View Full Version : V8 Engines
- Ideas on how to maintain your truck/add HP
- Burnt valve?
- ignition problem
- Houston We Have A Problem
- gas mileage
- where did my oil go?
- Best place and price to get remanufactured 4.6L engine?
- f150 tempature guage
- Anyone have the instructions for timing on this?
- Engine exchange
- Need Help Please !!
- 89 302 heads
- Belt slipage on 4.6
- It's Still a FORD!!
- Alternator questions, please help
- 6.2L for F-150 dubbed Hurricane?
- p0401
- In need of your advice...
- Injector Swap
- Not exactly non-Ford...
- need help with non-ford ?
- 1998 F150 "won't start"
- 1997 F150 4.2L Head Gasket Leak
- Engine sputtering????
- 5.4 24 valve engine noise
- 97 F150 5.4 L belt routing
- alternator with clutch?
- Bad alternator, makes whining noise?
- Need help with fuel injector noise
- Spark plug numbering
- Valve covers
- Cleaning MAF sensor
- sluggish,no power
- code p1151 1998 ford contour
- reset switch?
- Oak tree mechanic and newer trucks
- 1997-f150 4.2
- Air filter
- Spark plug coils
- Head Absorbing Oil
- Mega fuse where are you
- 2002 Screw FX4 Radio/Light problem
- Setting engine timing
- Spark plug torque spec 1998 4.6L Windsor F-150
- 2003 Triton engine in 1999 F250??
- 97 F150 engine swap
- thank you
- 77 F100 302 2bbl
- Out of ideas....
- Ok guys... serious top end question... Neal and other veterans here
- Possible Gas tank problem
- battery not charging HELP!!
- Changing heater hoses?
- New 5.4 have the power?
- '04 Lariat lugs at highway speeds?
- 97 F150 battery terminals
- spark plug removal help
- 1994 F150???...did they make this truck with GT-40 intake
- P401 code
- Anyone know the diff between these two cylinder casting numbers?
- Cold Weather Oil - 5.4 Screw
- 97 v6 has trouble pulling
- '01 or '02 - 4.6 or 5.4
- 1988 needs help
- tie rods/ball joints ???
- Decode vin for me please
- Almost Stalls When Pulling Boat
- Maybe A Miss? Maybe something else?
- Newbie/Problems
- Code? pushing reset and turn on engine
- Some more light
- electric fans is it worth it?
- port and polish throttle body?
- who makes a good header?
- Pulled code P1400 with Microtuner
- Battery Light Staying On
- 99 4.6 dies, after a short wait restarts
- K&N Filters question
- no power with a/c on
- Coolant leaking, what part?
- Question on value of pickup
- Anything to do at 60K? (maint.)
- 5.4l
- pp401 code
- Water Pump
- computer reset.
- guages for dummies...
- How to read casting numbers?
- Quintin I seen this in your sig.
- broken
- Valve job
- Is a 4.6 the same as a 5.4 head?
- engine swap
- engine removal
- riddle me this... cold engine ticks...
- Can I clean MAF without removing it?
- Doesn't Turnover...
- Can someone run a Carfax
- Starter location?
- shaking engine 5.4 V8 & leaking coolant
- Swap out my 4.9
- What grade gas best??
- Speedo Is Off
- Is my battery dying?
- oil change ?
- Oil Change question
- engine noise
- Check Engine Light On
- Timing Chain or Belt?
- Thermostat & Temp Gauge
- Walmart Supertech Synthetic oil
- 4.6 5 speed 4x4
- Zex Nitrous Oxide
- Front end report
- Lack of low rpm power
- Noise when turning slow???
- 5.4 Loss of power in high temps
- 98 4.2 Shakes
- what will interchange
- 1990 F150
- Cranky Starter?
- fan removal - 97 F150 5.4L
- What engine can I put in a 97 F150?
- Can you do me a favor? (carfax)
- k&n 77 vs. K&n FIPK
- Truck dies out of the blue, not getting enough fuel?
