Need Help Possible IAC problem
For a long time my truck would turn the battery light on at 4k rpm and it would go away when it came down under 4000 rpm. I never payed no attention and let that go on for a while. About to weeks ago i was driving and all of a sudden my truck just died out while i was turning into the store. Once i pushed it into a spot i tried starting it again and it started fine but when i hit the throttle it would die after or if I let it idle long enough it would just die. I thought it was the fuel pump so I replaced that and the fuel filter and no luck. I then took the battery and alternator to have it tested and the battery came up with a bad cell and the alternator was good. I found some posts on the IAC getting stuck so I tried cleaning it out. I used carb cleaner I had for my dirt bike but might have made the mistake by trying to dry it with a air compressor. Before It would turn on and idle for a while and now it turns on and dies immediately unless i keep on the gas. Is this a possible IAC problem or something else. Tomorrow I am going to take the throttle body out and make sure it is clean as well.
Also when i turn the ignition to on the battery light and the service engine soon light comes on
