Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Other F-Series Trucks > Expedition / Navigator
Thread Tools Display Modes
Old 05-10-2008, 10:49 PM
Vehicle: 2006 Ford F150
AC blowing only through the defroster (windsheild) vents
I have a 2004 Expedition 4.6, recently the AC will only blow through the defroster vents. My research leads me to believe it is a vacuum issue.
How do I check the system to see if the vaccum pump is working (where is the pump located)?
Any suggestions, help will be much appreciated.
Old 05-12-2008, 12:06 AM
Vehicle: 2006 Ford F250 4X4
There is no pump to check. Check the vacuum line that runs along the passenger side of the engine compartment on the fender well. It also goes through the firewall. It should be a small, black plastic line. Check it for cracks.
Old 05-12-2008, 12:20 AM
Vehicle: 07 King Ranch
I had the same issue on my 00 F150. Never got it fixed due to it only happened from time to time. The a/c would go through the correct vents if I turned it off and on a couple of times. The issue was a butterfly valve servo thingy that directed airflow. Sorry for the lack of technical terminology.
Old 05-12-2008, 01:05 AM
Vehicle: 1999 FORD F-150
you cnn buy a cheap hand vac pump that may help you track down a pin hole leak in a specific line
Old 05-13-2008, 09:24 AM
Thanks for your help, I found that the vacuum tube that goes through the firewall is broken, it's very brittle . I'm thinking of replacing the entire tube that runs through the firewall. I'm not sure how difficult it will be yet.
I will keep you guys informed....
Old 05-20-2008, 04:03 PM
congrats on finding the issue. please keep us posted, i am having the same issue w/ my 98 Expy. i gotta make time to work on it in the week or two.
thanks
Old 05-27-2008, 09:39 AM
Well, I had to replace the tube running from the valve to the firewall. I also had to replace two valves, one with three connections and one with two connections. After these changes I can now control the air vents again.
Old 05-30-2008, 04:23 PM
and of course you took pictures right!
thanks for the reply, did you get the replacements straight from Ford? where were the valves located?
thanks again!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150online is not affiliated with the Ford Motor Company.
