F-250 / Super Duty / Diesel
2006 F250 trans fluid change
Old 07-12-2013, 03:15 PM
phillyFX4's Avatar
Question 2006 F250 trans fluid change
Hi, asking for my brother and his 2006 F250 Automatic 5.4L V8 with 95K miles.....he wants to drop the pan, clean the screen and change the fluid, approx. how many quarts can he expect to replace ?
sincerely and thanks
Old 07-12-2013, 04:26 PM
glc is offline
The 5R110 requires Mercon SP fluid, and a pan drop will require 7.5 quarts. If you do not use the Motorcraft fluid, you should do a complete exchange and use SP-compatible synthetic. This will require 19 quarts.
Old 07-12-2013, 09:28 PM
phillyFX4's Avatar
Ok glc, thanks again
Quick Reply: 2006 F250 trans fluid change
