2002 F-250 turn signal/ hazard problem
2002 F-250 Turn signal/hazard problem
A couple of weeks ago I had a relay buzzing and vibrating under the dash. I replaced the relay and everything worked fine. Today, my turn signals/hazzards are inoperable. They have power, light up, but don't flash. I was told the turn signal multi switch was a common problem so I purchased and installed one. And the problem persists. I checked all fuses under the dash, and located 2 boxes of relays under the hood by the drivers side firewall. All seem normal. Also an ABS light came on today.
I am unable to locate an actual power distribution box under the hood; and believe it's all under the dash. Is that correct? Could this be a ground problem? I am lost and would appreciate any suggestions.
Locations of any other relays and fuses I may have overlooked?
Thanks!
Thanks!
