View Full Version : V8 Engines
- 93 Octane
- Fluttering
- Honda Accord Question sorry
- 4.6l not kicking in to passing gear?
- Heat diverter?
- 97 F150 4.6L 213,564 miles,low idle,idle surges,weird air/fuel mixture
- HELP !!! Check Engine light
- Need help with 4.6 wiring
- Strange heater
- Intermittent Rough Idle
- no heat
- door locks going bad
- Bad bearing noise stops when fan engages . . .
- EGR Problems...I think
- Defective heads Question on '01-'04 4.6L's...
- 4.2 to 4.6
- misfire after a heavy rain, only under a load
- 5.4L Rebuild Questions.....Bear With Me Please.....
- #5 Plug in 4.6 : Threads Rusty!
- Fuel filter help with a twist
- Check this out...new on Ebay
- Cold Air Induction
- thanks guys bad voltage regulator
- swap 5.4l to a ford lighting engine?
- New spark plug?
- bad idel
- Hmm break in period on Reservoir & Valve?
- Maybe wrong forum but...
- oil filter change
- Check engine light
- Thermostat
- 6.0 diesel
- MPG with a 5.4
- Defective heads on '01-'04 4.6L's...
- Coolant Leak Help
- Engine Strain With Heat On
- Helicoil spark plug hole insert
- Holy Grail of MPG
- anyone got a pic of the IAC on a 99 4.6 ?
- battery light flash's on @ redline
- Spark plugs changed
- Selling my F-150
- 5.4 idle miss acceleration stutter
- Jamaican Chapter
- Misfire and loss of power
- OIl Pan Magnet
- Resetting computer always clear code?
- Oil pan
- hesitation/code 172
- Need help bypassing my A/C pump
- Head gasket replacement
- Knock sensor
- Throttle body/butterfly adjustment
- intake manifold
- 5.4 oil analysis
- engine swap or supercharger
- oil pressure
- How do you clean the iac ??
- 4.6 engine knock
- Repair manuals on eBay
- code 172
- Gas Mileage?
- Need final advice on plugs & wires
- need help, where to get an iac?
- Winter Air intake applications
- KN Filters
- check engine light flashing! help
- Redline on 5.4??
- gt-40 heads will they fit?
- why does my 99 4.6 quit while idiling durring warm up
- Where to get plug change?
- finance
- 4.6 vs 5.4 ?
- Aftermarket parts for 2004 "carry-over" 4.6 engine?
- Coolant Freeze Plug?
- Insufficient Torque
- 3 Bar MAP? What ford comes with one?
- 89 5.0 Code 12-- Need help, Please!
- when to change plugs
- 97 f-150 starter problems
- Repair Manual
- 4.2 reliable?
- AC drain hose? how does it go on?
- code 0171 and 0174
- Need Some Advice
- Studder!
- old f150 fuel pump (?)problem
- 03 5.4 Maf
- FI to carb conversion
- Wicked Starting Problem
- High-mile '97 F150 4.6l update
- how's this price sound from dealership?
- AC stalls Engine?
- 1997 6.8L V10 HP versus 2000 model
- 5.4L engine ticking noise
- 350 Built in a F150?
- Would a code 31 cause an engine misfire?
- new amsoil air filter installed
- Powerstroke Vs. V-10 in an F250...?????
- DPFE Sensor???
- Water temp gauge install...
- Underdrive pulleys
- Hands Down best bolt-on mod available today!!
- To much?
- head gasket on 4.6L @55K
- Rubber Valve Cover Gasket
- supercharger conversion requirements
- An end to the pinging
- Mod suggestions for 5.4
- check engine code!
- Hydraulic lifters
- Oil Quanity for 5.4L
- Coils on 1997 4.6 L
- Check Engine Light
- N/A E.T.'s
- 90 F150 302 PS pressure
- buzz in radio
- Please help with random backfire
- Superchip Or Hypertech
- Weird problem
- 10 MPG typical?
- 4.6 gas mileage
- 03' F150 4.6L - flutter / ticking noise
- Excursion V--10 OIL Recommended ?
