View Full Version : V8 Engines
- Heli-coil blew out
- Lately Im getting decent gas millage!
- Feels Like A Miss Help
- engine knock and zero oil pressure at start
- low idle
- Grinding noise from front end? Engine? Transmission? Help!
- p0174 code where to start ?
- To fix or not to fix?
- 240,000 Km's and running great
- help please
- E-fan power gains....
- Ran Out Of Gas..1999 F-150
- what does it take?
- 1986 F150 Injectors
- getting screwed by rebuild shop, PLEASE HELP!!!
- '04 5.4L Mpg?
- engine or exhaust? noise
- which way to turn oil filter
- Going to give Sea Foam a try
- Gas tank and sending unit
- 1983 F150 351 Vacuum hose diagram
- improved gas milage
- Changing plugs out
- Engine Runs Rough (misfires) under load
- Smoking gun?
- loud noise when first starting truck
- ECU Problems
- Dual Fuel - Propane and Gas
- Maverick current rots radiator!
- Remote Oil Filter Systems
- What kind of gas mileage to expect?
- mileage
- AIR Filter 04 f-150
- Gauges for 98
- Throttle Body Spacer
- 300 6cyclinders
- Gatorback Belt ?
- schematics for 5.8 351??
- Full intake installation
- A/C low pressure location
- exhaust stud
- Crower Cams
- Piston Slap, whats my next step...
- Blown Plug? Whatever happened?
- Drive train bucking
- Gas smell at startup
- Whats my stats???
- cat and/or o2 sensor bad?
- EGR Kleen Screen
- EGR Kleen Screen
- EGR Kleen Screen
- Thanks
- converter smells?
- How to remove old fan
- 97 timing chain cover removal procedure
- 5.4 sohc vs dohc
- New Ford Plugs
- computer
- Code 27
- Oil in water, what I found!
- F150 engine rough during acceleration
- Electric fans Pics
- mobil1 15w-50
- New High Horse power F150 engine for 05?
- Aero Turbine Mufler?
- Engine Upgrades
- How do I change the oil in my 1999 F-150
- 4.6litre puffing blue smoke on start up??
- emissions in PA
- 1999 5.4 oil pressure(urgent)
- engine stalling, eating oil, exhaust smoke what do i do?
- dead battery??? Nope!! - please help
- not looking good
- Intermittant Death
- Engine Jerk
- Enough oil???
- need help
- radiator petkock pic
- Drive train swap
- interchangeable body parts?
- Best plug gap for 5.0 w/ MSD?
- High Millage oil?
- My truck just cranks on
- Help needed in texas 96 F150 4.9 stalls
- Hole in cylinder head leaking coolant. How many has this happenned to?
- Check Engine Light and Fuel Rail Rot
- So what if you pulled coded 171 and 174?
- Bizarre!- Coolant leak from 5.0 throttle body
- 302 quits and stalls
- Start up miss
- i gained 3.5 mpg
- High Pitch Squeal
- truck is quitting
- Gatorback belt
- Air filter box (assembly) restriction!!!
- 4-5 quarts low
- What engine mods can I make? '88 F150
- loss of oil pressure, 4.2L, sender? oil pump?
- How does a tachometer work?
- Problematic P0401 CEL on '97 4.6L
- rear axle seal
- 2004 5.4 Horsepower Rating
- CEL on. one code pulled
- Several Mods Done - Poor Gas Mileage?
- fuel filter
- 97 4.6 freeze plug size?
- Gatorback Belts...
- 86 302 heads
- Fuel Filter Replacement - Tool Question
- Oil in coolant
- Service engine soon
- slower cruise control
- Flex-A-Lite 270--A/C question
- Engine Power
- Fuel filters
- Iridium spark plug help / ?
- Oh no!!!
- New Denso IT16's Gapping?
- Smart Truck?
- changing heads...
- O2 sensor locations
- Engine Dies
- Piston Slap
- New 6.2l for F-150???
- Power Foam works like Sea Foam
- A little bit of stumbling...
