09-05-2008, 10:26 AM
Vehicle: 2004 ford F150
bank 2 sensor 2
my read out on my diagnostics is saying that my o2 sensor is running "lean" what does this mean? 2004 F150 screw new body style
09-06-2008, 01:07 AM
Vehicle: 2004 Ford F-150
Do you have an aftermarket intake without it being tuned in for the computer?
2004 Ford F-150 XLT Supercab 5.4L 4x4
Appearance: Gloss Black Grills/valance/wiper cowl, 20% Tint, LED Reverse & Plate Lights
Performance: 2.5" True Duals X piped, Rear Cats Deleted, Magnaflow 11" Bodies, Magnaflow 4x18 Rolled Tips.
Suspension: Bilstein 5100 Leveling Struts & Rear Shocks.
Videos: Start Up, Revs, Driving. Fly-By Sounds Burn Out Video Interior Sound/Drone
09-08-2008, 10:39 AM
Yeah i do but when i hooked the k&n cold air up to it i unhooked the battery also put on a rousch cat back system on it. When i did this i unhooked the battery too.
09-08-2008, 10:48 AM
Quote:
Originally Posted by
khosek
5.4L? If so you need to get a custom tune because thats why you are running lean. 4.6L your alright.
09-08-2008, 01:01 PM
custom tune? can i do that with the cortex super chip that i have?
09-08-2008, 02:01 PM
khosek
No, the computer need re-programmed for the intake and exhaust to not run lean. Head over to the Chips & Programmers section and ask questions. VMP tuning is good.
09-08-2008, 02:11 PM
Thank you!
09-08-2008, 02:42 PM
Vehicle: 2001 Ford F150
Disconnect battery and put stock intake back on to see if error goes away. If it does you will need a custom tune. 04s run lean from factory and some CAIs make it worse.
Display Modes
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