- Rough Idle on my 2000 F150 with 4.6L Engine
- Ugh, help. Pulled a "My Bad"
- Valve Lash
- Re-Gear
- need help 86 bronce wont run
- 1990 5.0L SD-EFi - throttle body size?
- Where and how to change oil sending unit
- 5.4L V8 variety
- Oil type
- Emission results from NJ
- Is the "new" Ford commercial on the net somewhere?
- Pulley ribs???
- Emissions System Diagram
- P1151, what to do?
- Chirping /Squealing
- a scary story
- 97 4.2L Valve Lifter Tap
- compare intakes hp/torque
- When to change coil packs?
- 2001 4.6L with P0304 Code
- clutch fan replacement suggestions
- how about the 4.6
- Power steering whine
- OBD available by turning ignition On/off?
- reply
- big problem need help asap
- Info on rough 5.4 engine idle.
- odd hesitation/shutter
- Service light
- New Engine???
- volant intake filter system NEW
- Coolant flushing
- looking for parts
- Tsb?
- Switching to L 5.4 $$$$$$$
- daytime driving lights suck
- 98 power locks
- Buying, what should I be aware of?
- K&N or Accel?
- IDM circuit failure?
- cold start clicking
- Help with battery &/or other situation
- new engine???
- another oil question
- Replaced coils, wires, and plugs
- Stuborn Fan...
- My new intake!
- Need help with '95 F-150
- Odometer-error code 3
- horse power
- Got the Codes EEC-IV
- Dyno test
- Timing Chain Deflection in 302
- Amsoil air fiter questions!!!
- Oil level Problem
- Carbon buildup
- Won't idle
- Finally changed the original factory fuel filter!
- Barely starts in cold and/or rain days
- Engine vibration?
- Ram Air
- oil consumption
- 04 5.4 Track times
- PCV Valve change out
- How do you get the fuel filter to come out?
- Help with Oil pressure indication problem
- 95 MPH cut-out
- `Enhanced DTC` code?
- Conflicting Codes
- 2003 5.4L hp/torgue chart
- 2001 4.2 constant light pinging at cruise
- Havoline Synthetic ????
- coolant in the oil
- PO303 Cylinder #3 Misfire
- Power Steering noise
- strange noise
- Thanks
- Bought Excursion--OIL ??
- Truck Stalls After AF1 Fix?
- 1994 - F150 Engine Light
- will a V8 fit in a V6 truck?
- ppfftt,ppfftt,ppfftt...
- Oil in intake
- Check Engine Light Problem Fixed
- Misfire...again!! AGHHHHHH!!!!!!!!!!!!!!!!!
- Engine Humming
- PO455 Code
- Part ID, 2002 FX4
- could rumor be possible?
- Hissing noise under hard accelleration
- Coil pack diagnosis/troubleshooting
- Thermostat hmmmm
- blue exhaust smoke
- I am having Oil level problems
- How much for an engine swap?
- 1998 F150 4.2L P0401 Code
- DPFE sensor voltage
- K&N FIPK For 2001 Expedition (Kit #)
- Lifter noise
- Speed mods
- 1994 F150 302 Starts and runs till hot
- Question about mods for Bronco
- Perplexed about engine ratings for the new 2004 F150 and F250
- Changing oil filter on 99 4.6
- Build Sheet??
- Rear main seal
- rusty sparkpugs
- 97 4.6 missing
- Help - 5.4L Cranking problem
- Is this notch supposed to be in the water pump backing plate?
- IAC valve?
- anyone mess around with the 4V heads on an F150 5.4?
- Engine Stutter
- Broken Exhaust Manifold Stud ('97 F-150)
- 4.2 v6 reliability
- 93 Tracer periodically dies....?------>
- Water temp gauge installation in heater hose...Which one??
- Spark plugs?
- Modding the stock airbox
- Help Whats wrong
- 5.4L Power Ratings
- used Sea Foam...Nothing, not even the white smoke
- high mileage '97 f150-what can go wrong?
- 87 EFI Stalling
