F-250 / Super Duty / Diesel
F250 with 5.4 shuts down at 2500 rpms
Old 03-19-2017, 10:43 AM
Darril's Avatar
I have a f250 2000 model with 5.4 triton runs great up to about 2500 rpms then basically shuts down not off just bogs out
Old 03-19-2017, 11:17 AM
glc is online now
When was the last time you changed the fuel filter? I'd get the cats checked for blockage.
Old 03-19-2017, 11:37 AM
Darril's Avatar
New fuel pump, new fuel filter and new air filter. Also new throttle sensor
Old 03-19-2017, 11:39 AM
Darril's Avatar
The cats no longer has any guts since this started
Old 03-19-2017, 12:54 PM
projectSHO89's Avatar
Either it's running out of fuel when it needs it the most or it can't breath (either in or out) the volume of air air it needs at higher RPMs.
You need to investigate each possibility and VERIFY that it is good, not ***-U-ME it's good just because some part or another was changed, modified, or replaced.
Kindly put all relevant details like what has been done or tested (along with the results) out there up front. Extracting details piece-meal, like pulling teeth, isn't very pleasant. Also, feel free to use the "Edit" feature to add to prior posts. This isn't Twitter, there's no 140 character limit.
