
- Broken Bolt / Header leak
- I Finally Got "head"!!!!!!
- battery light comes on and goes off
- Cold Engine Startup Noise
- tune-up question
- K&N Filter Question
- Oil Filter Part Number Difference - Are these the same?
- Startup Engine Knock - PS or SP problem?
- carb troubles
- Aftermarket air intakes for V10s...
- Suggestions for buying a 99 4.6 4x4 or an 00 5.4 2wd?
- Oil in Crankcase Filter
- 5.4L Small Block
- Whistle from intake?
- 4.6 Runs Rough
- EGR Cleaning
- Time to change plugs, Questions for you.
- replacing various sensors, valves, etc
- Spark plug torque
- Come on guys
- Got some Burnouts?
- valvoline maxlife
- 98 4.6 Won't Hold Idle
- Replacing PCV valve
- Fuel Mileage Question
- alternator
- Thanks guys
- Dyno'd Intake?
- Motor vibration, and hesitation...bad coils?
- MAF sensor location
- acceleration ?
- F-150 '04 Alert!
- sport 4x4
- Supercharged V-8 -VS- V-10 power???
- listen to this??? truth or myth
- 4.6 Pinging
- Rattling during Acceleration
- Coolant Question
- Question for those using Ford Racing wires. . .
- Cleaning IAC
- kinda interesting
- running hot under a load?
- Computer chips???????
- Electric fans... more questions???
- Motorcraft spark plug wire info please...
- Poll: RPM in park and in Drive?
- Super Unleaded??
- Rods
- 32v conversion on 4.6
- 96 EFI inline 6 -- suggestions please
- Rough idle
- Flushing engine?
- coil pack info needed
- 93 F-150 will not start - need troubleshooting advice
- 92 Inline 6 fuel pump acting up
- Change Oil Pan
- Timing chain photo's
- Rough idle in drive
- plugs ?
- Help!! Blue smoke from my 01'
- Pic....
- SOHC-DOHC conversion
- Cleaned my IAC valve
- i have a problem
- Gold Coolant
- Air Intake Kit
- fuel smell form engine area.
- Pinging issues
- timing
- 4.6 questions
- Dont sweat the Hemi, as far as torque goes..
- Fuel Pump and Sending Unit
- 89 F150 - Is this the IAC?
- thanks
- Where's the IAC?????
- Help Engine Code - P01450
- 4.6 V8 help
- 1988 bronco wont start and nothing works lights
- Diesel Fuel economy
- fiche
- anyone know anything about timing on a 1987 mazda b2000??
- first and last ford
- oil in upper plenum
- '92 F-150 5.0 fuel psi reg Q:
- dual filter intake
- Throttle Body Spacers - Performance Product or "Snake Oil"?
- 5.0 engine swap
- will it run with injectors???
- Friend's 88/89 F150 4.9 starting problems
- pulleys/dim lights
- '03 Mountaineer 4.6 Got PROBLEM??
- electric fans ... power/$$$
- odometer
- 2001 Lightning Engine Knock
- Stock Cobra Supercharger on my truck?
