View Full Version : Other Powertrain
- Noise/clunk comming from the rear?
- going to lower gears
- 4x4 not engaging on 98 F150
- rear end gears
- in the process
- 92 Ford 28 or 31 splines?
- 35" tires with 3:31 gears??? What ya think
- How to Replace Front Differential cover
- Front Wheels Locking in 2003 F150 FX4
- diff problems
- Regrets?
- picture
- rear diff. noise and 4x4 not reliable
- Ford dealer burst my bubble
- dash lights
- which front is stronger dana 44 ifs or ford 8.8 ifs
- Driveshaft spacer with 6" lift?
- carfax???
- Curb Weight
- ls. dif. chatter
- Clunk in rear end
- Eaton vs. Auburn Gear Limited Slip
- Whirling sound when driving
- U-Joints,How to Check ?
- What gears do I have?
- Creaky Cab/box
- Manual hubs on a 97?
- Steering Slack/Clunk
- u joints
- Shutter vibration at 35 - 40 mph
- Leaking Tailshaft While Off-Roading
- Diff Cover Torque
- 3.89 gears and other stuff . . .
- Rusty driveshaft-how to repair?
- who has 3.55ls with 285/75r-16???
- ring and pinion question
- Novice with vibration
- weird noise
- what type of gear lube
- Steering Wheel Locks While Driving
- Should front axle shafts turn when not in 4X4?
- Rear End
- Gear Change cost
- Won't go in 4WD
- Turbonator???
- Clunking noise in 4WD?
- 4wd front axle removal
- No Wheel Spin on Dry Pavement
- MY 4x4 is sucking bad please help
- code P0420
- gear help
- What to expect from 3.73 gears?
- Metalic clink
- Strange Howl from Rear End
- Heater Core Problems
- Differential Leaking After Fluid Change
- LSdif.
- Changing the rear u joint
- LSdif.
- Steering noise PLEASE HELP
- 89 f150 ext rearend?
- New truck with water in axle.
- Is my limited slip not working?
- Price to replace LS Clutch Packs
- 77 ford f150 rear dana 60 ujoint???
- Loud whine varies with speed
- Limited Slip Def?
- Weird noise and cant figure it out
- sad sight
- Towing Question
- engine swapping
- What rear diff do I have?
- 1997 Front Differential question
- 4X4 trouble shooting help!!!!!
- Help with new gears/lockers
- Front End Problem?
- Quick 4WD question
- vibration
- trans / rear end vibration or slip
- Transfer Case Question
- A fix for pre 04' f150 driveshaft vibes.
- Need new power steering pump and oil pan gasket...need help!!
- 4x4 problems
- rear end fluid????
- 1976 F350 460 4bbl C6 rear end??
- Changed Diff. Fluid But Parts Place Had 2 Quarts...
- ls differential options
- Nedd a rear diff. housing
- 2003 F-150 King Ranch
- 4x4 problem
- Rear End Swap
- looking for info on 98f150 rear end.
- A4WD Question
- F150 whine
- Rear End Noise
- gears for towing
- Tranny
- Diff shiming????
- 4x4 noise from front wheels
- Trailer towing help
- 3.73 ls and 35s
- Will changing rear gears effect factory warranty?
- What is a limited slip?
- more gear questions
- Rear end clunk
- Rear End Swap
- Bronco Driveshaft
- gears?
- Drive Shaft
- 9.75" axle width
- Gears??? & Problems
- trailer towing
- Heres the info
- Please Help!!!!!!!! Driveshaft Vibration
- My 98 Nascar 150 needs limited slip
- Limited slip not slipping: here's a quick fix
- Play in rear wheels...Please help!!!
- Gearing help????
- 4x4 Shift Fork $$??
- no 4x4 light... stuck in the mud!
- Stock Gear ratio's?
- clunk/thump and now a rattle...
- Low intermittent whine...
- Cool It!
- Differential Installation
- limited slip stopped working
- rear end issues???
- 1st Truck Mods Work! - Thanks!
