Need help choosing
Old 07-31-2014, 12:19 AM
Vincent1380's Avatar
Need help choosing
Ok so I bought a 2006 ford f150 4.6l xlt 2wd extended cab. I want my truck to sound loud and ballsy and it wanna add some more horse power what should i do?
Old 07-31-2014, 10:12 AM
NFLD FLARED 281's Avatar
magnaflow straight-through muffler would be a fine choice. also gott's mod
Old 08-01-2014, 12:20 AM
coldburn92's Avatar
Yeah search more about Gott's mod. Then a good performance programmer.
Old 08-01-2014, 10:40 AM
EsJayEs's Avatar
Magnaflow exhaust (which is a straight-through design except for their XL-Series). But there are other choices that are less expensive. I'm a big fan of Magnaflow though and have had the pleasure of touring their R&D facility when they prototyped my truck.
http://www.realtruck.com/exhausts/ford/f150/2006/
Gotts mod is a great bang for the buck, or a full intake system such as these:
http://www.realtruck.com/k-n-fipk-ai...006Y212MA.html
http://www.realtruck.com/volant-cold...006Y212MA.html
http://www.realtruck.com/afe-magnum-.../54-11122.html
Then if you want, you could do a tuner. The big advantage is it allows for my final recommendation.
http://www.realtruck.com/performance...ord/f150/2006/
Finally, gears are a great mod. It leverages the power you have and puts more of it to the wheels. A tuner will allow you to adjust the computer and speedometer for it. 4.10 is what I'm runnning and it's perfect. RPM on the interstate is still lower than a Crown Vic with 3.55 gears. This makes the truck much more responsive and the cost is relatively cheap if you do it yourself.
http://www.fordracingparts.com/parts...KeyField=13229
Old 08-03-2014, 01:34 PM
5.4Ls, true dual 2.5" Dynomax bullets on the left, single 3" Magnapack with 2.5" tails on the right. Sound almost exact with mine having the stronger idle.
Quick Reply: Need help choosing