- 4.2L question from a newbie
- PVC valve on 2002 F150 and fuel economy
- 98 F150 5.4 Spark Plug/Coil Change
- Water dripping on passenger floorboard?
- Ignition Upgrade
- Smell of Gas
- need pics of a 97 F150 engine
- 97 F150 water damage
- Error P1747 and Overdrive light blinks?
- Please help!!! Starts and then dies - will not idle.
- 1994 5.8 liter v-8
- How To port your throttle body?
- Will Ford be left behind again...?
- Expedition rough idle
- CAI for Ram AIr Hood
- Water in coil?
- Check Engine Light And Scanner Codes
- 2000 5.4 Triton Problems Help!!!!
- 1990 w/302
- techron fuel additive?
- has anyone put a 408 in a f150
- engine removal
- milling heads on 5.4
- Spark plug torque
- Where to mount the Amsoil dual oil setup?
- Home Made Electric Fans??
- Fan clutch
- Single Cab Short Box 2WD 5.4
- Edelbrock performer 5.0 truck intake?
- check eng light
- IMRC stuck open Code!!! P1518
- 1988 F-150 Custom...whiny steering
- 00 expedition
- Starting Problem..........
- I Need Someones Help!!!
- Head Bolts
- Truck Shakes
- SES light and DTC codes....need opinions
- Is this IAC?
- Plug/ Wires question
- Here we go again!
- 4.9 I6 to V-8 Swap
- Looking for 5.8L 351W crate motors
- how to tell the difference between a 302 and a 351w
- What to upgrade next?
- #3 cy. misfires....third time...
- Troyer Performance rocks
- adding oil cooler
- pinging in dad's truck
- Possible Dumb Question
- litre/ci
- Different cam and timing gear in same head?
- Lightning motor
- Fuel Filter Change
- "CHECK ENGINE" light on, but better MPG?!
- Remove radiator?
- Erratic Idle
- WTB 4.6L block
- Is it worth it to keep computer codes current?
- Can someone do me a favor?
- Main seal leak on 4.2L '01
- 2000 f-150 fuel problem
- engine swap?
- Cop, good or bad?
- Milky colored oil
- runnin rich
- Plugs and Wires
- spark plugs
- po206
- Loss of power
- Replacing head Saturday, checklist
- Looking For Chevron Supreme 5W-20
- amsoil in my 2002 f150
- which 5.4s have the 4 valve per cylinder?
- Troyer Stage 4 Kit for 4.6L
- High idle
- Normal running temperature
- racing problems
- motor gone? newb needs help!
- Coil on Plug Prices COP Who's got the cheapest factory replacments?
- Service Engine Soon light
- Spring-lock fuel lines are STUCK!
- Oil Viscosity
- will a 2000 4.6 work in my 97 f-150 4.6
- replaced alternator and starter solenoid
- warranty
- 96 f-150
- My f150 problems
- Whats it Worth Please Help 99 Ford F-150 lariat 4x4
- A pox on the Ford engineers!!
- Whinning/humming sound
- Bought junkyard F150 head.. What next?
- Lifter / Valve rattle
- mileage, mileage, mileage
- What Air Intake To Get?
- Where are the plugs?
- Engine Skip and Buck
- Spark Plugs
- good sites for new engins
- need help--> high RPM when in neutral
- Changing Heads
- Stumble when I get off brake?
- 4.6 "baby diesel"
- Spark Plug Opinions
- Bolt on performance! Need help!
- okay, please dont laugh at me!
- Replacing passenger side blown head, should I replace gasket on right head too?
- Error code P0171 & P0174
- Washing my 2002 4.6 V engine
- whats up people, oil grade ?
- CNG (compressed natural gas)
- beat a hemi
- Accelerating Between 30-50 MPH
- Heli-coil
- Blown plug + Great dealer service
- Oil Dip Stick Rod
- Hypertech Power Tuner 3
- re:
- My Seafoam experience
- It just wants to die
- Can't get rid of the Misfire...
- Fuel pick Up
- No DPFE Sensor?