- I Need Help...please
- When to change Diff. Fluid
- Limited slip rear end..pop..shutter??
- type of rear diff....
- Limited Slip or Non Limited Slip?
- Another rear end question
- 2004 Shuttering problem
- Clear rear differential cover
- lightning drive shaft in regular 150
- gentlemen please
- Rear end clunk
- replaceing cv half shaft
- won't lock into four wheel drive
- 4x4 problem
- modified gears for a borg warner?
- 10.25 vs 10.5
- tranfer case fluid
- Lockers!?!
- feel your pain steve
- Totally confused
- If the 8.8 a 28 or 31 spline for the trucks?
- Extended service plans and modifications
- 3.55 Vs 3.73
- u joint installation
- 4X4 Wont disengage
- 3.73LS 8.8" Installation
- Feels like something grabbing in rear?
- Rear Diff problems
- Vibration on driver's side
- Lowest Stock Gear Ratio?
- Front Wheel Bearing replace/service
- Front wheel bearing
- Rear Diff
- General question - Snowplowing?
- Difference between open, limited slip, and locked differentials
- '99 Power Stroke LS Diff. Rear-end Noise
- slight shake ??????????
- Changing Rear Brakes and Axle Seals
- stuck in 4WD
- Didn't know where to post this
- Engage 4x4 while moving?
- Rear Diff Lubricant
- Front Differential Arm and Vacuum Motor not staying connected
- 97 2wd f150 rear axle
- Front shaft abuse?
- driveshaft squeaking
- Door Seals
- 4x4 engage piston stuck
- 4x4 not working
- Shuttering after gear change
- 4x4 engage problem
- 4x4 Problems?
- Rumble in the Rear End
- rear axle free play
- VSS gear or programming?
- Hubs locked, but not 4WD?
- 4 wheel drive
- Rear and Front Differential Problems
- Identifying my rear end?
- Rear end Issues, or brakes???
- U-joint life
- best site ever!
- 4X4 not working....??
- CNG Owners & Shop manual
- 87 F150 4X4 'rear antilock' light on
- Crazy Vibration
- shudder above 25mph
- What should my gear ratio be for 35 in tires?
- 8.8 Aftermarket Ribbed Diff Cover ????
- WANTED, US Gear 411 Kit for 8.8 diff
- Which Gears
- vibration and rear lock kick problem
- Axle code help
- 1986 F150 3.55 differential specsMy Nephew
- 99F250 SD stuck in 4wd??
- Front diff not shifting
- Shifting to 4x4....
- For me, would Auburn LS or Lockers be better?
- Synthetic oil in front diff?
- 2003 f150 supercrew 4wd problems
- high speed vibrarion
- Leaky rear end?
- help with gear ratio??
- Tranny / T-case
- locker questions 2004 f150 4.6L 4x4
- Anyone used Superior Ring and Pinion?
- Looking for some parts
- Superior Ring & Pinion for 9.75?
- '89 f150 vs f250 driveline
- Rear End Identification
- Wheel Bearing
- Bent Driveline-Early $470 christmas present for me!
- Weight?
- Installing Limited Slip couple of questions.
- 9.75 help
- Limited Slip
- self inflicted vibration/shudder, need help
- Drivetrain Backlash TSB
- Drivetrain Backlash Noise???
- Harley, Lightning Driveshaft?
- Front axle not pulling
- Alright folks, I need som Serious HELP! asap
- intermitant 4x4 noise
- Power steering pump noise
- Will a NP203 bolt to an AOD?
- front differential options
- Noisy LSD
- Gears
- putting 85w-140 in, instead of 75w-140?
- Measured my pinion angle.Is it correct.
- Differential clunk
- Having Problem Shifting Manual Trans
- Excessive play in the differential?
- Loud rubbing and vibration while in 4wd
- hey bigtruck311 i got a ?
- ratio???
- Who makes a 4.10 for 9.75" rear end?
- four wheel drive problem
- What size differential in a Supercharged Harley Davidson
- what gearing?
- Axle removal problem
- Power Steering Hoses (return line pressure)
