Will Magnaflow Exhaust from 04-08 SCrew fit 09-14 SCrew?
Does anyone know the answer? I may be upgrading to a 2011 F150 SCrew Lariat w/5.0 from my 2007 F150 Screw Lariat w/5.4. For the sake of trying to save some cash and the fact it was a Bday present, will it fit with possibly just adjusting the hangers? Please let me know. I've tried searching but apparently have not hit the right keywords. Thanks in advance!
I would assume the length of the piping would be similar since the cab styles are the same but pipe routing underneath may be different. You would need to get under both trucks to see if there are any additional cross members or objects blocking the exhaust path. You can buy mandrel 45/90 degree bends or have an exhaust shop modify it for you for cheap typically. Mufflers are the pricey part the piping is relatively cheap just make sure you use mandrel bent pipes to get the pipe radius true.
Thanks for the reply. I'll climb under the new one and check the hangers if I end up buying it. Maybe it'll fit with no problems or minor modification. Either way I've already pulled the exhaust off my '07 and put the stock exhaust back on. I'm selling my '07 anyways. I'll post back once I find out.
Anyone else please chime in if you've done this already. Thanks
Thanks for the reply. I called roush yesterday and they pretty well laughed at me and said everything is completely different and it would never work. I figured that would be their arrogant response. I have compared the factory exhaust for both years and they seem to be pretty well the same to me. I'm expecting to have to some tweaks but was just wondering if it was remotely possible. I put on stainless works headers with their cats and piping kit which was pretty tough dealing with broken studs so I looking for something nice to match it up too now.