- 4.9 I-6 Engine miss
- 1998 4.2 with very low oil pressure while stopped
- last resort
- off road
- No codes = No idea what to fix
- Spark plugs
- Pics of my Air Filter
- Help! dead PCM?
- factory oil filter remote
- 5.4 misfire, no code comes up
- Rattling while using AC
- More EGR questions
- Standard (manual) trans on F150
- I Just Blew Up My 4.6l Engine In Need Of A Used One
- speaking of 4.6 triton....
- Bad DFPE?
- MSD Zero Cross Distributor.....
- Slight squeal after start up
- Propane and Gas dual fuel
- 10w-30 oil ok???
- High volume oil pump for my 5.0????
- Check engine P0405 diff. EGR problem?
- Fuel Injection swap to Carb.
- Lots of miles means thicker oil?
- Technical Service Bulletin 0322
- "bank 1 lean" C.E.L.
- 97 5.4 stutters...
- smog pump
- Clicking noise especially when accelerating
- Engine stall immediately after starting
- High Fuel Consumption on '92 F150 302
- wont kickdown
- is it ok to run 5w20 in a '97 5.4?
- Need help diagnosing problems
- Insufficient EGR Flow
- high pitch churping noise from engine
- 300 6 cyl. surging
- replacing a 6 (300) with an 8 (302)
- 95 f-150 4.9 cutting out
- 300 I6????????
- Cat Converters
- Oil Filter leaking
- IAC Biorhythm Canister
- oxygen sensors
- Can I install pullys myself?
- Stall's out when I let off gas.
- 89 F150 4.9L Stumper
- Best chip for my 5.0
- 5.4 Camshaft Gear Bolt breakage
- Seaform took out O2 Sensor
- engine stumble
- Upgrades!!!
- '86 4.9L timing mark
- Help with '00 F150 5.4
- 5.4 burns a quart of oil between changes
- A ford mechanic told me my truk has 3 months to live help!
- Snythethic oil vs. conventional
- 5.4L motor opinions (esp. the 1999s) & how'd i do?
- new truck, oil and bypass filters...
- rear main seal
- F150 wont stay running
- New Fram Air Hog vs. K&N???
- 5.4L plug removal
- Free Valvoline Synpower oil anyone?
- Added Horsepower!!!
- spark plug help!!!!
- From 03 4.6 to 04 5.4
- Can I activate the fail safe system?
- check engine light
- oil interval question, HELP
- Quick question
- Gas mileage
- What intake should I get?
- RTV Curing time (non-ford question)
- P0402 DTC, need advice...
- blue smoke
- Can you tell if this Truck is a Roller from the VIN?
- Cylinder layout
- Ford Racing Plug Wires
- underbody rattle
- Too good not to share this on oil loss in a 03
- sensor on lower intake manifold
- True duals question
- cleaned engine -now skipping
- how strong is the v6 in the Explorer and will it tow a 20 ft boat well ?
- Intake Plenum to Intake Manifold Torque.
- Gasket question.
- Engine noise
- 88 f150 timing help?
- coil packs
- Port in Manifold?
- Considering A 1999 F150 4.2 Engine..
- engine cleaning
- 88 f150 blues
- 2 questions on '89 F150, 4.9 L6, 2WD
- Serpentine Squeeking
- Another question
- whipple charger
- 'Clicking' sound in engine
- Poorer Gas Milage / PCV vavle
- Quick question
- I know this isnt a F150 question but.....
- Lean Condition Leak Question (with pictures!)
- Motorcraft 2150 carb
- Help! Broken ECU/Connector Bolt!
- Coil Test
- better 1/4mile time?
- ^&%^& Fuel filter removal
- Whine Under Hood
- overheating
- compression test
- Rough idle
- 1997 4.6 hesitation/missing
- 1980 bronco 302
- 2000 ford f 150 4.6 triton v8 Firing order
- Has anyone tried this?
- chocolate milk in fuel filter, fuel line question
- test
- Tune up on a F150 running CNG help
- Starting problem- Turns over slowly then quickly
- CARFAX Please!!
- Air Intakes?
- hoses
- Real water temp gauge install 2003 F150 5.4?
