Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain (OEM) > Exhaust
Thread Tools Display Modes
Old 08-22-2008, 08:48 PM
CEL light on after high flows installed
Is there any way to fix this? the CEL is on after having my high flows installed and i know its because of the o2 sensor. The guy who installed em said the o2 sensor was in the stock cats and had to put it "into" the new cats, now behind it like ive read here. Help please
Old 08-22-2008, 09:08 PM
Vehicle: 2002 Ford F150
Quote:
first you might wanna take it to autozone or who ever does the free computer check, then read the code and see why its on, it will probably be the same thing fordtruckin' has, running lean, and i have no idea how to fix the lol, maybe replace all 4 sensors, he said he replaced the front 2 and it fixed it for a little bit, then started doing it again, then he replaced the DPFE and its fixed, ive had my hi flows on for a good while and no CEL yet
hope this helps
[IMG]Please re-size sig image to 500x100[/IMG]
Signature Thanks To DarrenWS6
True Dual 10 Series Flowmaster, H Pipe, Maggie Hi Flows (94106) http://www.youtube.com/watch?v=nezTBIV8bOA
Old 08-22-2008, 09:28 PM
Vehicle: 2004 Ford FISO
Quote:
hope this helps
Aren't you the same guy that said this wouldn't happen when I asked this question in an earlier thread? Great information. Glad I havent gone through with it yet. I guess if you can't give correct information maybe you shouldnt be giving any at all...
http://www.f150online.com/forums/3342190-post8.html
QUOTE:
"you buy the hi flows, take them to the exhaust shop, tell the guy to cut all 4 cats off and weld the 2 hi flows on there, and he will do this, and he will be happy about it, and you will be happier, and you will pay, and drive off, and enjoy your new sounding exhaust,
and no it wont throw a code, and by mess with the 02 sensors what do you mean. you wont need to change the 02's if you replace with hi flows, ive had my hi flows on for about a month now, and it took the Check engine light off (i had no cats) and it hasnt came back on...so no you wont run into any problems"
Carl
Old 08-22-2008, 09:52 PM
ahh yes i forgot about this, out of everyone that has gotten hi flows how many have the CEL came on? 2 that i know of, mine hasnt, so the reason i told you it wouldnt come on is because theres something different, fordtruckin's DPFE had to be replaced, but at 202,000 miles it was about time anyways, anything could happen you know
Old 08-22-2008, 10:03 PM
Vehicle: 2005 Ford F-150
Did you try disconnecting your battery for a few minutes. Sometimes when the computer is seeing different info coming in from the sensors all of a sudden it will throw a code. When you discoinnect the battery and let the memory clear it will see the new info and think it is normal.
This is of course if everything is in working order and within the stock programs parameters for tuneability.
2005 F-150 XLT SuperCrew 4x4
K&N CAI, Flowmaster Cat Back
Old 08-23-2008, 01:22 AM
Vehicle: 2004 Ford F-150
If you bought cats that need an O2 sensor mounted in them, then thats your own bad that the CEL is on. Your supposed to get regular 2.5" hi-flow cats and have the front sensors infront of the cats, and rears behind them.. So dont dog on F150fellas advice whe n you bought the wrong cats.
2004 Ford F-150 XLT Supercab 5.4L 4x4
Appearance: Gloss Black Grills/valance/wiper cowl, 20% Tint, LED Reverse & Plate Lights
Performance: 2.5" True Duals X piped, Rear Cats Deleted, Magnaflow 11" Bodies, Magnaflow 4x18 Rolled Tips.
Suspension: Bilstein 5100 Leveling Struts & Rear Shocks.
Videos: Start Up, Revs, Driving. Fly-By Sounds Burn Out Video Interior Sound/Drone
Old 08-25-2008, 01:26 PM
Vehicle: 1997 Ford F-150
Yes, I did have problems after installing high flows, but mine wasn't just the CEL on but the truck actually ran bad. After I replaced the front two O2 sensors it did run better for a while but the CEL was still on from time to time reading Lean. I wasn't worried about the CEL until the truck was running bad again which was P0402 so I replaced the DPFE and now there's no CEL and the truck runs perfect at 202,500 miles. So don't throw parts at it and get the CEL code and let us know. Does the truck run like it did before the cat swap?
1997 Lariat 4x4 Scab - Westin Bull Bar - Rough Country AAL - Torsion Bars Cranked - 305/70/17 Buckshots - Magnaflow High Flow Cats - X Pipe - True Duals/No Mufflers
Exhaust vid:
Before X-Pipe: http://www.youtube.com/watch?v=t9QSMtF5xeg
New With X-Pipe: http://www.youtube.com/watch?v=wjFu0Cdj5eA
Old 08-25-2008, 01:36 PM
Vehicle: 2003 Ford F150
I swapped mine out and didn't have any CEL problems. Maybe the guy damaged the sensors during the install? Just a thought.
2003 Supercrew, 4x4, 5.4L, 6" Fabtech Lift, 3" PA Body Lift, Superchips Tuner, 38x15.50x20 Toyo M/T's, 20x9.5 Procomp 7005's, Yukon 4:88 gears, 40 Series Flowmaster Dumped, 3" AF1 Intake, magnaflow cats
Wish list(in order): Headers(maybe OBX), true duals w/super 44s, ride-rite airbags w/compressor, , SUPERCHARGER!
Thanks for the SIG krusedisc!
Old 08-25-2008, 08:15 PM
Vehicle: 1998 Ford F-150 4X4
I have had no problems at all. Got 500 miles on mine.
My exhaust: http://www.youtube.com/watch?v=NOhSPHP1e9o
Flowmaster 40 Series SI/DO
Pre-cat delete with two 94006 Magnaflow hi-flow cats.
Old 08-25-2008, 11:30 PM
Vehicle: 1997 ford f150
Quote:
i think thats exactly how my truck sounds with all 4 cats and and the same muffler except mine is dumped right after the muffler
Old 08-26-2008, 02:05 AM
truck is running great...i actually got 23-24 mpg on my drive back to school...i might swing by auto zone or something just to see what the code is or ill just have it checked out when i get my oil changed in the next day or 2
2005 XLT Scab
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150online is not affiliated with the Ford Motor Company.
