Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain (OEM) > Exhaust
Thread Tools Display Modes
Old 08-18-2008, 11:16 PM
Vehicle: 2000 Ford F150
Advantages/Disadvantages
is there any advantages or disadvantages to having my duals both come out in front of rear pass side tire? now they are coming angled out back, might go with a new look eventually. will the exhaust do anything to my polished rims? change sound any?. thanks
Old 08-18-2008, 11:35 PM
Vehicle: 2002 Ford F150
yes it will change the sound, no it wont hurt your rims, the only advantage/disadvantage is change of sound, different look, and dissadvantage is you might hurt them faster, i.e dirt, rocks, and tar
[IMG]Please re-size sig image to 500x100[/IMG]
Signature Thanks To DarrenWS6
True Dual 10 Series Flowmaster, H Pipe, Maggie Hi Flows (94106) http://www.youtube.com/watch?v=nezTBIV8bOA
Old 08-19-2008, 01:56 AM
True duals? If so, the only disadvantage I can think of is the amount of bends involved in routing two pipes to in front of the same tire. Lots of bends is is not a good thing for flow. Using all mandrel bends helps, but it also gets spendy and complicated.
Why not y-pipe it down to a single 2.5 inch pipe? Unless you have a stroked 5.4 and/or forced induction, a 2.5 single should work well.
Old 08-19-2008, 03:09 AM
Vehicle: 2004 Ford F-150
As Ty said it'll be louder, should get damaged as much though, after tire the tips take alot of abuse.
2004 Ford F-150 XLT Supercab 5.4L 4x4
Appearance: Gloss Black Grills/valance/wiper cowl, 20% Tint, LED Reverse & Plate Lights
Performance: 2.5" True Duals X piped, Rear Cats Deleted, Magnaflow 11" Bodies, Magnaflow 4x18 Rolled Tips.
Suspension: Bilstein 5100 Leveling Struts & Rear Shocks.
Videos: Start Up, Revs, Driving. Fly-By Sounds Burn Out Video Interior Sound/Drone
Old 08-19-2008, 09:18 AM
Y pipes are a bad idea, they take your power away
Old 08-19-2008, 12:24 PM
Quote:
True. The best thing to do with a Y pipe exhaust is have a new Y pipe mandrel bent real fine to elliminate the restriction, and have it go into a 3" intermediate pipe, then into a 3" muffler with dual 2.5" outlets. Keeps everything balanced well and helps scavenging.
Old 08-19-2008, 01:24 PM
Vehicle: 2004 Ford F150 4x4
lol.
Unless you have forced induction or a built engine, 2.5" true duals are not going to net you more low end torque than a y-pipe will. There is a reason all fullsize trucks come from the factory with a y-pipe design....
To the OP: no advantages/disadvantages as far as performance. Just pick the look you like best and go with it.
- Pioneer Premier - US Amps - Image Dynamics - JL Audio - Raammat - Secondskin - KnuKoceptz - SOON--> Stereo Integrity
Old 08-19-2008, 02:05 PM
Quote:
Originally Posted by mSaLL150 View Post
lol.
Not ALL fullsize trucks, my buddy's GMC came stock with no Y pipe, just a single muffler, dual in, single out... But that's a GMC and what do they know anyway!
2004 F150 XLT 4.6L SCAB - 2.5" Leveling Kit - Edge Evolution Level 2 - S&B Cold Air Intake - Rhino Liner -
Magnaflow True Duals & High Flow Cats - Chrome Step Rails - UWS Black Toolbox - Smittybilt Black Bull Bar - ProComp 7" Driving Lights Get Your "Don't Blame Me" Sticker Here
Old 08-19-2008, 02:17 PM
On the dyno @ Troyer's, the highest power came from a y-pipe with a si/so muffler and he recommends that system for a N/A truck without major modification.
Old 08-19-2008, 02:58 PM
Vehicle: 2008 Ford F150
In cold weather, the exhaust will mess up your wheels. The 97 F150s had the exhaust coming out in front of the wheels and in cold weather climates they ruined the wheels. There was a silent recall on the wheels because it was only a problem in the colder areas. I live in Minnesota and had a 97 that Ford replaced the wheel and relocated the exhaust pipe because of the issue.
Old 08-19-2008, 03:15 PM
Thats not at all true. A y-pipe, when properly designed, is a very good thing. Ever heard of 4-2-1 headers? Ever seen the results they produce? All they are is a header some y-pipes. The same thing applies to going from the headers/manifolds into a y pipe then into a single exhaust tail pipe. If everything is properly sized and properly engineered a y-pipe equiped exhaust system will be far superior. Exhaust is all about scavenging and thats what y-pipes are all about.
Old 08-19-2008, 03:18 PM
Quote:
A dual in single out muffler is a y-pipe....it just happens to have a muffler in it.
Old 08-19-2008, 03:25 PM
Wouldn't that make it a Yuffler?
Old 08-19-2008, 03:32 PM
To the GMC exhaust comments, if your guys are speaking of a 2500HD, 2000 - 2006 those trucks exhaust factory are 3" duals with hi flow like cats all OEM, and the whole system is 3" duals, the muffler is a 24" dual in/out then Y jointed running a 3.5" tailpipe. Why I am not sure but they are programmed factory like that and perform quite well. My Silverado 2500HD still got up & went with the stock exhaust, not so much after I did the true dual Super 44s though
Old 08-19-2008, 03:43 PM
Vehicle: 1998 Ford F-150
Advantages are you can hear the exhaust better in the cab, even with a relatively quiet muffler, the disadvantages are the tips do take more abuse, mine cause a black haze on the lower rockers and that it is louder in the cab. I have had 6 different exhaust setups now, and the sideswept is my favorite sounding and looking, sidepipes for life And a y-pipe is the most effective exhaust on a small block that is lightly modified, but the factory Ford y-pipe is necked down ALOT, mine on my 98 measured less than 1 3/4" inside diameter. Run 2.5" duals, I have pictures of mine if you want to see, there is no need for mandrel bent either, the short run of pipe does not need mandrel bent, there won't be any performance gain for the extra $$$ you will have to spend.
Minus the 2 large cats:http://www.youtube.com/watch?v=6RqUGdHwOsc
Other Exhaust Vids:http://www.youtube.com/user/joshmac46
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150online is not affiliated with the Ford Motor Company.
